58 Plymouth Sedan Jump to page : 1 2 3 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
dukeboy |
Expert 5K+ Posts: 6203 Location: Big pimpin' | That's What I'm talking bout!! BB, 4-speed, Dana 60, does it get any better? Would LOVE to hear that 'ol BB screamin' up round 6000 and walkin' through the gears. Edited by dukeboy 2012-05-07 12:53 PM | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I can't wait to hear it either. It's been a long time since I jammed through the gears. That 4:10 posi in the Dana should tear up some asphalt. I also got the disc brake caliper mounts from Scarebird this weekend so that is next on the list. I have a stock 63 Plymouth Hurst shifter and I'm trying to decide if I like the length and positioning. What does everyone else think? (IMAG1021.jpg) (IMAG1022.jpg) Attachments ---------------- IMAG1021.jpg (66KB - 120 downloads) IMAG1022.jpg (68KB - 135 downloads) | ||
big m |
Expert 5K+ Posts: 7808 Location: Williams California | Todd, What was the issue with the passenger side quarter panel that it needed replacement? Just curious. ---John | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | It had a bunch of pieces that were all patched into it and poorly done. It was one big hole that was about 2 1/2 feet by 1 foot tall that was patched with 4 different pieces of metal and they were only tacked in. I decided to just replace the whole thing since I had a quarter panel laying around. When I get home I will post a picture of the bad patch job. | ||
savoy_man |
big m |
Expert 5K+ Posts: 7808 Location: Williams California | Gotcha! I would have replaced it too if it were on my car. ---John | ||
BarnFind57 |
Elite Veteran Posts: 957 Location: Signal Mountain, TN | I love the look of a tall shifter in a street/rat rod for sure.... I would toss it through the gears a few times pretty quick if I was you, though. I installed a bus shifter in a bug years ago... it looked really good untill that one day that I was shifting rapidly and ran forward too fast, cracking my knukles on the dash... Product testing they call it... | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Took me a long time to post these pics. Terrible week at work with server crashes. The shifter is a stock one from a 63 Plymouth and trust me the 63 dash has dents in it. I will probably heat it and bend it back slightly for clearance. (IMAG0939.jpg) (IMAG0941.jpg) (IMAG0942.jpg) Attachments ---------------- IMAG0939.jpg (54KB - 117 downloads) IMAG0941.jpg (55KB - 128 downloads) IMAG0942.jpg (80KB - 122 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I decided to start the disc brake conversion and took the drum off the front and found something surprising. The original drum brakes look like new. (IMAG1045.jpg) (IMAG1049.jpg) (IMAG1050.jpg) Attachments ---------------- IMAG1045.jpg (59KB - 122 downloads) IMAG1049.jpg (52KB - 134 downloads) IMAG1050.jpg (56KB - 122 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I also got the rear end all painted up and it is mounted and the new air shocks installed. (IMAG1039.jpg) Attachments ---------------- IMAG1039.jpg (67KB - 131 downloads) | ||
BarnFind57 |
Elite Veteran Posts: 957 Location: Signal Mountain, TN | Looking good, man. My front drum brakes, alas, did not look like that when I took my drums off.... | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I had issues with the headers my grandpa built not fitting. It must be where I placed my engine. I must be just a smidge back from stock. So since I had the holes and another set of headers I decided to stick with fender exits. (IMAG1065.jpg) Attachments ---------------- IMAG1065.jpg (129KB - 123 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I pulled everything back out and powerwashed the engine bay and sprayed some black paint. I really would have liked to do a bunch of bodywork under the hood but I'm trying to get the car on the road quickly so I can take it to a car show I am hosting. The detail work will have to wait until the winter and I will tear everything back apart. (IMAG1069.jpg) (IMAG1070.jpg) (IMAG1071.jpg) Attachments ---------------- IMAG1069.jpg (72KB - 119 downloads) IMAG1070.jpg (67KB - 125 downloads) IMAG1071.jpg (87KB - 125 downloads) | ||
Windsor Wendy |
