1961 New Yorker mystery side trim? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
highpockets |
Extreme Veteran Posts: 398 Location: Watertown South Dakota | I have a 61 New Yorker 2 door parts car here. I started stripping it and was kinda proud of the side trim on it,,,thought it was an option. Peter (KP/Sweden) informed me that it is not original. I did some internet image searches and can't find anything similar (year/make) with this trim. It sure seemed to fit the car good. I will attach some poor pictures. I have already removed the trim now, so new pictures of the car won't work. Any clues? (013.JPG) (014.JPG) (015.JPG) (016.JPG) Attachments ---------------- 013.JPG (302KB - 48 downloads) 014.JPG (300KB - 53 downloads) 015.JPG (298KB - 45 downloads) 016.JPG (301KB - 49 downloads) | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | I would say that's a '60 Windsor trim perhaps? There are two kinds of trim on Windsors I seem to recall, a wider trim and the thinner one. I think someone put the thinner trim on this '61. http://www.powerful-cars.com/images/chrysler/chrysler60windsor1c.jp... Edited by BigBlockMopar 2014-06-10 6:28 PM | ||
60crossram |
Elite Veteran Posts: 836 Location: Layton, Utah | Would you sell me the right rear wheel lip molding ? (Passenger rear). I'm not sure about the side trim, but if the trim fits the door good you would think it would have to be Mopar trim. | ||
Board Moderator & Exner Expert 10K+ Posts: 13055 Location: Southern Sweden - Sturkö island | Herman is almost dead on - it's the '60 standard side trim for Saratoga and Windsor that was used for monotone cars. The sporttone trim uses the same wide side trim with a thinner in addition for to create a field for the two tone color (normally same as the roof color) between the two trims. Fender and door trims is a direct fit for Saratoga (it seems like the fender trim is longer) 2 DHT | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | The NY'er 'gills/chevrons/what-ever' on the quarter panels are so valuable, it's conceivable that the area around them might be cut out, so that those ornaments could be carefully removed from the body-steel, off and away from the car. | ||
StillOutThere |
Location: Under the X in Texas | Here is a pic of a '60 Windsor monotone convert with the trim. (Frt Rt.jpg) Attachments ---------------- Frt Rt.jpg (40KB - 49 downloads) | ||
Centurion |
Regular Posts: 88 Location: Puyallup, Washington | Highpockets, do you have the rear molding that extended between the taillamp bezels of the car, passing between the trunk lock cylinder and the license plate? Please let me know. | ||
LAGTONE420 |
Member Posts: 26 | I need this molding, RH SIDE,,would you sell it ? (61 NEW YORKER.JPG) Attachments ---------------- 61 NEW YORKER.JPG (332KB - 54 downloads) | ||
61desoto |
Regular Posts: 60 Location: Pine, CO | Would you like to sell your front bumper? | ||
