1959 Dodge 4-Door Sedan Build Sheet
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
jpmopar
Posted 2012-03-12 9:02 PM (#311848)
Subject: 1959 Dodge 4-Door Sedan Build Sheet
I was looking through some old papers and found this build sheet that I pulled from my '59 Dodge Custom Royal 4-door sedan parts car. It was taped to the back of the glove box.
(59 Dodge Sedan Build Sheet.jpg)
Attachments 59 Dodge Sedan Build Sheet.jpg (114KB - 315 downloads)
d500neil
Posted 2012-03-28 9:37 PM (#314278 - in reply to #311848)
Subject: Re: 1959 Dodge 4-Door Sedan Build Sheet
5000500050002000200010025
Each car had several Broadcast Sheets attached to different parts of them.
Your B.-Sheet was annotated on its "Special Instructions" box to identify how that particular dash was to be created and painted.
It says "all-Black" and "Custom Royal"; apparently without any other accoutrements, like a "Crash Pad" or "convertible-contol"
or "power tail gate window lift" any of the other optional devices/controls that were installed onto a 1959 Dodge dash board.
When the dash board was finished, its "instruction manual" (the B.-Sheet) was taped to its back, so that, when it arrived at the
assembly line, along with the car body, a Line Supervisor could confirm that 'this' dash' did get to be installed into 'that' body.
Some B.-Sheets, for whatever reasons, were left, taped onto the glove boxes, as a sort of a Time Capsule/gift to the future.
Note option code 429 : "Roof Molding"--that's a bit of a typo; it confirms the quarter panel "gills".
Option 501 is Undercoating, and the Axle Ratio 533 is the "Hi-Performance" 3.31:1
Its tires were Rayon 8.00x 14" white walls.
Its paint scheme was mis-inked; the "2" means that it was the least-complex 2-tone (called The "Deluxe"!), but only one of
the two colors is identified: "Beige", and the second color would only appear on the car's fins.
It did have the black/white swivel seats.
Nice parts-car!