Extreme Veteran Posts: 395 Location: Netherlands | savoy_man - 2012-05-24 6:12 AM I also got the rear end all painted up and it is mounted and the new air shocks installed. Where did you mount the air valve(s) for the air lines to the shocks? We have the same shocks but still undecided where the valves should sit... I take it you know that using a T-piece in the air lines makes for an "anti" anti sway bar? | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I ran the lines across to the other side of the car to the outside of the frame rails then down the frame rails and came back together in the middle of the cross piece at the back of the car. That might not makes sense but since the air lines point inwards I ran the left shock line down the right side of the car and vice versa so i wouldn't have to kink them back to run them down the frame. I did use the T because I'm not too worried about anti-sway. This will be more of a straight line car anyway. | ||
LookForward |
Regular Posts: 78 Location: Mistake on the Lake | Wicked! | ||
JT Vincent |
Expert Posts: 1493 Location: Jamaica Plain, MA | That car is going to be amazing. If I were going to build something from the ground up, I'd do it the same way. Outstanding. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Thanks. It is pretty much being built exactly how I want. I am a hot rodder and love mean looking mean sounding cars. I know it's not the style for everyone. If only I could afford a blower and tubbing the car. | ||
lawrence |
Expert Posts: 3951 Location: Bama | That is gonna be a sweet ride! | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | It's been a long busy summer and I haven't been posting updates. The progress has been slow. I've had a few setbacks and that has slowed the progress. I also haven't been able to spend as much time on it as I would like. Funny how life gets in the way of your play time. (IMAG1074.jpg) (IMAG1075.jpg) (IMAG1077.jpg) (IMAG1079.jpg) (IMAG1088.jpg) (IMAG1090.jpg) (IMAG1093.jpg) (IMAG1092.jpg) (IMAG1096.jpg) Attachments ---------------- IMAG1074.jpg (128KB - 166 downloads) IMAG1075.jpg (135KB - 142 downloads) IMAG1077.jpg (99KB - 114 downloads) IMAG1079.jpg (121KB - 196 downloads) IMAG1088.jpg (66KB - 120 downloads) IMAG1090.jpg (106KB - 133 downloads) IMAG1093.jpg (85KB - 120 downloads) IMAG1092.jpg (98KB - 130 downloads) IMAG1096.jpg (103KB - 129 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | As you can see in the pics I got the brake lines all run and the proportioning valve and master cylinder in. I also installed a Summit line lock and it turns out to be junk. The whole body of it leaked like crazy when I bled the brakes. I replaced it with an old Hurst one I had lying around but not sure it it still works. At least it doesn't leak! The summit one was so poorly made the threads that hold the two pieces of the body together really don't match up. It is brand new but I bought it over 2 years ago so I'm sure they won't exchange it. I've sandblasted and powder coated the z bar and clutch fork and also the blow proof bell housing. The engine is in but i still need to put in the trans. The quarter is hung and I'm almost done welding it. Hopefully I can get this car on the road soon. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | It has been a while since I have been on and posted anything. Life gets in the way sometimes. i haven't made any huge strides lately but some progress has been made. I got the engine and trans all done and lots of bodywork done on the passenger side. Here are a few pics of that. (IMAG1114.jpg) (IMAG1118.jpg) (IMAG1122.jpg) (IMAG1123.jpg) (IMAG1124.jpg) (IMAG1126.jpg) (IMAG1127.jpg) (IMAG1130.jpg) (IMAG1131.jpg) Attachments ---------------- IMAG1114.jpg (38KB - 127 downloads) IMAG1118.jpg (60KB - 155 downloads) IMAG1122.jpg (67KB - 133 downloads) IMAG1123.jpg (48KB - 122 downloads) IMAG1124.jpg (47KB - 123 downloads) IMAG1126.jpg (61KB - 127 downloads) IMAG1127.jpg (47KB - 136 downloads) IMAG1130.jpg (46KB - 124 downloads) IMAG1131.jpg (64KB - 128 downloads) | ||
bel5758 |
Elite Veteran Posts: 716 | Woof! Good work - that's going to be a beast. | ||
58sportsuburban |
Extreme Veteran Posts: 449 Location: jersey | Is that a '65 dodge next to it? | ||
quick_tsi |
Member Posts: 47 | Just wondering, what headers did you wind up using? Thanks Jared | ||
JT Vincent |
