61 Fury rag Jump to page : < 1 2 3 4 5 6 7 > Now viewing page 5 [50 messages per page] | View previous thread :: View next thread |
fenix |
Expert Posts: 2120 Location: atlanta | Video of what, the top going down?, and what's the cryptic manual trans reference? :-) | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | its chrome and the holes are oblong slits . polish is good for removing any minor rust that starts but wax , like carnuba , will help repel water/oxidation . the first side pipes i had were on a 318 73 charger in 77 . you be goin along at about 55 or so , drop the automatic down one gear , floored and it would sound like an indy racer . these ones are a good deep hot rod sound ---------------------------------later | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | I just like 3 pedals. It's sad with all of Chryslers technology that they didn't build a real standard trans for all of their hot motors back then. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Yes, Dorsey, the 3 on the column is long gone, i would venture to guess few would know how to drive one, certainly not this generation. Anyway, a little progress, installed the rear antenna's and mocked one of the fender skirts. (1-DSCF1711.JPG) (1-DSCF1712.JPG) Attachments ---------------- 1-DSCF1711.JPG (166KB - 186 downloads) 1-DSCF1712.JPG (169KB - 181 downloads) | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | You better sell it soon before you really f...... something up. lol Looking goooood. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Little progress today, insatlled a new universal joint and installed the driveshaft in the car, also mocked up the placement of the side scoops. (1-DSCF1713.JPG) Attachments ---------------- 1-DSCF1713.JPG (154KB - 220 downloads) | ||
w.weiland |
Expert Posts: 1493 Location: Lordstown, Ohio | That kinda will be hard to keep the bugs out of | ||
fenix |
Expert Posts: 2120 Location: atlanta | w.weiland - 2015-05-20 8:31 PM That kinda will be hard to keep the bugs out of Your right, maybe i should turn it around, kinda like thje Pontiac Trans Ams. | ||
Tragic Wagon |
Member Posts: 35 | If you want to get the end carbs to work, progressive linkage for a later mechanical Six Pack setup should work, and is so simple you could duplicate it yourself. As long as all three carbs have accelerator pump, it works great. Super Stock Six Pack carbs had 3 accelerator pumps and no vacuum actuation. I drove a setup like that one the street, daily, in the mid-'90s in Atlanta. I loved it. I had about 1/2 travel on the center carb before the outers would open. Once your foot "learns" it, it's awesome! | ||
The Chrysler Kid |
Expert Posts: 1384 Location: Ocala, Florida | Looking good! Hope to see it in person one day! | ||
fenix |
Expert Posts: 2120 Location: atlanta | Tragic Wagon - 2015-05-20 8:53 PM If you want to get the end carbs to work, progressive linkage for a later mechanical Six Pack setup should work, and is so simple you could duplicate it yourself. As long as all three carbs have accelerator pump, it works great. Super Stock Six Pack carbs had 3 accelerator pumps and no vacuum actuation. I drove a setup like that one the street, daily, in the mid-'90s in Atlanta. I loved it. I had about 1/2 travel on the center carb before the outers would open. Once your foot "learns" it, it's awesome! I actually had the Weiand tunnel ram 6 pack with three 2300 Holley's, the were all mech, no vac, except the center. I had a .060 440 in a 71 Demon, but alas someone made me an offer I couldn't refuse. the three 2300's with vac pods are for stock street motors, ala the one year only AAR/T/A, and the BB 5 packs, These are Holley ECG-5s are 1 1/16 throats, the biggest available other than the 2110 bug sprayers, the end carbs are choke free and the idles blocked, and don't have pumps, the center will support my motor, weakly, and i don't wanna run straight linkage, but, we'll see. | ||
Tragic Wagon |
Member Posts: 35 | Well, without pumps they're almost certain to bog on opening unless it's very, very slow--hence the vacuum pods on the factory Six Pack/Six Barrel setups. You'd have to be pretty judicious with your right foot to make non-pumped end carbs transition well to WOT. I had the Weiand tunnel ram as well, but didn't use it. I put the Super Stock carbs (4791 center/4792 outers, if memory serves, but those may be the 340 S/S carbs) on a factory '69.5 A12 Edelbrock intake instead. Not as much power but more fun on the street, and kept the element of surprise! | ||
sidesho_bob1961 |
Expert Posts: 1728 Location: Fleetwood, Pa | Scoops might work better if you mount them on the roof........flow through ventilation???? | ||
fenix |
Expert Posts: 2120 Location: atlanta | sidesho_bob1961 - 2015-05-21 6:23 AM Scoops might work better if you mount them on the roof........flow through ventilation???? I thought of that, but i thought they might look silly on the roof, and because of the fabric tearing, they may not last long. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Tragic Wagon - 2015-05-20 11:52 PM Well, without pumps they're almost certain to bog on opening unless it's very, very slow--hence the vacuum pods on the factory Six Pack/Six Barrel setups. You'd have to be pretty judicious with your right foot to make non-pumped end carbs transition well to WOT. I had the Weiand tunnel ram as well, but didn't use it. I put the Super Stock carbs (4791 center/4792 outers, if memory serves, but those may be the 340 S/S carbs) on a factory '69.5 A12 Edelbrock intake instead. Not as much power but more fun on the street, and kept the element of surprise! Yep, those numbers sound right, i got my vac pods and accel pumps mixed up, all three had accel pumps and no vac on any, full mech setup, iirc i had to put blocks under them for linkage clearance. These little holleys on the ends are called "dumpers", you can set the linkage to bring them in at a certain percent of the middle carbs linkage position, when there's enough vac/air flow through the venturi to let them work, maybe somewhere around 70 t0 80 %, make sense? OOPS, the ECG's ends do have pumps, don't know what i was thinking. Edited by fenix 2015-05-21 11:31 AM | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | i never liked the throttle side linkage at all on my first first trip setup . you might not want to hear it but the other side works way better and only a few dollars more ----------------------------------------later (finished carbs 004.JPG) Attachments ---------------- finished carbs 004.JPG (133KB - 189 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | That's the fuel line setup i wanna run chuck, whose linkage is that? what carbs are they, Rochester 2G's? A little more progress today, replaced the rear universal joint and installed the driveshaft, install the new battery and ground cables, installed the new swedged battery terminals and covers, ran a new #10 wire with a fusible link from the alt to the the starter relay, installed a fusible link and bypassed the ammeter, removed and replaced the alt and new electronic regulator after having them checked out, and i ain't talking Autozone, i mean a dedicated auto electrical shop with a guy that knows his doodoo. Gonna be real soon for cranking the motor. Edited by fenix 2015-05-21 9:40 PM | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | Whose that knocking in my Block I know its not Mr. Rod But what's the Blue Smoke cumin out my Hole I took My Viagra but I'm feelin Kinda Limp From that knock Knock Knock In My Block | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | carbs are 2g rochester small base . the banjo fuel fittings you can get from speedway @ 60$ . the linkage is offenhauser , can be had from epay @ 80$ ------------------------------------later | ||
fenix |
Expert Posts: 2120 Location: atlanta | oldwood - 2015-05-21 11:11 PM Whose that knocking in my Block I know its not Mr. Rod But what's the Blue Smoke cumin out my Hole I took My Viagra but I'm feelin Kinda Limp From that knock Knock Knock In My Block Dorsey, you sure ya didn't get that Viagra mixed up with something else? by the way Haiku is only three lines, i believe. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Worked on the motor, trying to keep it running for the break in, the new starter started acting up yesterday and was making a hell of a noise, didn't want to mess up the flywheel so called it a day, today we dropped the left header and exhaust, removed the starter, i had another new one here and we compared the bendix movement and determined the starter wasn't extending far enough to engage the flywheel correctly, the new starter solved that problem. I could get the motor to run, but only by priming and filling the fuel bowl, today we took the line loose and had no gas past the regulator, next we filled a container with gas and it sucked some into the pump, but still no gas,i'm thinking bad regulator, removed the input line to the regulator, nothing, went a got a new fuel pump, fixed the problem, tomorrow, re-install the exhaust, and try to break the motor in. Gotta admit the motor sounds pretty good for a ballpark dial in, haven't set the timing or played with the jetting, and the first motor i've built in many moons. The way things are going, i may be cruising by Christmas, and i mean Christmas this year. | ||
196061SAVOY |
User has resigned from board | I found this , thought u might like it Attachments ---------------- 361 Golden Commando Fury Convertible - YouTube.url (0KB - 232 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | Break-in went pretty good, thought i had a temp problem, didn't think the stat was opening, but it tested good on the stove, i think it's a bad temp gauge, it's new, but who knows, no water in the oil, no steam, no oil leaks, no strange noises. Next i have to adjust the valves, set the timing and play with the center carb. Chuck was right the side pipes sound good, mellow as heck. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Good stuff Wheres the movie Took 2 days to get the cam broken in on mine Stupid core plugs kept popping out | ||
fenix |
Expert Posts: 2120 Location: atlanta | Film at 11:00 Mick, was going to make a video today, but my two topless female assistants weren't down for it! :-). these core plugs seem to be holding so far. by the way, here's how i by-passed the fire starter (ammeter), dual field 60 amp alt, I ran a 10G wire from the output lug of the alt, with a 14G fusible link at the starter relay lug, the field wire remains the same, the second field wire is grounded. A 12G wire from the alt to the headlight switch power lug with a fusible link at the switch end. The 12G original power in to the ammeter from the starter relay lug is disconnected from the ammeter and a fusible link installed and runs to the tie point for all the rest of the circuits and as a return for battery power if the alt is not engaged. | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | Guess what show I seen this '61 fury convertible on | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | Guess what show I seen this '61 fury convertible on (WP_20150601_002.jpg) Attachments ---------------- WP_20150601_002.jpg (181KB - 172 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | Don't know Steph, but I wish i was in it! | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | The last bit has got me a bit It sounds like you have 2 supplies going to the headlight switch? The alternator should have B+ all the time (not like the generator), so there is no need to have a wire to cover if the alternator is not working If you have 2 supplies going to the same place, each with its own fuse, you can basically add the 2 fuses together and come up with what the circuit is fused at, as an example, 2 wires, each with a 20 amp fuse coming from the same place and going to the same place will be a 40 amp circuit (before anyone goes nuts about some stupid long formula to get an exact current rating, this is an indication and an advice not to have a double supply) | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | Crime Story I have the complete series on DVD. | ||
fenix |
Expert Posts: 2120 Location: atlanta | OK, here's a friend of mine holding the carb for the second break in session, man is he anal about this car! sometimes i wonder who's car it is. :-) http://youtu.be/u03pTVa15kE Edited by fenix 2015-06-01 10:05 PM | ||
Tragic Wagon |
Member Posts: 35 | Sadness. (private.jpg) Attachments ---------------- private.jpg (19KB - 167 downloads) | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | I believe that is yours. | ||
Expert 5K+ Posts: 9675 Location: So. Cal | Are you selling your car Fenix? I didn't expect to see it here. Is everything OK? http://www.ebay.com/itm/121713305234 | ||
fenix |
Expert Posts: 2120 Location: atlanta | fenders on, hood install mocked up, front frame rail end fixed, bumper center and drivers side section installed and mocked up on car, 75% of the trim is ready for pick up at the polishers, including the grill, 3 brand new Holley 94's, one Edelbrock and two "bully 94" dumpers, new hoses and lift cylinders for the top which now works. (2-DSCF2048.JPG) (3-DSCF2049.JPG) Attachments ---------------- 2-DSCF2048.JPG (115KB - 178 downloads) 3-DSCF2049.JPG (140KB - 170 downloads) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Does this mean your back in the game Roger (hope so) Did you do the frame repair? Not that hard to straighten out, is it? (mine wasnt anyway) Good to see your at it again | ||
fenix |
Expert Posts: 2120 Location: atlanta | Yes Mick, looks like I'm at it again, tried to sell it, tried to trade it, nobody wants a project unless it's free, or almost free. I didn't personally do the repair on the frame, I don't have the equipment, and probably the skills either. The guys did a great job, measured it six ways from Sunday before welding anything permanently. I now have a new problem, the column shifter has no spring tension when shifting out of 1st to find neutral, it's a hard place to access to see exactly what's going on in here. | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | Glad to see you are not giving up. Your not too far from being finished | ||
fenix |
Expert Posts: 2120 Location: atlanta | Picked up some trim pieces and dropped off more at the polishers, all came out great, especially like the grill. (1-DSCF2050.JPG) (5-DSCF2054.JPG) (6-DSCF2055.JPG) Attachments ---------------- 1-DSCF2050.JPG (166KB - 162 downloads) 5-DSCF2054.JPG (200KB - 166 downloads) 6-DSCF2055.JPG (189KB - 156 downloads) | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | I cleaned and polished mine myself. all my dad needs to do is repair the dents he did that with my other 1. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Moved the car under it's own power today, been 27 months at least.
oldwood |
Expert Posts: 2905 Location: little rock, AR | Can someone do the hokey pokey and make the you tube come up. Roger, do you have a grill guard??? Difficult part to find, I knew you were eyeing mine on the '60 Ply that I met you with. Don't ask its going on my '61. Edited by oldwood 2015-09-15 11:36 PM | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | I wish I was close to mine being finished. If I had the money I would take to a body shop and have them fix the body and primer it then I would let my dad paint the car. The only 2 body shops I know that is good is Marks auto body and Buckmans in Melbourne, FL. My dad knows the owner of Buckmans auto body. I have a gallon of epoxy primer for the car and some black paint from the other '61 | ||
fenix |
Expert Posts: 2120 Location: atlanta | Yes Dorsey, i do have a grill guard, and that's not what i was eyeing when you were here, I was actually eyeing Your sister !! | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | Shows video as private. I would of love to see the video. Oh by the way watch out for walkers. The show I watch on AMC is filmed were you live | ||
fenix |
Expert Posts: 2120 Location: atlanta | installed the floor shifter. | ||
fenix |
Expert Posts: 2120 Location: atlanta | installing the trim temporarily (1-DSCF2084-002.JPG) (1-DSCF2085.JPG) (1-DSCF2083-001.JPG) Attachments ---------------- 1-DSCF2084-002.JPG (138KB - 160 downloads) 1-DSCF2085.JPG (138KB - 166 downloads) 1-DSCF2083-001.JPG (126KB - 159 downloads) | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | Your just a TEASE. LOL | ||
fenix |
Expert Posts: 2120 Location: atlanta | LOL, not everyone's "cup of tea", but i happen to really like tea. Built by me and for me. Might be on the road around Christmas, not finished, but on the road. | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | NO video it didn't happen. I believe it should have an ARKANSAS License plate. lol | ||
