Vickers Power Steering Pump Shaft Seal
bbrasse1
Posted 2014-07-18 5:08 PM (#449612)
Subject: Vickers Power Steering Pump Shaft Seal
50025
Has anyone gotten a new shaft seal for a 57-58 Vickers pump? The one Rock carries is perfect shaft diameter and width but the bore is 1.25 and the bore in the pump is 1.31. I have 3 pumps and they are all the same so I know it is the correct bore size. I hate to go to seal companies and pay the minimum order amount for one seal if someone has bought one recently and can share the make and part number.
Thanks
Shep
Posted 2014-07-18 7:19 PM (#449622 - in reply to #449612)
Subject: Re: Vickers Power Steering Pump Shaft Seal
20001000100100100100
Bob, go to Napa they have a seal catalogue and may be able to match it up.
Posted 2014-07-19 7:36 PM (#449710 - in reply to #449612)
Subject: RE: Vickers Power Steering Pump Shaft Seal
20001000500100100252525
I have a very old Trostel seal catalog and that '54-'57 pump calls for a seal that's 3/4" X 1.254" X 1/4" (#423294).
CR seal #7481 has the following dimensions, .750 X 1.301" X .250"
http://www.ebay.com/itm/like/291126062097?lpid=82
bbrasse1
Posted 2014-07-20 7:41 AM (#449742 - in reply to #449710)
50025
57chizler - 2014-07-19 7:36 PM
Big thanks! That will save me a lot of time and money. Hope I can do the same for you someday.
58coupe
Posted 2014-07-20 11:20 AM (#449752 - in reply to #449612)
100050010010025
What do you mean "minimum order amount"? We have local bearing and seal stores that can match up just about any bearing or seal and you can buy just one if you want.
bbrasse1
Posted 2014-07-21 9:23 PM (#449972 - in reply to #449612)
50025
Many of the seal companies won't sell you one and have a minimum order. I got one coming from eBay. Thanks I may need a referral to one of your sources in the future.