Expert Posts: 1493 Location: Jamaica Plain, MA | Sweet! This is one of my favorite projects on here. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Sorry but I've been absent for a while. I was busy putting on a car show and it is amazing how much time that takes. Thanks for the compliments. The headers are A body fender exits. They required a bit of tweaking but they worked out well. I've gone out of town a couple of times in the last month and will be going out of town this weekend but hopefully after that I can get back on the bodywork and put the car on the road. It's been weeks since I've touched my car and I'm ready to work again. The car next to it is a 64 Dodge that I've put a straight axle under. It will be a Poly Powered Gasser with fender exit headers that I built from scratch. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | It has been a long time since I have posted but I have finally made progress on my car. I had to finish building a 64 Dodge for a friend. I almost have all of the bodywork done so hopefully this weekend I will be able to primer the whole car and start blocking it out. It's gotta be smooth because I have decided to paint it black. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Here are some pictures. (2014-05-18 14.32.53.jpg) (2014-05-18 14.33.14.jpg) (2014-06-08 17.59.44.jpg) (20140613_214048.jpg) (20140613_214305.jpg) (20140706_144309.jpg) (20140706_144136.jpg) (20140706_144136.jpg) (20140611_071430.jpg) Attachments ---------------- 2014-05-18 14.32.53.jpg (257KB - 110 downloads) 2014-05-18 14.33.14.jpg (268KB - 110 downloads) 2014-06-08 17.59.44.jpg (258KB - 108 downloads) 20140613_214048.jpg (299KB - 107 downloads) 20140613_214305.jpg (297KB - 99 downloads) 20140706_144309.jpg (199KB - 104 downloads) 20140706_144136.jpg (282KB - 99 downloads) 20140706_144136.jpg (282KB - 110 downloads) 20140611_071430.jpg (291KB - 110 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | In case you were interested here is the finished 64 gasser. (2013-09-06 22.11.06.jpg) (2013-09-06 22.11.33.jpg) (2013-08-18 22.31.16.jpg) (2013-08-18 22.31.23.jpg) (2013-08-09 18.51.50.jpg) Attachments ---------------- 2013-09-06 22.11.06.jpg (281KB - 109 downloads) 2013-09-06 22.11.33.jpg (254KB - 100 downloads) 2013-08-18 22.31.16.jpg (376KB - 110 downloads) 2013-08-18 22.31.23.jpg (349KB - 103 downloads) 2013-08-09 18.51.50.jpg (264KB - 98 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | I have no idea how I missed your Plymouth before. Looking good! Love the candymatic Dodge, too... | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I got the car in full primer and guide coat this weekend. (guidecoat1.JPG) (guidecoat2.JPG) (guidecoat3.JPG) (guidecoat4.JPG) Attachments ---------------- guidecoat1.JPG (69KB - 101 downloads) guidecoat2.JPG (56KB - 106 downloads) guidecoat3.JPG (55KB - 105 downloads) guidecoat4.JPG (62KB - 99 downloads) | ||
big m |
Expert 5K+ Posts: 7808 Location: Williams California | Nice progress!! ---John | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Thanks John. I'm hoping to have it done for a car show here called Last Fling Til Spring. It is at the end of September and Richard Rawlings will be there. It would be a lot more fun to show up in this than my Beetle. | ||
Expert 5K+ Posts: 5006 | where did you find a good two door donor quarter? Or is that a four door? | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | It was a 4 door quarter. That is why I only did the back half. | ||
Expert 5K+ Posts: 5006 | Okay yeah I see the smaller body line, I have to map a 4 door quarter onto a two door. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Just some more progress picks. (BlackBeauties.JPG) (20140724_070327.jpg) (20140724_070341.jpg) (20140724_070352.jpg) (20140724_070400.jpg) (20140724_070413.jpg) (20140724_070434.jpg) Attachments ---------------- BlackBeauties.JPG (51KB - 100 downloads) 20140724_070327.jpg (41KB - 98 downloads) 20140724_070341.jpg (40KB - 106 downloads) 20140724_070352.jpg (39KB - 97 downloads) 20140724_070400.jpg (41KB - 103 downloads) 20140724_070413.jpg (40KB - 109 downloads) 20140724_070434.jpg (41KB - 102 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Primed and in guide coat for a second time. (20140729_224343.jpg) (20140729_224410.jpg) (20140729_224431.jpg) (20140729_224449.jpg) (20140729_230028.jpg) (20140729_230854.jpg) Attachments ---------------- 20140729_224343.jpg (37KB - 103 downloads) 20140729_224410.jpg (33KB - 98 downloads) 20140729_224431.jpg (34KB - 102 downloads) 20140729_224449.jpg (39KB - 103 downloads) 20140729_230028.jpg (40KB - 106 downloads) 20140729_230854.jpg (38KB - 106 downloads) | ||
quick_tsi |
