1957 imperial frame off restoration Jump to page : 1 2 3 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Wiz, we have great craftsmanship here, guys work almost with out proper tooling. those Teflon joints are designed for race cars applications when regular ball joints are not going to last. I convinced to this busy guy to do the job on my car because the rarity of it. Edited by hemidenis 2013-05-10 11:35 PM | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | no much going today, weather sucks I'm ready to work on the axle. i would say that the last owner maybe experienced some engine vibrations, judging by this rubber mount Edited by hemidenis 2013-05-12 3:41 PM (image.jpg) Attachments ---------------- image.jpg (69KB - 214 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Finally is Torquefllite time (image.jpg) Attachments ---------------- image.jpg (109KB - 207 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Years collecting Torquefllite stuff finally ready to use (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (111KB - 211 downloads) image.jpg (120KB - 195 downloads) image.jpg (93KB - 206 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | hard to find to Unobtanium (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (97KB - 210 downloads) image.jpg (112KB - 209 downloads) image.jpg (103KB - 201 downloads) image.jpg (112KB - 198 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | all almost new, friction discs impeccable. (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (101KB - 200 downloads) image.jpg (69KB - 222 downloads) image.jpg (97KB - 198 downloads) image.jpg (104KB - 218 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Five clutch packs; heavy duty trannie. | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | yes it is, I have another thread on trans section with questions about this rare sample. http://forwardlook.net/forums/forums/thread-view.asp?tid=47026&post... | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | My dodge trans is the same, 5 discs in the front and 4 in the intermediate. Putting the overun clutch together was a challenge without the special tool, but did it by useing 10 3/16 screws to hold the rollers back | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | late 57 -58 cast iron torqueflites had 5 clutch plates , 10 plate total 59 and later had 4 clutch plates , 8 plate total Edited by 60 dart 2013-05-17 12:19 AM | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Mine has 9 Chuck? 5 in the front 4 in the rear Does that meen that the front clutch assembly may have been changed? | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | that's not what my auto trans book is showing for cast iron torqueflite . it also says rear has 5 clutch plates and 5 driving discs -------------------------------------------------later | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | slow advance, I finished the valve body and the clutch packs, (specially thanks for Phil for the data and pics) and of course to all members who always put some input. weather is horrible, I can't paint the housing but I'm going to make an small oven to cook the epoxi paint, I can't wait no longer for the weather. Last night I changed all the bushings, which was and accomplishment in itself, seems like a few rebuilders do that, is noticeable the reduction of the side play on the components, even that the bushing looks fine there is a considerable wear on them. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (77KB - 205 downloads) image.jpg (95KB - 203 downloads) image.jpg (96KB - 222 downloads) image.jpg (89KB - 209 downloads) image.jpg (77KB - 208 downloads) | ||
Phil_the_frenchie |
Elite Veteran Posts: 915 Location: Pau, S-W France | d500neil - 2013-05-17 1:23 AM Five clutch packs; heavy duty trannie. All '57-59 Imperial had the five clutches assembly in rear clutch. Also NewYorker (and 300 !!). Front clutch has four discs. Edited by Phil_the_frenchie 2013-05-19 6:40 PM (front5 [1024x768].JPG) (rearclutch [1024x768].JPG) Attachments ---------------- front5 [1024x768].JPG (148KB - 200 downloads) rearclutch [1024x768].JPG (141KB - 199 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | slow advance today, weather still horrible. My heater went down just a bit after I started, but at least I cleaned the trannie to perfection, I used a acid that converts rust in a brownish powder and grease in a white one. The job is completed by a wire brush, and the trannie is back to new again. Tomorrow is paint day, no matter what. I need to get my heater back to life. Edited by hemidenis 2013-05-22 12:22 AM (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (115KB - 196 downloads) image.jpg (115KB - 205 downloads) image.jpg (114KB - 190 downloads) image.jpg (121KB - 196 downloads) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Fun job isnt it Why did they have to put so many little corners in the case | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Finally weather improved, and my heater is running. Finished the housing with 4 layers of epoxy paint, but i used my own formula to make the cast iron color, since this particular tone is not available, came out good i guess. I assembled the 1-2-3 units in to it and valves, i painted the aluminum pieces with four epoxy layers plus 2 of clear coat. Definitely this is an over restored trannie but look good. If everything is good tomorrow the transmission will be done. