rod knock in my 241 hemi Jump to page : 1 2 3 4 5 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | In '53-4 there was no Mouse Motor! | ||
ttotired |
Expert 5K+ Posts: 8445 Location: Perth Australia | For my 318 poly (cheaper than a hemi) it cost me just under $3000 Now before you faint here is the breakdown Bore and hone cylinders (30 TH) Re grind Cam Rebuild both heads to suit ULP/LPG Re grind crankshaft (10 TH) Re face lifters Re face rockers Weld and machine intake manifold. With your rods, you really need to check the roundness (is that a word?) of the big ends, to do this, you need an inside micrometer. You have to put the cap on the rod and torque the nuts tight, then you can measure, your basically looking for out of round. If the big end is out of round, I am afraid its going to be head (s no point just doing one) off. This is still not that bad provided the heads were/are ok, just wrap them up and put them asside. Unless you really are trying to make it go faster, just rebuild it as stock as you can (cam it a bit if you want), But if the pistons and rings ect are good and your on a budget, then why mess with them (although if the pistons come out, I would fit new rings) I would expect about maybe 300? for a crank grind, but not sure as I got a lot of stuff done | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | ttotired - 2013-06-10 6:54 PM I've noticed prices of things in Oz is higher than up here!For my 318 poly (cheaper than a hemi) it cost me just under $3000 Now before you faint here is the breakdown Bore and hone cylinders (30 TH) Re grind Cam Rebuild both heads to suit ULP/LPG Re grind crankshaft (10 TH) Re face lifters Re face rockers Weld and machine intake manifold. With your rods, you really need to check the roundness (is that a word?) of the big ends, to do this, you need an inside micrometer. You have to put the cap on the rod and torque the nuts tight, then you can measure, your basically looking for out of round. If the big end is out of round, I am afraid its going to be head (s no point just doing one) off. This is still not that bad provided the heads were/are ok, just wrap them up and put them asside. Unless you really are trying to make it go faster, just rebuild it as stock as you can (cam it a bit if you want), But if the pistons and rings ect are good and your on a budget, then why mess with them (although if the pistons come out, I would fit new rings) I would expect about maybe 300? for a crank grind, but not sure as I got a lot of stuff done | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Mopar1 - 2013-06-10 2:02 PM dodge59 - 2013-06-10 12:06 PM Yeah, nothing is cheap about these engines. QEC is "Wayfarer" here, PM him, and he's "73RR" on the HAMB, could try PMing him there. There's a place in Jacksonville, Fla that has a lot of new hemi stuff on EBay, could look them up & see what they think of there stuff. The cheap way of doing it is dropping in a 318LA/904 and a modern axle. :)who else might carry these high compression pistons for the 241 hemi everyone is talking about ? hot hemiheads wants $800+ ............ and QEC won't answer there phones. Thanks ! mopar1 I'll trying another way to get a hold of qec . I would never put a newer 318 in my old dodge . I love originality and hemis of course . . Edited by dodge59 2013-06-10 10:53 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update on the hemi took 4 hours to tear the hemi down today.. cylinder walls look great with very tiny amount of wear ..very little ridge . .. sure doesn't look like 70k miles. put sure was slugged up though.... couple other rod bearings had a scrape line in them from something .. .main bearings look great. C&S performance in butler wi. here is going to work with me on everything to lower the costs. They will do all the machine work it needs and the cleaning of the block ,heads and all the other items . I will reassemble it . they are the best shop here in the milwauke area . they have a very good reputation.. They did another hemi 392 for me a few years ago with no issues . Edited by dodge59 2013-06-10 11:11 PM (hemi bare 40%.JPG) Attachments ---------------- hemi bare 40%.JPG (184KB - 259 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | the 241 hemi is at the machine shop. still debating upon those high compression pistons for the hemi.. do you guys know if they would bolt right in without different rods? I heard they will. those would probally ad 50 HP . | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-06-11 9:16 PM Rods should be strong enough.the 241 hemi is at the machine shop. still debating upon those high compression pistons for the hemi.. do you guys know if they would bolt right in without different rods? I heard they will. those would probally ad 50 HP . | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update from machine shop....... most of the hemi