torqueflite 1956 to 1959 rear tail shaft bearings
hemidenis
Posted 2013-02-20 9:41 AM (#360893)
Subject: torqueflite 1956 to 1959 rear tail shaft bearings
20001000500100100100252525
Hi
Looking for a rear tail shaft bearings for a Torqueflite, does someone know the Timken or other cross reference for this bearing? Mopar # 1672194 it will be very helpful.
Thanks
58coupe
Posted 2013-02-20 10:58 AM (#360900 - in reply to #360893)
Subject: Re: torqueflite 1956 to 1959 rear tail shaft bearings
100050010010025
Check with your local bearing supply, should be a common ball bearing but I don't have the number.
rbmain
Posted 2013-02-20 11:56 AM (#360906 - in reply to #360893)
100010010010010025
OEM PART NUMBER: 1672194 OEM MAKE: CHRYSLER CORP. ABV: CHRYSL Timken Part Number: 2061 TYPE: TIMKEN BEARING UNIT Manufactured By: Timken
http://mibearings.com/timken-oem-bearing-unit-c-3834_7237/chrysler-...
All I did was Google "1672194 Timken". Took 5 seconds, Geez.
Edited by rbmain 2013-02-20 11:58 AM
hemidenis
Posted 2013-02-20 8:08 PM (#360979 - in reply to #360893)
Thanks a lot guys, doing those google search before i ending up with hundred dollars of parts i can't use, just last week autozone catalog was WRONG with their ball joints. HELL TIMKEN CATALOG IS WRONG too! showing 206WB wich is not correct.
However i ending up with the same conclusion 2061 but i have a NOS Output shaft and the diameters are not matching.
Edited by hemidenis 2013-02-20 8:40 PM
bbrasse1
Posted 2013-02-20 8:14 PM (#360981 - in reply to #360979)
50025
Rock Auto is wrong on lower full size 57 Desoto/Chrysler lower ball joints. Uppers are correct.
Phil_the_frenchie
Posted 2013-03-02 4:30 PM (#362705 - in reply to #360979)
500100100100100
I found this
Mopar #
1736432 SNAP RING, Ext. Brg., w/Short Extension
1672194 BEARING, Ext., w/Short Extension
NAPA#
Item#: BRG6207VSP55
Price: $50+
Additional Contents:Ball
I.D.:1.3780"
O.D.:2.8346"
Width:0.6693"
The message came from a Ramcharger forum and about a 74 Torqueflite !
I found also SKF 6207VSP55
Edited by Phil_the_frenchie 2013-03-02 4:32 PM
chrysler300c
Posted 2013-03-02 6:56 PM (#362727 - in reply to #362705)
Expert ,, George Passed away July 28th 2021, He will be Missed
1000100100252525
I have a new one at my shop.... I can check the number on it on Sunday and post it here. I bought from Gary Nelson, but it was the last one he had at the time.
George
