1957 Plymouth Belvedere Oil Filter/Cartridge Question? Jump to page : 1 2 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
g80panthera |
Member Posts: 8 Location: Longpont sur Orge, France | Hi, I visited the Hothemiheads website and didn't see anything for my 318 A engine. Thank's | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | I'm also interested in contacting chrysler300c to buy one adapter from him. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | g80panthera - 2019-12-11 11:09 PM Hi, I visited the Hothemiheads website and didn't see anything for my 318 A engine. Thank's What I was hoping was that you would phone them and ask. Sometimes the easiest solution is the best. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Or, you could just purchase this one. Kind of pricey, but available. https://www.ebay.com/itm/Mopar-318-Poly-Oil-Filter-adapter-coupler/1... | ||
g80panthera |
Member Posts: 8 Location: Longpont sur Orge, France | Hi, I tried send an email to Hothemiheads (my american language is not good at phone, better to write for me) but my email was rejected. I already saw ebay adapter but the price, WHOW, and for me I have to add shipment and taxe. very very expensive. Thank you | ||
normsclassicradio |
Extreme Veteran Posts: 303 Location: Kalispell, MT USA | OEM Part numbers from 1964 A engine Plate 2402103 Adapter fitting 1739619 or 3671602 | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | g80panthera - 2019-12-12 10:19 AM Hi, I tried send an email to Hothemiheads (my american language is not good at phone, better to write for me) but my email was rejected. Sorry. I forgot that you were in France. I just called Hot Hemi Heads in the States and asked about the poly filter adapter and the answer was no, that it not something that they are doing (or have ever done). He did say that I should contact Chrysler Firepower Magazine because they are making parts. Well after a lot of false leads, I finally figured out that it was Chrysler Power Magazine (no "Fire"). I called their phone number and got a hold of one of their tech support guys. I explained what I was looking for (on behalf of a guy in France with a 64 318 poly) and the response was "That adapter plate is the same as the ones that they used on the LA engines". That means the 318 LA, the 340, the 360, the LA 400 and maybe the later Magnum engines. That should make it easy. To remind ourselves, this is what you are looking for. Plus the gasket. Edited by 56D500boy 2019-03-12 1:48 PM | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Based on searching for LA 318/340/360 parts, you will find: 1. The plate: https://www.ebay.ie/itm/NOS-Mopar-1956-1992-Plymouth-Dodge-273-318-3... 2. The nipple: https://www.ebay.ie/itm/NEW-318-340-360-Oil-Filter-Block-Adapter-Fit... 3. The gaskets: https://www.ebay.ie/itm/MOPAR-LA-Engine-Chrysler-Gaskets-Angle-Oil-F... Hope that helps Edited by 56D500boy 2019-03-12 2:22 PM | ||
normsclassicradio |
Extreme Veteran Posts: 303 Location: Kalispell, MT USA | A search of the OE number 2402103 found this high flow version: https://www.amazon.com/gp/offer-listing/B019XBZD8A/ref=dp_olp_0?ie=U... https://www.hrpworld.com/can22-575-sb-mopar-filter-plate-replaces-mo... Edited by normsclassicradio 2019-03-12 2:04 PM | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Using the part numbers, I was able to find both parts from Summitracing.com Total price is $73 for both parts. Or, you could always make an offer on that other one. I would offer him $45 and see what happens. Filter connector: https://www.summitracing.com/oh/parts/cwa-53007563ab/overview/ Filter plate: https://www.summitracing.com/oh/parts/ctr-22-575 Edit: Looks like we all found them once the part numbers were revealed. Edited by Powerflite 2019-03-12 2:07 PM | ||
normsclassicradio |
Extreme Veteran Posts: 303 Location: Kalispell, MT USA | 53007563AB for the fitting is a current part number thru FCA, MSRP $10.60 Available thru your local Dodge dealer. Though maybe not in Europe? Edit: latest plate part number (2002 LA engine) 53021053 MSRP $6.75, also still available thru FCA dealers. Edited by normsclassicradio 2019-03-12 2:28 PM | ||
g80panthera |
