super glue , blue thread locker ?
60 dart
Posted 2013-01-26 1:20 AM (#356826)
Subject: super glue , blue thread locker ?
50002000100050010010010010025
anyone ever try it ? -------------------------------------------------------later
DeSotohead
Posted 2013-01-26 8:46 AM (#356869 - in reply to #356826)
Subject: RE: super glue , blue thread locker ?
Board Moderator
20001000100252525
Location: The not-so-great, dirty-white North ( Michigan)
Chuck...
I use the Loctite Blue threadlocker a lot on anything that has low torque tightening and a possibility of vibration.
I use the stronger Red Loctite on larger diameter bolts, and the Green Loctite Stud and Bearing Mount for exactly that. High torque applications.
BTW, the Green sometimes needs a heat assist to get a release, so watch it.
As for superglue, I use that on stuff that has low shear (twist/slide) need, such as repair of a cracked part that can be repainted, but does not need ultimate strength.
60 dart
Posted 2013-01-26 2:31 PM (#356928 - in reply to #356826)
Subject: Re: super glue , blue thread locker ?
the super blue seems to be like the loctite red ..... the super red seems to be like the loctite green . i thought i'd give the super blue a try and it's cheap ---------------------------------later
rockerarm
Posted 2013-02-14 5:58 PM (#360023 - in reply to #356826)
5001001001002525
60 dart - 2013-01-26 1:20 AM anyone ever try it ?
Blue thread locker works good for low torque applications and for aluminum.
Red for larger fasteners and higher torque, not recemended for use on aluminum.
Use a good anti sieze compound on fasteners that are removed on a regular basis.... (lug nuts, etc)
dukeboy
Posted 2013-02-15 12:53 PM (#360146 - in reply to #360023)
50001000100100
rockerarm - 2013-02-14 5:58 PM
You wouldn't believe the strength of some of that stuff. Most do not realize there are different strengths and uses for each.
Edited by dukeboy 2013-02-15 12:56 PM
(2thumbs.gif)
Attachments 2thumbs.gif (1KB - 117 downloads)
