Dual Quad AFB's 2653S, 2652S Date B8 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
bjinx |
Member Posts: 6 Location: Houston, Tx | These carburetor numbers were used on the following motors as a dual quad set-up:1958 Desoto Adventurer 361ci LS-3S and the 1958 Plymouth Fury 350ci LP2-S All shafts turn freely, bases are flat (used straight edge to check), no chips or cracks on the bodies, floats are still good, they have correct metering rods. No tags so I believe they have been rebuilt at least once. They came apart easy when I inspected the inside, both have oxidation in the bowls but no pitting. They choke cap has two pieces broke off the edge, they fit back real well but do not know if this can be repaired. The 2653 accelerator pump lever has been repaired earlier in its life and has the wrong rod. The 2653 also looks to have had extra holes drilled in the base for another application. I have taken every screw out of these carbs and all of the threads are good on the screws and the bodys of the carbs. Both carbs are in very shape but need a complete cleaning and rebuild. Because this is a matched pair I will not sell separatly, only as a pair. Please PM any responses and or questions. No trades I only take US postal Money Orders as payment. $895.00+Shipping to the lower 48 states Edited by bjinx 2011-09-27 2:29 PM (Front.JPG) (Left.JPG) (Right.JPG) (Bottom.JPG) (Top.JPG) (2653.JPG) (2652.JPG) (361.JPG) (Plastic 1.JPG) (Plastic 2.JPG) Attachments ---------------- Front.JPG (163KB - 173 downloads) Left.JPG (160KB - 109 downloads) Right.JPG (155KB - 140 downloads) Bottom.JPG (163KB - 154 downloads) Top.JPG (151KB - 129 downloads) 2653.JPG (148KB - 127 downloads) 2652.JPG (138KB - 126 downloads) 361.JPG (127KB - 136 downloads) Plastic 1.JPG (151KB - 148 downloads) Plastic 2.JPG (147KB - 150 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | These bad boys were also OEM to the 1958 Dodge Super D500 cars. 52: front; 53: rear. | ||
bjinx |
Member Posts: 6 Location: Houston, Tx | A friend said he thought they were used on Dodge but I never found that as I researched them. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | 1958 8 LD2-L, Coronet Stromberg WW 3 163 487 1958 8 LD2-L, Coronet Stromberg WW 3 164 487 1958 8 325 LD2-M Carter WCFB 2660 165 1958 8 350 LD3-H Carter AFB 2642 209 1958 8 361 LD3-S, D500 Carter AFB 2642 209 1958 8 361 Police Special Carter AFB 2801 209 1958 8 361 LD-3S (Front of 2) Carter AFB 2652 213 1958 8 361 LD3-S (Rear of 2) Carter AFB 2653 213 | ||
muddy |
Veteran Posts: 114 Location: South Australia | I take it that these would bolt onto the 57 (dual four) 318 manifold? (1822004) I realise they're not original for that application. | ||
big m |
Expert 5K+ Posts: 7808 Location: Williams California | muddy - 2011-09-28 5:07 PM I take it that these would bolt onto the 57 (dual four) 318 manifold? (1822004) I realise they're not original for that application. Yes, Grant, they will bolt directly on the Poly manifold. ---John | ||
muddy |
Veteran Posts: 114 Location: South Australia | Thanks for that John.Appreciated. | ||
bjinx |
Member Posts: 6 Location: Houston, Tx | Sale pending | ||
bjinx |
Member Posts: 6 Location: Houston, Tx | bjinx - 2011-09-29 12:20 PM SOLD TO MUDDYSale pending | ||
