56 Royal Disc Conversion Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ionzion1 |
New User Posts: 1 | I have recently purchased a 56 Royal and would like some info as to whether there is a front disc retrofit kit out there on the interweb or if there is some sort of parts swapping that can be done to put disc on the front? I really like the looks and ride, but want to update some of the safety features to make driving in modern traffic more enjoyable. Thanks! | ||
56RoyalLancer |
Elite Veteran Posts: 608 Location: Madison, Wisconsin | I believe this vendor has come highly recommended. I however do not have personal experience with them. http://www.aajbrakes.com/ | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 56RoyalLancer - 2014-06-03 8:01 AM You did see the multiple ads in the for sale section saying AAJ is for sale, buy it & put the product back in production......I believe this vendor has come highly recommended. I however do not have personal experience with them. http://www.aajbrakes.com/ | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | ECI makes brake kits. http://www.ecihotrodbrakes.com/dodge_plymouth_discbrake_conversions... | ||
t2dfyre |
Extreme Veteran Posts: 341 Location: California | I just recently started looking into this for my 56 dodge but dont really wanna pay an expensive price. So i thought about doing my homework on parts ill need but i have not a clue on the brackets they are using in their kits. Does anyone have any info into this?? Thanks TD | ||
55coronet440 |
Veteran Posts: 272 Location: Missouri | I used the AAJ brake kit on the '55, bought the calipers, pads, and hoses('76 Monte Carlo), and rotors('78 Plymouth Volare) locally. The basic AAJ kit has the brackets, hardware, machined spacer (to adapt the rotors' inner bearing and seal to our spindles), and complete illustrated instructions. It alone was about $250 IIRC. Spindles and outer tierod ends had to be modified some, but it wasn't hard to do, just takes some time with a grinder, welder and a 5/8" NF tap and nut. I can't report on performance yet as I have to finish plumbing the new line to the rear drum brakes and bleed it all. Harold | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | Have you noticed the "AAJ Brakes" business for sale posts? | ||
55coronet440 |
Veteran Posts: 272 Location: Missouri | Well I read the above post by you on 6-03, but I couldn't buy it if I wanted to. It'd be a good thing for someone to get the business and run with it, though! Was just trying to inform TD. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | The Tex Smith Mopar hot rod book has a conversion in it using '79-'85 Olds Toronado (& probably Eldorado) rotors that are redrilled to the Mopar pattern, backing plates moded from early 70s 4 wheel drive Blazer & apparently the hub from the Mopar. it's an Old book, has contact info listed as Ed Gross, down n dirty Rod shop, 221 N. Elias St. Wales, Wi. 53183 | ||
t2dfyre |
Extreme Veteran Posts: 341 Location: California | Thanks 55. Yeah i was thinking about aaj but i think im going to try another route. If all goes well it will be cost affective and safe. Ill post pics on here when i get started with the install. Im presently getting the parts i will need. Thank you for the info! TD | ||
t2dfyre |
Extreme Veteran Posts: 341 Location: California | Hi all what type of calipers are you guys running on your disc brake conversions for your mopars preferably 55 or 56 with 11" rotors? Thank you everyone. TD | ||
