61 Fury rag Jump to page : < 1 2 3 4 5 6 7 > Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
oldwood |
Expert Posts: 2905 Location: little rock, AR | If you want a little extra HP you might as well Balance the Motor. That 318 will serve you well. | ||
fenix |
Expert Posts: 2120 Location: atlanta | K, back brakes done, and new shocks for the rear on, blasted and painted some engine bay stuff, batt tray, MC brace, radiator support brace. (1-DSCF1372.JPG) (2-DSCF1373.JPG) Attachments ---------------- 1-DSCF1372.JPG (99KB - 179 downloads) 2-DSCF1373.JPG (111KB - 177 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | Got the firewall painted today. (01-DSCF1376.JPG) (02-DSCF1377.JPG) (11-DSCF1386.JPG) (22-DSCF1397.JPG) (20-DSCF1395.JPG) Attachments ---------------- 01-DSCF1376.JPG (160KB - 173 downloads) 02-DSCF1377.JPG (165KB - 176 downloads) 11-DSCF1386.JPG (77KB - 186 downloads) 22-DSCF1397.JPG (129KB - 173 downloads) 20-DSCF1395.JPG (118KB - 187 downloads) | ||
dragula426 |
Veteran Posts: 124 Location: duluth mn. | cool project! looks like a real nice solid car! | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | you're doin good kid ----------------------------------------------------later | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | Its getting there with time and patience it will get done. I will start the restoration on mine this winter. Right now I am enjoying it taking it to a couple of cruise ins , car shows and it will only be in 1 Christmas parade this year. I have found some parts for my car and they are on my watch list on ebay. When I get the cash I hit buy now or bid on the item I want to stock up on spare parts. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Just had the guts to open the new white covertible top I bought off Ebay about a year ago, I didn't expect much for $35.00, but man it's beautimus!, I think with the Baby Blue paint and the blue and white interior and the whitewalls, it'll look better than the black top. A shout out the W. Weiland for the "heads up" on the top on Ebay, Thanks Wayne. Edited by fenix 2014-08-17 1:10 PM (1-DSCF1398.JPG) Attachments ---------------- 1-DSCF1398.JPG (160KB - 167 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | 60 dart - 2014-08-16 11:38 PM you're doin good kid ----------------------------------------------------later :-) Thanks Gramps! :-) | ||
w.weiland |
Expert Posts: 1493 Location: Lordstown, Ohio | You bet Roger. Mine was super nice i paid less then $22 plus shipping window is really nice too | ||
fenix |
Expert Posts: 2120 Location: atlanta | Heater box, sealed (dumdum'd) and in place, and MC installed along with the backing plate. (4-DSCF1402.JPG) (3-DSCF1401.JPG) Attachments ---------------- 4-DSCF1402.JPG (205KB - 179 downloads) 3-DSCF1401.JPG (156KB - 180 downloads) | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | hope you used dumdum that is heat resistant . you brake lines coming off the master . did both the old ones go forward as in the photo . i would have thought the front line to the rear would almost come straight down then towards back , just askin -----------------------------------------------------------later | ||
fenix |
Expert Posts: 2120 Location: atlanta | the lines go to the propor valve, only thing i could find was home depot plumbers putty. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | yah , after i posted , i figured prop. valve is what it was . narrow trailer siding sealer works good for a heater box but not too wide , cause it sticks reallllll good . plumbers putty is ok but will harden about like window glazing . still coming along nice ------------------------------------------------later pssss. did you use an adjustable prop. valve ? | ||
60 Imp |
Location: North Australia | Good work Atlanta, that rig is coming along nicely. Keep up the cause and the pics coming! Steve. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Thanks Steve, appreciate the compliment, Yes, an adjustable Wilwood valve, Chuck. By the way Chuck, i need a recipe for the poly, I talked to Neilson yesterday about a cam, lifters and V springs, I'd like to go to a spin on filter, won't the Hot Heads bypass valve work?, the timing cover on the 61 motor has corrosion eating into one bolt hole, i have a 66 motor out back, will the timing cover off of it work? not sure about timing marks, have to look, what harmonic balancer will work, SBM, 318-340 steel crank? I know there's a list in the Big Book on things that will interchanbe, but not sure if it's for pre and post Poly's. | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | I will be watching for your info to upgrade the 318 since I will be pulling the one out of my '59 Plymouth. | ||