Member Posts: 47 | Nice to see the progress on this one. This is one of my favorite builds on this forum, and combined with a couple of others is my motor-vation on my 59. Keep up the great progress. All the best, Jared | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | I have been offline for a while and haven't posted progress so here goes the major picture dump. (20141207_160729.jpg) (20141207_160738.jpg) (20141207_212904.jpg) (20141207_212916.jpg) (20150321_205403.jpg) (20150321_205410.jpg) (20150321_205443.jpg) (20150321_205453.jpg) (20150321_205655.jpg) (20150323_185044.jpg) (20150323_185108.jpg) (20150323_185028.jpg) Attachments ---------------- 20141207_160729.jpg (66KB - 103 downloads) 20141207_160738.jpg (84KB - 103 downloads) 20141207_212904.jpg (113KB - 105 downloads) 20141207_212916.jpg (105KB - 113 downloads) 20150321_205403.jpg (111KB - 98 downloads) 20150321_205410.jpg (117KB - 106 downloads) 20150321_205443.jpg (98KB - 100 downloads) 20150321_205453.jpg (121KB - 97 downloads) 20150321_205655.jpg (84KB - 102 downloads) 20150323_185044.jpg (82KB - 100 downloads) 20150323_185108.jpg (65KB - 104 downloads) 20150323_185028.jpg (119KB - 100 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | And finally painted. (20150326_164230.jpg) (20150326_164236.jpg) (20150326_164244.jpg) (20150326_164301.jpg) (20150326_164309.jpg) (20150326_182317.jpg) (20150326_182328.jpg) (20150326_191432.jpg) (20150326_191607.jpg) (20150326_191640.jpg) Attachments ---------------- 20150326_164230.jpg (94KB - 99 downloads) 20150326_164236.jpg (91KB - 95 downloads) 20150326_164244.jpg (97KB - 101 downloads) 20150326_164301.jpg (109KB - 98 downloads) 20150326_164309.jpg (105KB - 114 downloads) 20150326_182317.jpg (104KB - 108 downloads) 20150326_182328.jpg (125KB - 104 downloads) 20150326_191432.jpg (119KB - 110 downloads) 20150326_191607.jpg (87KB - 98 downloads) 20150326_191640.jpg (120KB - 110 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | Just started buffing. (20150329_224011.jpg) (20150329_224040.jpg) Attachments ---------------- 20150329_224011.jpg (133KB - 99 downloads) 20150329_224040.jpg (118KB - 97 downloads) | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | Oh Black Momba... I don't know the rest of the song!!! What kind of Mini bike? I have 3 mini's myself. | ||
196061SAVOY |
User has resigned from board | is the one piece back quarter side glass available, I think that would add a lot to the look, very nice work (57sedan-1.jpg) Attachments ---------------- 57sedan-1.jpg (38KB - 108 downloads) | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | The mini bike is a Trail Horse. There are 2 other minibikes and a moped sitting back there with it. I have been trying to figure out how to make the back glass one piece. That would make it look less clunky and a little sleeker. It looks like your pic is exactly what I'm going for only in red and minus chrome. Now I have to figure out what rims I am going to run. I am thinking Cragar S/S. | ||
jimntempe |
Expert Posts: 2312 Location: Arizona | I thought I read in a thread somewhere on this board that the Business coupes that did not have a back seat had a one piece rear side window that was fixed in place. | ||
JT Vincent |
Expert Posts: 1493 Location: Jamaica Plain, MA | Looks awesome. The one piece back window glass is easy-- a good glass shop should have a template, or you can make one with cardboard. It would have to be laminated safety glass. It's flat, despite what some people say. About the A body headers, did you use those for coolness factor, or did off-the-shelf RB headers not fit? | ||
mstrug |
Expert 5K+ Posts: 6502 Location: Newark, Texas (Fort Worth) | Your car is going to be tough! I like the fact that you are keeping some sort of Sport Tone Trim on her. Did you sell the 3 speed and hemi? Marc. | ||
savoy_man |
Veteran Posts: 191 Location: Nebraska | The headers were just for the cool factor. I had them in the garage and wanted to use them. The one piece glass I am sure I could have cut but I was wondering what to do about the gaskets and mounting. I don't know how to get the window all sealed up and set in place. I did sell the Hemi and trans. In hindsight I probably should have kept it but I just don't have enough storage space. Hey 196061SAVOY - Do you have the psd file for that picture or would you be able to modify it to help me figure out what rims I want? I want to see what my car would look like with Cragars or the grey Rocket Racing Strike rims. | ||
