Pushbutton 727 identification
mopark
Posted 2014-12-08 6:34 AM (#463963)
Subject: Pushbutton 727 identification
Hi All, I have a aluminium 727 with cable shift and rear emergency brake drum. It has a 318 poly bellhousing pattern. What would it be out of or is it made up of a mixture of parts? Thanks Glen
grunau
Posted 2014-12-08 9:22 AM (#463968 - in reply to #463963)
Subject: Re: Pushbutton 727 identification
10010010010025
Hi
The only TorqueFlite 727 that I know of with the parking brake mounted on the extension housing is from the '62 Chrysler and it has a big block bolt pattern
I have two of them and I was going to see If I could build what you have...its possible someone has already done this in your case or since you are in Australia
Chrysler may have done it for an export model. I have no "export" parts books in order to verify this.
Posted 2014-12-09 1:46 PM (#464109 - in reply to #463963)
Subject: RE: Pushbutton 727 identification
20001000500100100252525
What is the part number stamped on the left pan rail just below the NSS?
Rodger
Posted 2014-12-11 12:34 AM (#464296 - in reply to #463963)
1000500
Hola Glen
Every Dodge Truck with The A-318 used what you are describing. Very few Dodge or Plymouth Cars have this Transmission - but with a few hand wrenches - any Car Division
could have what you have. The Bristol's may also use this transmission.
The Dodge Truck version was with a Four Gear Planetary Gear and 95 plus % of the cars had a three gear designed Model 727.
Rodger & Gabby
Colo Spgs
Now tell us the number's.
