1961 Dodge wheel covers
plymouth
Posted 2013-09-01 8:15 PM (#394784)
Subject: 1961 Dodge wheel covers
20001001002525
my 1961 Dodge Polara has full wheel covers but there are some differences between the wheel covers on the car. one cover has the regular teeth to hold on to the rim. the other three do not have the teeth. does anyone have an explanation why they're designed differently? the ones without the teeth do not seem to want to stay on well.
Posted 2013-09-02 12:30 PM (#394857 - in reply to #394784)
Subject: RE: 1961 Dodge wheel covers
50002000100100
Can you post some pics of them? I have found that there are 2 different types used on 1960 Chrysler as well, each designed for a different rim, like these ones. I found the ones with the teeth would rotate around the rim and bind the valve stem, as they weren't the correct ones for my rims. Now I have wire wheels so the problem is not an issue but I had a mix of them on the car prior to the wire wheels. The ones with the dimples on the edge are the correct ones for my rims, and the rims have corresponding raised bumps where the dimples seat onto. Otherwise the 2 types of wheel covers look identical from the front side.
Christian, if your wheel cover types are like this, then I expect your rims were designed for the "toothy flanged" type, not the dimpled type to hold them on.
Edited by imopar380 2013-09-02 12:37 PM
(60_covers_2.jpg)
(60_covers_3.jpg)
Attachments 60_covers_2.jpg (90KB - 27 downloads)
Attachments 60_covers_3.jpg (92KB - 39 downloads)
plymouth
Posted 2013-09-02 12:35 PM (#394859 - in reply to #394857)
Subject: Re: 1961 Dodge wheel covers
20001001002525
I'll take some pictures later. Thats how my covers are.