parts are cleaned . few pics of the heads appears that the crank mains are .030 under already.. someone has been in the old hemi before. Edited by dodge59 2013-06-14 11:12 PM (heads cleaned III 30%.JPG) (heads cleaned II 30%.JPG) Attachments ---------------- heads cleaned III 30%.JPG (42KB - 214 downloads) heads cleaned II 30%.JPG (39KB - 176 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | machine shop miced up the crank and rods.......... it will need .040 under bearings on crank mains and rod bearings . definetly somone has been in this hemi before. ... these 241 hemis were know for there bad bearings .. I remember my pa buying these old dodge hemi cars and replacing the bearing in them and reselling them when I was a youngster. . | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | John, the 9.0:1 pistons would be high-er c.r. than your OEM's, but they wouldn't really be HIGH compression slugs, except in 53-55. Balance the crank, which your shop will do, I'm sure, port the gaskets, and install tubular adjustable pushrods (thru Hot Heads), and get the cam re-ground, and put in 9.0 pistons and twin pipes and you're good to GO (headers if you really get motivated)....and oh yeah, get the distributor re-curved so that it can control, and not restrict, the application all of that new HP.... | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | more info on the hemi machinest miced the cyl bores today and it is .030 over .. also two piston skirts are worn and rings are sloppy . so far crank mains and rods need .040 bearings and now the cyl bore .040.. now need new pistons and rings too. .040 I new this was going to happen when they opened it up and started micing things up. the old hemi has been put thru the mill . she is worn out big time . but it ran like a swiss watch . go figure . now wondering if this hemi really had 70K on it or someone shoved another used 241 hemi in it over the past 60 years . guess anything is possible. john | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | here are the 241 hemi Ross high compression piston that are available for $800 + rigs . almost a grand.. just can't afford them . with milling the block and heads to clean the mating surfaces up, it may bump the CP up a tiny bit. That's fine. Edited by dodge59 2013-06-20 11:34 AM (241 hemi HP pistons.jpg) Attachments ---------------- 241 hemi HP pistons.jpg (9KB - 204 downloads) | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Don't mill the heads/block unless you have to, & then as little as possible. Don't want to mess with valve train geometry. The pistons are how you adjust C/R. | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | George is correct; let me do a little bit of piston/rod research, & we can PM about it... | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | I don't think the machine shop is going to make any drastic just on the heads or block .. I don't want to be changing all that rocker gear geometry like you guys mentioned. buying different length pushrods and all. going to stay with the stock compression pistons too ......... No high domes .........too much $$ Edited by dodge59 2013-06-20 10:13 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | here is a couple pics of my 241 hemi head gasket that I removed f .. it's .060 thick. also as you can see they have some brass rings around water jackets .. That's good also look at all the blow by between the cylinders (Black) apparently this gasket was not sealing properly. these gaskets are stamped VIC 2 with part number HR 632545 metal on both side with some type of gasket material in between . do these head gaskets appear to be a stock gasket or later aftermarket? john Edited by dodge59 2013-06-27 5:29 PM (my head gasket top side 40%.JPG) (my head gasket bottom side 40%.JPG) Attachments ---------------- my head gasket top side 40%.JPG (150KB - 157 downloads) my head gasket bottom side 40%.JPG (153KB - 183 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update . won't be decking the block because machine shop does not have a small enough tool that fits in the journals to secure the block in the machine. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | also going to use mopar 1966 and older lifters becuase they are half expensive. 1966 and older mopar engines used 1/4" pushrod tips like the hemis did back then. | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-06-28 6:47 PM I've used the 361/413 lifters in my Chrs, the groove isn't an exact match, but they work.also going to use mopar 1966 and older lifters becuase they are half expensive. 1966 and older mopar engines used 1/4" pushrod tips like the hemis did back then. