picking a locked glove box door lock NO KEY Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | anyone have any luck picking a glove box lock ? have one in a 54 dodge royal that has no key. Thanks ! Edited by dodge59 2013-12-01 6:50 PM | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | I'm the forum's resident locksmith..... you may need to take it to a locksmith to open it for you - unless you have the correct picking tools it will be hard to do. You need to put tension on the lock towards the way it rotates to unlock, at the same time as you rake the tumblers back and forth with a pick. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | ok ........ I need to know which key opens the glove box lock >> for a 54 dodge royal >>> Is it the ignition /door key , trunk or a separate key all by itself ? I have a whole bunch of keys to try . Thanks Edited by dodge59 2013-12-01 7:28 PM | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | dodge59 - 2013-12-01 4:27 PM ok ........ I need to know which key opens the glove box lock >> for a 54 dodge royal >>> Is it the ignition /door key , trunk or a separate key all by itself ? I have a whole bunch of keys to try . Thanks Normally it would be the trunk key that opens the Glove box. Doors should be keyed the same as the ignition lock. If you have a bunch of keys that will go in the glove box lock, rake them back and forth while maintaining slight turning pressure to the unlock position. Sometimes you can open them that way with the incorrect key if you are lucky, the raking may line up the tumblers in the right spot as you hold the pressure and if so it will open. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Thanks Ian .. I will try that .. I did have a couple keys that did slide into the lock cyl. If that does not work .. I will cut a key down as a bump key.. There may be hope still. Edited by dodge59 2013-12-01 7:50 PM | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | dodge59 - 2013-12-01 4:48 PM Thanks Ian .. I will try that .. I did have a couple keys that did slide into the lock cyl. If that does not work .. I will cut a key down as a bump key.. There may be hope still. I guess you've been looking at YouTube videos on lock picking and bump keys .....your glove compartment lock is a "wafer" locks, not a pin tumbler lock, and wafer locks don't really respond to "bumping" like pin tumbler locks. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | imopar I made a key the way youtube instructed to do and it worked ......It opened. observe the teeth on the key. Edited by dodge59 2013-12-02 5:27 PM (bump key for glove lock 40%.JPG) Attachments ---------------- bump key for glove lock 40%.JPG (171KB - 168 downloads) | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | Well, there ya go. You did it. You're now a qualified locksmith ;-) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | No............. just got lucky. lol | ||