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (110KB - 203 downloads) image.jpg (95KB - 201 downloads) image.jpg (97KB - 207 downloads) image.jpg (73KB - 214 downloads) image.jpg (105KB - 212 downloads) image.jpg (103KB - 194 downloads) image.jpg (77KB - 196 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Warning: the parking brake dust cover is a grease-dirt-oil nightmare to clean, just near the parking cable support. Took me a long time to get it done properly. | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | What kind of bad weather are you having? ? I thought it was always warm where you live! Your trannie looks amazing. Edited by imopar380 2013-05-25 10:54 PM | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Thanks! yes 2 weeks of rain! Very humid and cold! Winter is setting in... | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | That looks great Your silver is better looking than mine, but I just used aluminium engine enamel Nice job | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Thanks! Good advance today, the T-flite is almost done. I need to restore the pan, assemble the parking brake and the torque converter and is done..... After 2 decades the engine and the trannie they are about to be bolted together again. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (110KB - 184 downloads) image.jpg (83KB - 196 downloads) image.jpg (102KB - 193 downloads) image.jpg (90KB - 198 downloads) image.jpg (85KB - 196 downloads) image.jpg (76KB - 192 downloads) | ||
Doctor DeSoto |
Location: Parts Unknown | Some people run from the gunfire. Some people run towards it. I see you have no fear of diving into the deep end of the pool. Looking great ! | ||
60 Imp |
Location: North Australia | No big deal, but I had to remove the park brake to remove and install the engine and gearbox from my 60. only just enough room to get the assembly out and back in! This was with the body on the chassis, and the box/torsion bar crossmember also installed. Steve. | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | Great work and pictures Denis - thanks for sharing! I have saved you pics for reference to be used on my upcoming TF renovation. | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Thanks guys! Lot of advance in the last few days the trans is done, with oil filter and pan installed. I also painted the trans adapters. A before and after pictures. (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (114KB - 195 downloads) image.jpg (58KB - 187 downloads) image.jpg (83KB - 186 downloads) image.jpg (54KB - 200 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Thompson time..... Edited by hemidenis 2013-06-01 9:52 PM (image.jpg) (image.jpg) Attachments ---------------- image.jpg (81KB - 202 downloads) image.jpg (86KB - 189 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | I would just like to say that this is a perfect example of over engineering. This is basically a piece that could be in the SR-71, not in a car :). I had to build the special tooling required for the re assembly it, I also resurface the pumps, because they were very scratched. This nightmare is a double rotor pump, with so many thing that can go wrong in it. Phil can tell us a bit more about it, remember when his unit looked up. No wonder why this aluminum nightmare was replaced a few years later. Edited by hemidenis 2013-06-01 10:48 PM (image.jpg) Attachments ---------------- image.jpg (87KB - 194 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | New bearing and home made gaskets, the bushing on the back is in perfect shape. (image.jpg) (image.jpg) Attachments ---------------- image.jpg (64KB - 189 downloads) image.jpg (75KB - 190 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | This is the final result, I'm pretty sure is the right color combo, at least is the one showing in the shops manuals. Sad Chrysler never added a colorful decal on it. Edited by hemidenis 2013-06-01 9:51 PM (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (73KB - 184 downloads) image.jpg (67KB - 195 downloads) image.jpg (68KB - 191 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Trans adapter and torque converter housing. During blasting and the end result. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (100KB - 181 downloads) image.jpg (135KB - 188 downloads) image.jpg (124KB - 189 downloads) image.jpg (73KB - 180 downloads) image.jpg (74KB - 187 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Finally the hemi elephant is out of storage. (image.jpg) Attachments ---------------- image.jpg (71KB - 194 downloads) | ||
Phil_the_frenchie |
Elite Veteran Posts: 915 Location: Pau, S-W France | hemidenis - 2013-06-02 3:37 AM Phil can tell us a bit more about it, remember when his unit looked up. Ah, i remember this day, it was in july 2006 when i slow down to leave the highway !!! Suddenly no power assist, a lot of smoke from under the hood and this odor of burnt rubber !!! The rotor locked in the bore because there was a very tiny piece of metal and ruined the pump !!! Fortunately i had a spare but i need a trailer, i coudn't go home (40 miles) without belts (i had spare belts but i can't use them) which drive also the water pump. Here is the thread http://www.forwardlook.net/forums/forums/thread-view.asp?tid=11168&... Since that i bought another spare unit !!!! And yes you need a "special tool" to install the small tubes ... As i didn't have it (it was a long time ago, 1995 maybe), i used a lot of .... flat washers which gave me the correct height for each tube. Each tube needs different height, so 5, 8, 10 washers, etc ... The only requirement is that the washer must have just a smaller diameter than the tube bore ! Edited by Phil_the_frenchie 2013-06-04 5:26 PM | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Phil shows a decal on his unit. Not hijacking your thread, but the 57's have the Saginaw P/S pump; are there any obvious advantages of the Thompson guy over Mr. Saginaw? | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Your work is amazing! | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | thank guys, Phil is that decal location accurate? | ||