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update ................. all my engine parts will be here next week so the machine shop is going to do the final hone on the cyl bores (.040 bore) when they arrive for one last fit ,, then line bore . valves will be here so the valve job can be finished ... still debating if I should use a valve seal on the intake valves. this 241 never came with valve seals . this engine has double springs so maybe there just isn't enough room for it to have valve seals. what are your opinions on the oil seals ??? yes or no? cam is being reground and will be finished next week also.. decided to step up the cam one size larger . these baby hemi engines had such small cams .. when the machine shop is finished with everything , I get it all back and start assembling it.. | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | It's supposed to have intake seals, no ex seals | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Mopar1 - 2013-07-06 9:50 AM It's supposed to have intake seals, no ex seals were the 1954 hemis suppose to have intake valve seals from the factory ?? I thought I remember reading articles saying the 1954 redram did no valve seals . period . | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | let me run this by you guys ......... upon reassembling the 241 hemi ... there is a 12"vent tube that is in the oil pan and runs along the crankshaft for venting vapors and pressure in the crankcse area.. the foot long tube exits a hole on the rear of the engine block next to the rear main cap .. it makes a mess inside the bellhousing area with oil and condensation from inside the oil pan.. I think I am going to plug that hole with a screw in plug and eliminate the vent tube all together . your opinions please.. I really don't think it is really neccessary . (hemi crank case vent tube pipe 40%.JPG) Attachments ---------------- hemi crank case vent tube pipe 40%.JPG (230KB - 536 downloads) | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-07-06 9:19 PM I'm under the impression that all of the hemis had intake seals & no ex seals. IF you have that in writting from the OEM or other relaiable source, I'll accept it, but it doesn't sound like a good idea. No ex seals because oil can't run up the ex valves, but the intake side is no different than any other engine. but then all my expierience is with Chrs, not Dodges. Someone mentioned no room for seals on the '54, any evidence of smaller valve spring pockets on them?Mopar1 - 2013-07-06 9:50 AM It's supposed to have intake seals, no ex seals were the 1954 hemis suppose to have intake valve seals from the factory ?? I thought I remember reading articles saying the 1954 redram did no valve seals . period . | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-07-06 9:37 PM NOOOOO!!!!! The engine has to breath! Air has to get in & out or you'll be blowing gaskets, or oil out the dipstick tube. The best way to solve the mess is to install a PCV valve in the hole where the tube bolts on(with the valve shielded) & figure out how to plumb it into your carb base if you can't put a modern carb on it that has a PCV port.let me run this by you guys ......... upon reassembling the 241 hemi ... there is a 12"vent tube that is in the oil pan and runs along the crankshaft for venting vapors and pressure in the crankcse area.. the foot long tube exits a hole on the rear of the engine block next to the rear main cap .. it makes a mess inside the bellhousing area with oil and condensation from inside the oil pan.. I think I am going to plug that hole with a screw in plug and eliminate the vent tube all together . your opinions please.. I really don't think it is really neccessary . | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | You could block off that one IF you move it somewhere else. The Chrs have them in the rear of the Valley cover. You might modify your's to there, or maybe a PCV fitting on a valve cover. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | mopar1 maybe second thought ......... I'll just leave the tube in the crankcase and pick up hotheads pcv conversion kit that fits in the rear of the valley pan where the old down draft tube is.. once there is suction there from the carbs pvc in the valley pan , it won't be pushing all the vapors and oil condensation junk into the bellhousing . | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-07-07 10:59 AM I have no expierience with Dodge hemis, but if you have the draft tube @ the back of the valley cover & this other seperate one down in the pan area, you'd want to seal off the pan one so no unfiltered air is drawn in through it. You want air coming in through a filtered source, witch should be the oil fill cap.mopar1 maybe second thought ......... I'll just leave the tube in the crankcase and pick up hotheads pcv conversion kit that fits in the rear of the valley pan where the old down draft tube is.. once there is suction there from the carbs pvc in the valley pan , it won't be pushing all the vapors and oil condensation junk into the bellhousing . | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update new stock oem pistons & rings came in . one thing different >> the reliefs are larger on the new pistons.. probally made for an option to install larger valves.. but my compression is going to drop some more now. so much for original cast pistons ! Edited by dodge59 2013-07-09 5:06 PM (new hemi pistons 40%.JPG) Attachments ---------------- new hemi pistons 40%.JPG (170KB - 934 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Mopar1 - 2013-07-07 11:17 AM dodge59 - 2013-07-07 10:59 AM I have no expierience with Dodge hemis, but if you have the draft tube @ the back of the valley cover & this other seperate one down in the pan area, you'd want to seal off the pan one so no unfiltered air is drawn in through it. You want air coming in through a filtered source, witch should be the oil fill cap.mopar1 maybe second thought ......... I'll just leave the tube in the crankcase and pick up hotheads pcv conversion kit that fits in the rear of the valley pan where the old down draft tube is.. once there is suction there from the carbs pvc in the valley pan , it won't be pushing all the vapors and oil condensation junk into the bellhousing . ordered up hotheads pvc conversion kit for the 241redram ... seemed to work great on my last hemi 392 . I'll just plug the hole in the block crankcase where the vent tube was. Edited by dodge59 2013-07-09 5:13 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update on241 hemi rebuild machine shop just squared the block up .. had to deck the block .020 on both sides of the block . appears the block deck was off by .020 on each end. that means the pistons will now stick out of the block .015-.020 . Well , I got my compression back now and then some. new head gasket is .050 thick. looks like we are safe still. now the block is true and even on both sides. back in 1954 .......... they did some crazy machine work .. went to install the new egge oil pump kit and the drive gear shaft is a 1/4" shorter than the old one. checking into that issue as we speek. Edited by dodge59 2013-07-10 6:22 PM | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | OK, John; here's some eye candy for your thread. First pic shows the 315/325 engine with the crankcase breather tube mounting to the top-rear of the engine. Next pic shows a factory illustration showing the 54 engine with the breather tube exiting like it does on the later engines (right by the air-cooled trannie grille...and yeah; that breather tube's excrement will get all over the undercarriage). Next photo is an 8x10" factory print of your engine, without the breather tube being installed on it. Next pics are from my 1954 file, showing the 5/54 Hot Rod article, which should be of interest to you. I'll go dig out that issue and PM you with some readable PDF-scans of its pages. (PICT1902.JPG) (PICT1903.JPG) (PICT1904.JPG) (PICT1905.JPG) (PICT1906.JPG) (PICT1907.JPG) (PICT1908.JPG) (PICT1909.JPG) (PICT1910.JPG) (PICT1911.JPG) (PICT1912.JPG) (PICT1913.JPG) (PICT1914.JPG) Attachments ---------------- PICT1902.JPG (106KB - 217 downloads) PICT1903.JPG (105KB - 178 downloads) PICT1904.JPG (95KB - 193 downloads) PICT1905.JPG (60KB - 169 downloads) PICT1906.JPG (68KB - 142 downloads) PICT1907.JPG (76KB - 155 downloads) PICT1908.JPG (64KB - 150 downloads) PICT1909.JPG (117KB - 149 downloads) PICT1910.JPG (59KB - 159 downloads) PICT1911.JPG (74KB - 160 downloads) PICT1912.JPG (70KB - 135 downloads) PICT1913.JPG (69KB - 155 downloads) PICT1914.JPG (122KB - 182 downloads) | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-07-10 5:18 PM What is in the oil pump kit, & why are you replacing the shaft?update on241 hemi rebuild machine shop just squared the block up .. had to deck the block .020 on both sides of the block . appears the block deck was off by .020 on each end. that means the pistons will now stick out of the block .015-.020 . Well , I got my compression back now and then some. new head gasket is .050 thick. looks like we are safe still. now the block is true and even on both sides. back in 1954 .......... they did some crazy machine work .. went to install the new egge oil pump kit and the drive gear shaft is a 1/4" shorter than the old one. checking into that issue as we speek. | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | dodge59 - 2013-07-10 5:18 PM Early Hemis have a rep for good machine work, but there's always some tolerances that can get off.update on241 hemi rebuild machine shop just squared the block up .. had to deck the block .020 on both sides of the block . appears the block deck was off by .020 on each end. that means the pistons will now stick out of the block .015-.020 . Well , I got my compression back now and then some. new head gasket is .050 thick. looks like we are safe still. now the block is true and even on both sides. back in 1954 .......... they did some crazy machine work .. went to install the new egge oil pump kit and the drive gear shaft is a 1/4" shorter than the old one. checking into that issue as we speek. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Mopar1 - 2013-07-12 4:19 PM dodge59 - 2013-07-10 5:18 PM What is in the oil pump kit, & why are you replacing the shaft?update on241 hemi rebuild machine shop just squared the block up .. had to deck the block .020 on both sides of the block . appears the block deck was off by .020 on each end. that means the pistons will now stick out of the block .015-.020 . Well , I got my compression back now and then some. new head gasket is .050 thick. looks like we are safe still. now the block is true and even on both sides. back in 1954 .......... they did some crazy machine work .. went to install the new egge oil pump kit and the drive gear shaft is a 1/4" shorter than the old one. checking into that issue as we speek. mopar1 talked to egge today .. they say they put the wrong kit in the package to me.. the oil pump kit comsists of 3- rubber O- rings 2 small and 1 large....... the shaft and the round dooo giggy it rotates in and a new spring. hope I get the correct shaft now. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | d500neil - 2013-07-12 4:10 PM OK, John; here's some eye candy for your thread. First pic shows the 315/325 engine with the crankcase breather tube mounting to the top-rear of the engine. Next pic shows a factory illustration showing the 54 engine with the breather tube exiting like it does on the later engines (right by the air-cooled trannie grille...and yeah; that breather tube's excrement will get all over the undercarriage). Next photo is an 8x10" factory print of your engine, without the breather tube being installed on it. Next pics are from my 1954 file, showing the 5/54 Hot Rod article, which should be of interest to you. I'll go dig out that issue and PM you with some readable PDF-scans of its pages. thanks Neil is the magazine article available to buy somewhere.. sureis some goodinfo thre. also neil .. they talked about installing a length of tubing over the vac diaphram linkage .. what is that all about? is that so it locks it out and will not have any vac advance then? Edited by dodge59 2013-07-12 7:27 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | update on the hemi rebuild maching shop says today ............. one of the rod journals has been welded up previously and feels I should find another crank.. to be safe and all. anyone out there have a good crank that is not cracked , welded up and still has some meat to it? I have two other people close by milwaukee wi that I am waiting to talk to. they might have one.. just covering all my bases on locating one for now. geeee .. I just can't see how supposeablly a 70K engine could of had all the work done do it before . now the crank . Edited by dodge59 2013-07-12 7:34 PM | ||
Shep |
Expert Posts: 3402 Location: Chestertown, NY ( near Lake George) | Due respect here but I would look at that crank first hand. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | shep I did look at the crank today and you can see around the border edges in the journal that it has been welded. looks totaly different at the outside border of the journals ........... than the other journals . | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | d500neil - 2013-07-12 4:10 PM OK, John; here's some eye candy for your thread. First pic shows the 315/325 engine with the crankcase breather tube mounting to the top-rear of the engine. Next pic shows a factory illustration showing the 54 engine with the breather tube exiting like it does on the later engines (right by the air-cooled trannie grille...and yeah; that breather tube's excrement will get all over the undercarriage). Next photo is an 8x10" factory print of your engine, without the breather tube being installed on it. Next pics are from my 1954 file, showing the 5/54 Hot Rod article, which should be of interest to you. I'll go dig out that issue and PM you with some readable PDF-scans of its pages. Neil Thanks for the hotrod article /pics ............ I recieved the personal meassage with them . sure do appreciated the info. john Edited by dodge59 2013-07-13 12:14 AM | ||
jimntempe |
Expert Posts: 2312 Location: Arizona | dodge59 - 2013-07-12 4:32 PM update on the hemi rebuild maching shop says today ............. one of the rod journals has been welded up previously and feels I should find another crank.. to be safe and all. anyone out there have a good crank that is not cracked , welded up and still has some meat to it? I have two other people close by milwaukee wi that I am waiting to talk to. they might have one.. just covering all my bases on locating one for now. geeee .. I just can't see how supposeablly a 70K engine could of had all the work done do it before . now the crank .