Member Posts: 8 Location: Longpont sur Orge, France | Hello guys, I'm very happy about your help. I wrote a ebay seller to buy the 3 items in only one order. I'll post you the result to confirm that's fit. Hope that oil leak at filter will forget with this adapter. Thank a lot for your time. Fabrice | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | g80panthera - 2019-12-12 11:41 PM I'm very happy about your help. I wrote a ebay seller to buy the 3 items in only one order. I'll post you the result to confirm that's fit. Fabrice Fabrice: As per my email yesterday, hold off on buying the plate and adapter off eBay. I bought a plate and adapter yesterday and picked them up today. I am going out now to mail them to you using the address you sent me. Hope it all works. Dave F. (OilFilterAdapterPartsForA318_small.jpg) Attachments ---------------- OilFilterAdapterPartsForA318_small.jpg (185KB - 488 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Powerflite - 2019-12-12 11:05 AM Using the part numbers, I was able to find both parts from Summitracing.com Total price is $73 for both parts. Or, you could always make an offer on that other one. I would offer him $45 and see what happens. Filter connector: https://www.summitracing.com/oh/parts/cwa-53007563ab/overview/ Filter plate: https://www.summitracing.com/oh/parts/ctr-22-575 Edit: Looks like we all found them once the part numbers were revealed. I've bought the two parts from a Dodge Dealer for a third of that price and shipped them to Fabrice this afternoon. | ||
g80panthera |
Member Posts: 8 Location: Longpont sur Orge, France | Hello Dave, As already said, thank you very much to you. It's very friendly I'll sent picture after conversion. Fabrice | ||
normsclassicradio |
Extreme Veteran Posts: 303 Location: Kalispell, MT USA | To bad Canadian prices are more. It's like our escalated price matrix here in the US. Norm | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | normsclassicradio - 2019-03-15 10:05 AM To bad Canadian prices are more. It's like our escalated price matrix here in the US. Not really "more". It's just the exchange rate. 1 CDN $ = US$ 0.75, i.e. 1.33 factor, i.e. US$6.76 = CDN$9.00, a factor that I have to live with every day. | ||
g80panthera |
Member Posts: 8 Location: Longpont sur Orge, France | Hi All, I tried the adapter today and the result was very bad (as Niagara falls with oil). I was very short in time as I work outside, I put the original filter: it's our daily car. But I will try the next time with more time and I hope inside with car lifter. Thank you, Fabrice | ||
normsclassicradio |
Extreme Veteran Posts: 303 Location: Kalispell, MT USA | I forgot to mention the paper gasket that goes under the plate. Mopar 53020461AB. Discontinued thru FCA, but Fel-Pro makes one part # 70522. (felpro 70522.jpg) Attachments ---------------- felpro 70522.jpg (21KB - 440 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | normsclassicradio - 2019-04-23 1:34 PM I forgot to mention the paper gasket that goes under the plate. Mopar 53020461AB. Discontinued thru FCA, but Fel-Pro makes one part # 70522. I think we flagged the gaskets to Fabrice back when, I know I did. 56D500boy - 2019-03-12 10:55 AM Based on searching for LA 318/340/360 parts, you will find: 1. The plate: https://www.ebay.ie/itm/NOS-Mopar-1956-1992-Plymouth-Dodge-273-318-3... 2. The nipple: https://www.ebay.ie/itm/NEW-318-340-360-Oil-Filter-Block-Adapter-Fit... 3. The gaskets: https://www.ebay.ie/itm/MOPAR-LA-Engine-Chrysler-Gaskets-Angle-Oil-F... https://www.ebay.ie/itm/372597825645?ul_noapp=true Edited by 56D500boy 2019-04-23 6:19 PM | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | If you were here you could go to any junk yard & take one off any LA in the yard. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Mopar1 - 2019-04-24 3:35 AM If you were here you could go to any junk yard & take one off any LA in the yard. Small problem. Fabrice is in France. Edited by 56D500boy 2019-04-24 8:39 AM | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 56D500boy - 2019-04-24 7:37 AM That's why I said "If you were here"....Mopar1 - 2019-04-24 3:35 AM If you were here you could go to any junk yard & take one off any LA in the yard. Small problem. Fabrice is in France. :( | ||
g80panthera |
Member Posts: 8 Location: Longpont sur Orge, France | Hello All, Yes, in France, yunk yards for american car are rare. I already used the Fel Pro 70522. Thank you for your support, Fabrice | ||
1961plymouthfury |
Expert Posts: 2633 Location: Minor Hill, TN | 6 quarts with the filter and 5 with out the. filter. I plan to convert my '61 to the screw on filter . | ||
FURY |
Elite Veteran Posts: 1049 Location: Auckland, New Zealand. | Hi did you ever get this conversion completed without leaks successfully? Did you have to do any internal engine work as some suggested was necessary, to plug the oil bypass valve? Glenn. | ||
