Location: Muskego, WI | Does anybody know where to purchase a new front engine mount for a 1955 Dodge truck with 241 Hemi? There is one rubber cushion block between the bottom of the water pump housing and the stamped metal "horseshoe" mount bracket that extends down to the frame rails. I have know I idea where to get one. |
Location: N.W. Fla. | I'd go to a NAPA & look through their catalogs of those & see what matches up |
Location: Muskego, WI | Will this engine mount work for a truck?
http://www.ebay.com/itm/Front-Motor-Mount-53-54-55-Dodge-Cars-V8-19... |
Location: N.W. Fla. | I would assume so, the blocks are the same, & I'd guess the block to pad would be also. |
Location: Wales, Wisconsin | Not sure if you ever tried this site but it is for your truck. Kind of like Forward look but for the cars and trucks just prior to them. Nice guys there.
http://mopar.pairserver.com/p15d24ph_forum/page/index.html |
Location: Muskego, WI | I'm a member of that forum as well, mostly for flathead stuff. The mounts are pretty reasonable, I'm going to buy one and "learn the hard way", but I can share the results with everyone else. |