fenix |
Expert Posts: 2120 Location: atlanta | As of now, it'll be .030 over, P-600 3 X 2 intake and Ford ECG carbs, I have a set of the Austrailian Fountain aluminum valve covers, and a set of the Spitfire shorty headers. I'll use a Neilson cam, lifters and valve springs, a Flowcooler water pump, a roller timing set, MP or MSD distributor ad a Crane HI-6 CD box and coil. I do have an old Mallory dual point, and all you need is one set to trigger the CD box. This plan could change if I find a complete 383 sonoramic motor and trans on the side of the road somewhere. | ||
fenix |
Expert Posts: 2120 Location: atlanta | dragula426 - 2014-08-16 7:28 PM cool project! looks like a real nice solid car! Thanks, I see by your avitar, you may also he the dreaded 61 Plymouth bug! :-) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | LA 318 timing cover fits, its just got the marks on the left side of the engine You can use your original pointer on it and time it as per usual The trap though is that there is 1 bolt hole that they deleted on the LA that the poly has, it down the left side about 1/2 way down. You need to plug this hole before the timing cover goes on, because it covers it a little bit, I just used a bolt that I cut of and wound it in with gasket silicone and then staked it to make sure it wouldnt come loose | ||
fenix |
Expert Posts: 2120 Location: atlanta | Thanks Mick, appreciate the info. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | my cam is a 480 lift , duration 274 , overlap 54 , from schneider in cal. , 318 poly solid lifters . the springs and caps are comp cams cause i didn't like the cap fitment on the ones i got from the left coast . if the old cap locks look good , reuse the old ones . if not schneider can fix you up with new ones but they don't have any new 318 poly blank cams to grind the last time i looked . the way it was explained to me , that 480 was a good street choice and should have no match up issues like a wilder cam . the 480 will give you all the kick ass you want , especially when using stock heads , which i'm also doing . those trips you got are they dumpers with plugged idle circuits . if they aren't they'll be hell to tune . with the ends being true dumpers just the center one needs bolted on at start up . then when you get the break in done add the other 2 true dumpers . if they aren't true dumpers about the only way to set em up is by vacuum , which might be problematic depending on how wore the trip cores were before rebuilding . butttttttttt you could use the ends as dummies and only use the center 2bbl --------------------------------------------------later COMP 318-360 CHRYLSER 1.494 SINGLE VALVE SPRINGS SPRING KIT .480" Max Lift MOPAR | ||
fenix |
Expert Posts: 2120 Location: atlanta | I soulda jumped on that cam ya sold, sounds pretty good, how wide was the lobe separation? I'll have to recheck the carbs, with heaers and cam, be a shame to run dummy outboards. Those pistons/rods, and rings I got from ya, are those the truck dished pistons with about 7.5 CR.? | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | the cam i sold was a 460 lift . the new one lobe separation i don't have . for a street cam i really don't think it's needed . those piston i sold ya were mated to the motor by local napa machine shop and should be 9.1 : 1 . brand not sure but most likely silverlite or federal mogul , which is the same . if you run them trips with a heavy foot , be prepared to get @ 10mpg ---------------------------------------later and do what was suggested up above . for an extra couple hundred or so get it balanced . Edited by 60 dart 2014-08-22 12:31 AM | ||
rockerarm |
Elite Veteran Posts: 873 Location: ALABAMA, HEART OF DIXIE |
Roger, are you changing the color of your car. The firewall looks much lighter in the picture. | ||
fenix |
Expert Posts: 2120 Location: atlanta | No Will, crappy camera and crappy camera operator, the outside shot is more the "real" color, it's the factory original color, the factory paint chip say it's called, "screamin' by Mr. Ford and Ms. Chevy Robin's Egg Blue". | ||
fenix |