When I consider how many cars seem to go over 100K with zero problems, I mean even back in the "day", combined with the notorious amount of odometer rollbacks dealers used to do, I firmly believe that a vast number of cars people complained about not holding up were in fact cars they bought used with tons of miles rolled off the odometer. A real 80K car that's been cared for, and that was driven a lot in a relatively short time, will still look new and it's easy to detail it and roll it back to 40K and resell it, might even be able to do it a second time so that when it starts coughing when it reads 100K it's actually at 180K. My dad drove his 60 Matador to around 110K and never even changed the transmission fluid and it was still running, engine good, transmission about due for some work! | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | In racing applications the 241 were known for not having great crankshafts, usually agrivated by the lack of an OEM installed damper. Edited by Mopar1 2013-07-13 10:05 AM | ||
wbower3 |
Walter passed away on Jul 29, 2014. We will miss you, Walt! Posts: 5358 Location: Heaven Above (Formerly Oklahoma City,OK) | Many a "stroker" engine was built back in the 50's - 60's with welded crankshafts. I have a Kawasaki 900 motorcycle engine that has one welded connecting rod journal. Couldn't wait for a new crankshaft and had it welded, reground the one journal, had it straightened, nitrided, and put about 100 hours on the engine on the race track in a race car! | ||
MOPAR-TO-YA |
Expert 5K+ Posts: 5139 Location: cornpatch county, Southwest IOA | Something you may want to consider---When I did my 354 Hemi, the machine shop did not want to guarantee anything that they did not assemble themselves. So I let them assemble the short-block, and I did the rest. However, I checked their work and found that their cam timeing was WAY off. They did not know that Mopar Hemi is not timed the same as a Chebby!.........................Good Luck............................MO | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | ...See page 15 of the 5/54 Hot Rod, above. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | here is another wcfb carb I have been working on .. total rebuild 2443sa .. 1956 d500 factory carb that will go on the 241 hemi when I have a few hundred miles on her..... everything taken apart and restored. here are the before and after pics. I down sized the jetting in the carb to accomodate the 241 hemi difference. you wouldn't believe the hours I have in this wcfb carb restoring it. can't wait to try it on the old hemi . Edited by dodge59 2013-07-14 7:38 PM (2443 oem 40%.JPG) (2443 all rebuilt 40%.JPG) Attachments ---------------- 2443 oem 40%.JPG (175KB - 227 downloads) 2443 all rebuilt 40%.JPG (143KB - 194 downloads) | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Looks like after & before! :-) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Mopar1 - 2013-07-14 12:29 PM Looks like after & before! :-)[/QUOTe) sorry about that mopar1 ! pics are in order now. . | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | That's good news, for sure; but you're gonna need a re-ground camshaft: http://www.qualityengineeredcomponents.com/ and, per my first post on page 1 of your thread, you're going to need to have your distributor be modified, in order to get the full benefit of that D500 carb's CFM. BTW, you can seal up both ends of it, and polish the carb to a shine like that of its spring-bracket. Then, you can clear coat it with something like this, to preserve its shiny-ness.. A little chromed paper-filter air cleaner would look bitchin sitting on your D500 carb, too. Edited by d500neil 2013-07-14 8:00 PM (PICT1979.JPG) Attachments ---------------- PICT1979.JPG (58KB - 162 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | d500neil - 2013-07-14 6:46 PM That's good news, for sure; but you're gonna need a re-ground camshaft: http://www.qualityengineeredcomponents.com/ and, per my first post on page 1 of your thread, you're going to need to have your distributor be modified, in order to get the full benefit of that D500 carb's CFM. hi neil yeah.................. chris neilson cams is regrinding the camshaff one size up . will be done this week . After I get the 241 up and running and broke in , I'll work over that distributor.... I just don't want to do too many changes here at once.. have to get her running first and then make the changes later. This hemi engine is going to run SWEET ! | ||
