1957 Dodge Coronet decode. Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jherman1 |
New User Posts: 1 | I'm new to this forum but have heard of the awesome members here that are able to decode the tags. I need some help. I picked up a 1957 Dodge Coronet 500series car. Original gold and white paint (anyone know the real paint names?) Anyways, here are the tags. Door tag: 42630980 SO NO MODEL DT PT TO 0816 5122 D661 2142 LPL 210 Any help would be greatly appreciated! Thanks. | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | jherman1 - 2011-06-29 9:06 PM I'm new to this forum but have heard of the awesome members here that are able to decode the tags. I need some help. I picked up a 1957 Dodge Coronet 500series car. Original gold and white paint (anyone know the real paint names?) Anyways, here are the tags. Door tag: 42630980 SO NO MODEL DT PT TO 0816 5122 D661 2142 LPL 210 Any help would be greatly appreciated! Thanks. The serial number - 42630980 Built at LosAngeles, model D66 - 42620001 to 42631610 for a total of 11,610. Yours was the 10,980th D66 built at LA. SO NO (SHIPPING ORDER NUMBER) = 0816 5122 where 0816 is the scheduled build date - August 16, 1957 (very late production) Model - D661 - D66-1 - Dodge Coronet V8 DT - 2142 PT (Paint) - LPL L - Roof & Fins - Glacier White (LA plant only) P - Saddle - Gallant Gold Metallic L - Lower Body - Glacier White (LA plant only) TO (Interior Trim) - 210 - (Do not have 1957 Dodge trim codes) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Oh; missed seeing this one: 2142: standard V/8 engine Coronet 2-dr "Club Coupe" sedan. Trim: Custom Coronet style(extra Mylar trim on upper trim panels, notched upper seat backs, and fluted vinyl on upper seat back areas, in Gold/Black motif. The Custom Coronet TRM option also included "color-coordinated" rubber floor mats, but, since your car has the Gold/Black motif, the floor mats are the same black-rubber as the Standard Coronets have in them. Are there any 'big' numbers stamped across the top area of your LA-built car? Have you looked-checked (carefully!) up/behind the glove box to see if a Broadcast Sheet might be masking-taped there? | ||
softballmom76 |
Member Posts: 8 | i have a 1957 dodge coronet that my husband and i are trying to restore.. the vin # is 35248026 the paint code is 4DED body type 2146 and trim 212 can anyone help me figure out the paint colors? | ||
softballmom76 |
Member Posts: 8 | i have a 57 coronet that i"m trying to find out a little about.. the vin is 35248026 the body code is 2146 the paint code is 4DED and the trim is 212.. can you tell me what color the orignial paint was? | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | softballmom76 - 2011-11-12 3:36 PM i have a 57 coronet that i"m trying to find out a little about.. the vin is 35248026 the body code is 2146 the paint code is 4DED and the trim is 212.. can you tell me what color the orignial paint was? For paint code 4DED - 4 - Paint scheme where saddle area is different colour from the roof, fins and lower. D - Roof and Fins - Misty Green E - Saddle - Forest Green Metallic D - Lower (below side trim) - Misty Green (1957-dodge-D-0A.jpg) Attachments ---------------- 1957-dodge-D-0A.jpg (116KB - 362 downloads) | ||
softballmom76 |
Member Posts: 8 | thank you for your help.. can you help with figuring out what engine it has? the numbers we found on the engine are KDS-I00747 | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Hello; just responded to your engine inquiry on your other thread, on this board. 2146 is the Coronet 2-door hardtop model. Your car may have the standard 2-bbl/single exhaust system, or, it could have the optional twin-pipes, or it could have the "Power Package", which would include the twice-pipes and a 4-bbl carburetor. Your car DOES have, however, the optional "Custom Coronet" interior package, in Green. The Custom Coronet interior option would include color-coordinated (Green, in your car) rubber floor mats (IF the rubber mats are still there, please PROTECT them, as they are very valuable; nobody re-pops them), unique "Star Dot" cloth upholstery, with 'embossed-pleats' in the center areas ("Bolsters", according to the advertisement-descriptions of those areas), and with both seats having notched-down center sections (the standard models have straight-backed seat tops). Also, your car has 'wide' sections of chrome-Mylar trim running across the upper areas of the door and quarter trim panels. And, the front seat is foam-padded. Please post up some images of your car over on our Member's Rides message board. | ||
softballmom76 |
Member Posts: 8 | Thank you so much for all your help.. so the tag on the fire wall has alot of numbers I will type them line by line to see if you can help anymore.... 666 66666677777777 778 123 45678901234567 890 233333333334444444444555556 901234567890123456789012890 3 5 1 9 5 2 4 SCHEDULE BDY PNT TRM A 0502 19113 2146 4DED 212 | ||
softballmom76 |
Member Posts: 8 | And it does have the 4barrel and twin pipes.. | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | softballmom76 - 2011-11-24 7:20 PM Thank you so much for all your help.. so the tag on the fire wall has alot of numbers I will type them line by line to see if you can help anymore.... 666 66666677777777 778 123 45678901234567 890 233333333334444444444555556 901234567890123456789012890 3 5 1 9 5 2 4 SCHEDULE BDY PNT TRM A 0502 19113 2146 4DED 212 The tag should look like - 666 66666677777777 778 123 45678901234567 890 233333333334444444444555556 901234567890123456789012890 3 5 1 9 5 2 4 SCHEDULE BDY PNT TRM A 0502 19113 2146 4DED 212 The blank rows are important. The "61" through "80", read vertically, are the first two digits of the sales code. The number under any column forming a three digit number is a complete sales code. For example, if the "3" is under the "29", the sales code is "293" But we have a problem with proportional spacing. Which is to say the blank space takes up less room on a line than the number 5, for example. In the original post it looked like the sales codes are 293, 315, 221, 359, 375, 392, and 414 as it appears there is one space between each number. But, when I copied into my reply above, the spacing is completely different, although they will look exactly the way they appeared in your post when you read this. Sales codes appear to the 293, 395, 421, 469, 485, 502, 524 or 584. Could you please give us just the three digit columns? Thanks. | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | "We" do not have a proportional spacing problem with this car's P/T plate (as long as the numbers are in proper sequencing). In NO particular order, this car is coded as having been delivered by Truck, to its dealership; it has power windows(!!) on the front doors; the quarter windows are flip out; it has power brakes; undercoating; the Appearance option group: 2-tone steering wheel, stone shields, and the full-but-plain wheel covers; and the Radio Option Group: push-button radio, left O.S. mirror, inside Day/Nite mirror, and back-up lights, and, it's got the TorqueFlite trannie. BTW, the(se) option-numbers, as appear on the P/T plate, are NOT represented by the car's actual "sales codes" as mentioned, above. Again, your car's complete numbers-listings of its options will be displayed on the IBM build card, but, the IBM card will not, necessarily, provide plain-language descriptions of all of your car's build-items/features. I have been able to decypher 57-58 Dodge's build-options (and some/most of the 55-56, and 59-61) as is shown on their P/T plates, from many years' observations of many of these cars' documentations. Edited by d500neil 2011-11-25 8:31 PM | ||
ronbo97 |
Expert Posts: 4043 Location: Connecticut | Chrycoman - 2011-11-24 11:02 PM But we have a problem with proportional spacing. Which is to say the blank space takes up less room on a line than the number 5, for example. The way to get around this is to use a monospace font, such as Courier New. Here is an example: SCHEDULE BDY PNT TRM Ron | ||