Expert Posts: 2120 Location: atlanta | Little progress on the car, interior out, nice pans, huh?, new fuel and temp guages, new ammeter, prep for repaint on steering column and shifter, need to treat for rust on the floor and reseal for new carpet and check out the power top system tomorrow.. (01-DSCF1409.JPG) (02-DSCF1410.JPG) (12-DSCF1420.JPG) (14-DSCF1422.JPG) (16-DSCF1424.JPG) (20-DSCF1428.JPG) Attachments ---------------- 01-DSCF1409.JPG (91KB - 167 downloads) 02-DSCF1410.JPG (85KB - 182 downloads) 12-DSCF1420.JPG (94KB - 162 downloads) 14-DSCF1422.JPG (136KB - 191 downloads) 16-DSCF1424.JPG (112KB - 174 downloads) 20-DSCF1428.JPG (106KB - 173 downloads) | ||
rockerarm |
Elite Veteran Posts: 873 Location: ALABAMA, HEART OF DIXIE | fenix - 2014-08-30 12:13 AMLittle progress on the car, interior out, nice pans, huh?, new fuel and temp guages, new ammeter, prep for repaint on steering column and shifter, need to treat for rust on the floor and reseal for new carpet and check out the power top system tomorrow.. Looks great Roger, Nice to see the progress. Will. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Disconnected the top cylinders and let the top down, probably the first time since 1974. (2-DSCF1431.JPG) (7-DSCF1436.JPG) (1-DSCF1430.JPG) (4-DSCF1433.JPG) Attachments ---------------- 2-DSCF1431.JPG (149KB - 164 downloads) 7-DSCF1436.JPG (125KB - 175 downloads) 1-DSCF1430.JPG (92KB - 179 downloads) 4-DSCF1433.JPG (123KB - 165 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | OK, I seem to be going backwards on the car. (10-DSCF1446.JPG) (15-DSCF1451.JPG) (06-DSCF1442.JPG) (08-DSCF1444.JPG) (07-DSCF1443.JPG) Attachments ---------------- 10-DSCF1446.JPG (112KB - 167 downloads) 15-DSCF1451.JPG (83KB - 164 downloads) 06-DSCF1442.JPG (161KB - 168 downloads) 08-DSCF1444.JPG (131KB - 158 downloads) 07-DSCF1443.JPG (137KB - 171 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | Little more progress of the rag, dash has base coat and mock up, redid the aluminum dash trim and knobs, started the body work. Edited by fenix 2014-09-14 10:00 PM (1-DSCF1468.JPG) (6-DSCF1473.JPG) (1-DSCF1455.JPG) (1-DSCF1458.JPG) (1-DSCF1461.JPG) Attachments ---------------- 1-DSCF1468.JPG (123KB - 171 downloads) 6-DSCF1473.JPG (124KB - 160 downloads) 1-DSCF1455.JPG (90KB - 166 downloads) 1-DSCF1458.JPG (93KB - 164 downloads) 1-DSCF1461.JPG (111KB - 158 downloads) | ||
60 Imp |
Location: North Australia | This Rag is well on it's way to being a silk hanky Good work Old Man! Now is a good time to recap on the driveline config, are we keeping three pedals??? Cool thread Man, and a cool car. Steve. | ||
SavoyPlaza |
Elite Veteran Posts: 1172 Location: Georgia | Excellent progress, Roger! Gracias for the updates. Pete | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | There may be a few that thought you had gone over the edge but you are turning the corner. Glad to see the original motor has come back into the picture. There are VERY few Verts that have survived and you will have a great car when finished. A 318 with 3 onda tree in a Drop Top. Ya gotta love it. | ||
fenix |
Expert Posts: 2120 Location: atlanta | Thanks for the compliments all! lots still to do, hope I'm around for the finish line. | ||
fenix |
Expert Posts: 2120 Location: atlanta | 60 Imp - 2014-09-15 6:26 AM This Rag is well on it's way to being a silk hanky Good work Old Man! Now is a good time to recap on the driveline config, are we keeping three pedals??? Cool thread Man, and a cool car. Steve. Silk hanky! LMAO Old man? no, ancient is more like it. Three pedals? yep, three on da tree, actually 3 1'2 if ya count the E brake. 318, 030, P-600 with trips, Flowcooler wp, Cloyes chain, Fountain aluminum valve covers, Spitfire headers, electronic dist with Crane Hi-6 MSD and LX-92 coil. Nothing crazy, just a good running cruiser. | ||
dragula426 |
Veteran Posts: 124 Location: duluth mn. | fenix - 2014-08-21 5:32 PM dragula426 - 2014-08-16 7:28 PM cool project! looks like a real nice solid car! Thanks, I see by your avitar, you may also he the dreaded 61 Plymouth bug! :-) you have no idea.....! | ||
big m |
Expert 5K+ Posts: 7807 Location: Williams California | Nice progress!! You've got a really solid convertible, that's something you do not see often these days! ---John | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | I hope you bring it to the PACE Car show in Pulaski, TN | ||
fenix |
Expert Posts: 2120 Location: atlanta | Worked on the front fenders and inst cluster, also got the steering wheel ready. The old one is the one that came on the car, the other is an NOS wheel I repainted with white gripes and cleared., thoght it would go better with the interior. Edited by fenix 2014-09-17 7:31 PM (2-DSCF1476.JPG) (4-DSCF1478.JPG) (1-DSCF1475.JPG) (5-DSCF1479.JPG) Attachments ---------------- 2-DSCF1476.JPG (143KB - 170 downloads) 4-DSCF1478.JPG (152KB - 162 downloads) 1-DSCF1475.JPG (118KB - 166 downloads) 5-DSCF1479.JPG (125KB - 201 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | double post, sorry Edited by fenix 2014-09-17 6:16 PM | ||
