Leaf spring bushings for 61
plymouth
Posted 2014-10-19 1:10 PM (#459678)
Subject: Leaf spring bushings for 61
20001001002525
Where have you all found all of the leaf spring bushings for our 61 mopars? Has anybody used poly bushings or just regular rubber? Thanks
Shep
Posted 2014-10-19 5:14 PM (#459699 - in reply to #459678)
Subject: Re: Leaf spring bushings for 61
20001000100100100100
Pst should have them, poly will prevent deflection will handle better.
plymouth
Posted 2014-10-19 7:19 PM (#459707 - in reply to #459699)
20001001002525
Thank you
Rodger
Posted 2014-10-20 3:12 PM (#459783 - in reply to #459678)
1000500
Hola Christian
If you compare worn out bushings form any vehicle over 25 years old to a new set of bushings - it will have improvement.
Compare a vehicles quality of ride with new rubber vs new poly and you will see a difference.
http://www.springsnthings.com/
Rodger & Gabby
COS
