Help! Need studs! Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
db300 |
Extreme Veteran Posts: 314 | Well, the machine shop lost my head to valve cover studs on my four bolt 413 heads...anyone know where I can get 8 of them ASAP? Fine thread on top, std on bottom...thanks! | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | If you have a Fastenall store nearby, they can usually order those odd combinations in a couple of days. I got some really odd ones last week and it took two days to get them in the store...but they weren't cheap. | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | Try an auto parts store like Napa with a Dorman selection or even Home depot or Ace hardware. You would be surprised what grade 8 hardware they have. you may only need grade 5 for valve cover studs. Marc. http://www.pointe-products.com/itemclass/Manifold-Studs New Zealand! http://www.usaspecialty.co.nz/index.php?main_page=product_info&cPat... http://www.allensfasteners.com/search_results.asp?txtsearchParamCat... http://www.olsenindustrial.com/itemclass/Manifold-Studs http://www.amazon.com/10-Double-End-Studs-28-SAE/dp/B004KB4TK2 http://www.nutsandbolts.com/stud-index-metric-sae-uss-saeuss-studs-... Shorties on ebay http://www.ebay.com/itm/10-Double-End-Studs-1-4-28SAE-x3-8-1-4-20US... long ones on epay http://www.ebay.com/itm/10-Double-End-Studs-1-4-28-SAE-x1-1-4-20-US... Edited by mstrug 2014-07-31 6:54 PM | ||
Expert Posts: 3778 Location: NorCal | Maybe I'm old-fashioned but I think if the shop lost them it's their responsibility to replace them. | ||
db300 |
Extreme Veteran Posts: 314 | I'd like to think they'd replace them too :-( I have a lead on a Dorman part number...will find out tomorrow | ||
58coupe |
Expert Posts: 1740 Location: Alaska | That is a very common stud design, coarse on one end and fine on the other. I am sure Dorman makes them, we had a whole assortment in a shop I worked in 3 years ago, I believe Napa resupplied us. | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | http://www.dormanproducts.com/p-22487-675-085.aspx | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | http://www.dormanproducts.com/p-3770-675-086.aspx | ||
mstrug |
db300 |
Extreme Veteran Posts: 314 | I was given Dorman 675.084 wS the stud needed. Sadly going thru the wall of Dorman at the well stocked machine shop/ parts store got me nowhere. The wall of Dorman didn't offer anything, and it showed online that neither of the vendors that supply them offered that item anymore. I ended up finding some used ones at Wildcat... | ||