fenix |
Expert Posts: 2120 Location: atlanta | Little more progress, trunk is stripped, new seam sealer, undercoated and ready for paint, also piddled around and got my 61 Ga tag redone. Hope I ain't boring ya'll. Edited by fenix 2014-09-24 9:07 PM (DSCF1493.JPG) (DSCF1498.JPG) (DSCF1501.JPG) (DSCF1502.JPG) Attachments ---------------- DSCF1493.JPG (198KB - 167 downloads) DSCF1498.JPG (143KB - 165 downloads) DSCF1501.JPG (184KB - 152 downloads) DSCF1502.JPG (214KB - 185 downloads) | ||
rockerarm |
Boring ......???????? I don't think so Roger. I'm excided for ya. She's looking great. Keep the progress pic's coming. Will. | ||
SavoyPlaza |
Elite Veteran Posts: 1172 Location: Georgia | Mucho bueno! It was a great day in Georgia when they started allowing us to use year-of-manufacture plates on our cars. I thought 1961 tags were yellow, is this one a special? Pete | ||
1961plymouthfury |
Expert Posts: 2634 Location: Minor Hill, TN | I need to restore my 1961 Tennesee Tag . It does not look as good as the other 1 on my other '61 (IMAG0615.JPG) (IMAG0347.JPG) Attachments ---------------- IMAG0615.JPG (143KB - 164 downloads) IMAG0347.JPG (129KB - 179 downloads) | ||
fenix |
Expert Posts: 2120 Location: atlanta | SavoyPlaza - 2014-09-25 6:07 AM Mucho bueno! It was a great day in Georgia when they started allowing us to use year-of-manufacture plates on our cars. I thought 1961 tags were yellow, is this one a special? Pete Just hoping no one notices but You! :-) by the way, after i posted the pic i noticed the first #1 was different than the second, and for some odd reason it is. | ||
fenix |
Expert Posts: 2120 Location: atlanta | 1961plymouthfury - 2014-09-25 6:17 AM I need to restore my 1961 Tennesee Tag . It does not look as good as the other 1 on my other '61 You ned to stop comparing this red car to the black car you had or you'll never be happy with this car. Why not recreate this red car into a copy of the black one, i think that's what will satisfy you the most. | ||
SavoyPlaza |
Elite Veteran Posts: 1172 Location: Georgia | fenix - 2014-09-25 10:46 AM SavoyPlaza - 2014-09-25 6:07 AM Mucho bueno! It was a great day in Georgia when they started allowing us to use year-of-manufacture plates on our cars. I thought 1961 tags were yellow, is this one a special? Pete Just hoping no one notices but You! :-) by the way, after i posted the pic i noticed the first #1 was different than the second, and for some odd reason it is. I doubt anyone will notice. I found an originally white 1961 public service commission tag that I thought would be cool for my green wagon. I repainted it black because I liked that color better and held my breath that they would accept a Public Service tag on a passenger car. They didn't flinch, and so I ride! Pete At the risk of polluting your thread with more ugly 1961s..... (July18,2011a.jpg) Attachments ---------------- July18,2011a.jpg (150KB - 168 downloads) | ||
rockerarm |
fenix |
Expert Posts: 2120 Location: atlanta | For her sake, I sincerely hope so, and I hope she doesn't talk about that black car in the presence of the red one, they hear everything, ya know. Ya have a point about getting over the loss of a car like that, even being stolen woulda been better than burned alive, what a gorgeous car she was! | ||
fenix |
Expert Posts: 2120 Location: atlanta | SavoyPlaza - 2014-09-25 11:14 AM fenix - 2014-09-25 10:46 AM SavoyPlaza - 2014-09-25 6:07 AM Mucho bueno! It was a great day in Georgia when they started allowing us to use year-of-manufacture plates on our cars. I thought 1961 tags were yellow, is this one a special? Pete Just hoping no one notices but You! :-) by the way, after i posted the pic i noticed the first #1 was different than the second, and for some odd reason it is. I doubt anyone will notice. I found an originally white 1961 public service commission tag that I thought would be cool for my green wagon. I repainted it black because I liked that color better and held my breath that they would accept a Public Service tag on a passenger car. They didn't flinch, and so I ride! Pete At the risk of polluting your thread with more ugly 1961s..... Ugly 61 Plymouths? ain't that one of them there ozzymorans? | ||
