Location: Park Hills, KY | Where can I get the correct type oil for the sure grip? |
Location: Chestertown, NY ( near Lake George) | Napa for one. |
Location: WHEELING,WV.>>>HOME OF WWVA | Hypoid Gear Oil , just about every parts store ---------------------------------------------------later |
I thought there was some kind of additive we had to use for sure grip??? At least for the 58 early ones.
Greg |
Chuck,
Greg Summit & others have the additive. |
Any auto supply will have limited-slip additive as will your local GM dealer under part number 88900330 |
Location: Netherlands | I've never had to buy the additive seperatly.
You just get the correct oil, usually labeled as Limited Slip oil, or a "LS" type gear oil.
Location: Under the X in Texas | I use Royal Purple gear lube. It includes additives for limited slip differentials. If you are not using any additive and do not think you have a problem, I would suggest that your lim. slip is no longer working due to burnout.