Phil_the_frenchie |
Elite Veteran Posts: 915 Location: Pau, S-W France | About the decal, it was in the set i bought (from Gary Goers i think) and i can't see any other location because it's a warning message so must be closer to the filling hole. About pump i always see Thomson on Imperial and Chrysler. And Vickers on other '57 mopar. My '57 manual says: pump 1733 496 (Thomson) : C75, C76 ,IMP pump 1672 697: P30, D64, D72 pump 1733 496: D67 Can. built pump 1672 610; D66 /70 /71, D67 (US), S27 pump (Vickers) 1826 158 : D66 /70 /71, D67 (US), S 25 / 26 / 27 pump 1730892 : S 25/ 26 | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | I spent all week working in my other project, this week will be time of the steering box, rear end and brake lines. | ||
Doctor DeSoto |
Location: Parts Unknown | Denis, You didn't happen to lead a Navy Seal team on a small mission in Pakistan about 2 years ago, did you ? This kind of precision work in a mess of dirt and chaos is very impressive. Please allow me to tap on your shoulder when I decide to dive in to some of these jobs I usually have others do. | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | In Argentina, they're known as Sea Lions. | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | I always enjoy read your post guys! Is always a pleasure to see when others members appreciate my hard work and push me to make the quality even better! Doc, I trustfully admire your guts to be in the sandbox for this long. Hopping that my work make your day a bit better !! | ||
Doctor DeSoto |
Location: Parts Unknown | It certainly does. A nice distraction to the daily grind. I am on the disabled list right now, so the days are real L O N G ! | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | I just finished all the brake lanes, I know that someone make the comment about copper lines, but is the only think I could find. I used AC type lines in which walls are thicker than regulars. I also re-use the springs shields. Doc, I'm working in a surprise for you, I hope it will be completed over the weekend. Disabled? It's a problem with your thumbs? I heard that 50 cal is really soft to push, I don't see any problem there (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (115KB - 188 downloads) image.jpg (121KB - 186 downloads) image.jpg (112KB - 175 downloads) image.jpg (111KB - 177 downloads) image.jpg (118KB - 183 downloads) image.jpg (115KB - 193 downloads) | ||
Doctor DeSoto |
Location: Parts Unknown | The closest I get to a 50 is having helped with set up or take down. They are not a small or light weapon ! So, ... were your brake lines rusted away ? I have only needed to replace the VERY occasional brake line, due to sand/mud getting trapped behind one and rusting it out. At least in my part of the world, brake lines typically hold up forever. | ||
ToMopar |
Elite Veteran Posts: 1159 Location: D-70199 Heslach | Denis, your front end of frame looks great, for me no problem with the copper brake lines. | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Thanks guys! Doc, my pipes where a bit rusted on the outside, dirty on the inside too. Maybe still good for another 56 years of service but who can tell for sure. Biggest Problem is that both sides where smashed by the upper arm suspension (due to a missing bumper stop) making the arm squeeze the brake line against the frame. It is hard too see on the pictures the magnitude of the encounter but the spiral dented the frame! Talking about maintenance of the front end.... Who chek that rubber bumper? Well this could happen, believe or not. (image.jpg) (image.jpg) Attachments ---------------- image.jpg (118KB - 198 downloads) image.jpg (146KB - 190 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Power steering time...... All aluminum unit, it was over sprayed on black on the outside. Just the part exposed to the engine bay. (image.jpg) Attachments ---------------- image.jpg (111KB - 182 downloads) | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Took 12 ton of pressure to release Pittman arm of the PS shaft..... | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Slow progress due to the long bad weather, the steering is just waiting for the restoration, but in the meantime I just finished the differential carrier assy with new bearings and seal. An important side note is that the differential cups listed on Timken website for 1957 imperial is not correct. The correct number is 25522. Tomorrow will be the time to complete the axle with differential axle and brakes. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (105KB - 209 downloads) image.jpg (96KB - 209 downloads) image.jpg (79KB - 214 downloads) image.jpg (89KB - 185 downloads) image.jpg (101KB - 200 downloads) | ||
57desoto |
Expert Posts: 1488 Location: New Castle PA | Absolutely astounding work! I would never tackle those rebuilds the way you did -- you're my hero! | ||
