Location: WHEELING,WV.>>>HOME OF WWVA | oem 383 elbows and a good , working dash pot ,,,,,,,,,,,,,,,,,, 1250$ + actual shipping . all are in good useable condition . the manifolds have minor pitting at the elbow
mating surfaces and one has minor pitting at one exhaust port surface but nothing that correct gaskets won't seal . both heat risers turn freely and need springs , which is
real common . i would however install new shafts and butter flies . the outside surfaces aren't ate up with rust . elbows are real nice oem . the dash pot holds vac. .
if someone has a serious interest and needs photos , i can do that . also all threads holes are good and clean . nothing is cracked or broken , except the springs -----------------later |
