Location: McComb, Mississippi | Where to buy an oem style 7 blade cooling fan? Collecting parts for ac conversion. |
Do you want the hard mounted Seven Blade Cooling Fan That was with all A-318's or The Seven Blade cooling Fan that was only used with the 361 or 383's ?
Rodger & Gabby
COS |
Location: bishop, ca | Chris, as per our PM, I checked my 61 file and found nothing of interest regarding the A/C or the clock.
Except, that the clock's individual option code is 299, and that it was included in the "Appearance" Accessory Group #304, which included the
'plain' wheel covers and the stone shields.
The A/C was available in two iterations: single or dual [on the wagons, only, naturally] and with both versions being N/A with
the manual transmission, the Rammie engine, or the Polara with standard steering.
The code for the A/C is 311 and the Dualie is 312.
Not much help, but that's all I've got on the 61 Dodge A/C or clock.
Here's a couple views of the 7-blade fan; the fan has the JAG fan clutch attached to it in these photos.
Edited by d500neil 2014-08-23 6:57 PM
(PICT0001.JPG)
(PICT0007.JPG)
Attachments ---------------- PICT0001.JPG (105KB - 208 downloads) PICT0007.JPG (110KB - 208 downloads)
Location: McComb, Mississippi | Any idea where I can get the fan? I have the clutch already. |
Location: Southern Sweden - Sturkö island | You can get fans from your closest junk yard - I run a more "modern" 5-blade fan from some 70 whatever Mopar - cheap, silent and good |
Location: New Orleans-ish | I think I have one. I bought one to keep as a spare but would probably part with it. |
Location: McComb, Mississippi | DeMopar - 2014-08-25 3:06 PM
I think I have one. I bought one to keep as a spare but would probably part with it.[/QUOT. PM sent |
