Carter AFB 3133S LO rough cold idle Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | Hi, I've recently rebuilt my carburetor (as mentioned in the title a Carter AFB 3133S LO) that is sitting on top of my stock rebuilt 383 using the Hygrade 224D Kit which should be the right kit for this carb. I've also replaced both floats. Every think worked fine, and as soon as the engine is warm, it runs really strong and has a nice idle. But unfortunately as long as the engine is running on the choke it idles really bad and is also lacking power. I have adjusted the choke according to the manual and set the fast idle to 1800 rpm when warm, which gives about 500 rpm when cold. Judging by the color of the plugs and the dense black/grey exhaust smoke the engine is running really rich when cold. Does anybody of you have an idea what the problem cold be? Thanks in advance! | ||
58coupe |
Expert Posts: 1740 Location: Alaska | I would try backing off some on the initial choke setting. Even though you set it to the "correct" setting, you are working with a 50 year old carb. and it just may be staying on too long. | ||
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | I don't really think it is staying on too long, it opens up just as soon as the engine is getting warmer. i have the feeling that the choke valve itself is somehow in a too closed position although it is meant to be closed when the engine is cold, right? edit: but if you're right, how would is set the choke to open up earlier? I thought it is pulled open by vacuum as soon as the thermostatic coil looses its tension? Edited by Polara61_383 2015-02-22 12:37 PM | ||
grunau |
Extreme Veteran Posts: 444 Location: North of the 49th | Hi Sometimes you can't just set the choke to factory spec and hope it works... what I've done here in the land of ice and snow is "tune" the choke. With the engine cold and with a symptom such as what yours is presenting with, I would, with the engine running and the air cleaner in place pull the choke actuating rod downward gradually until the engine unloads, RPM picks up and cleans up leaving just enough choke to keep it happy cold. I would mark the rod and readjust the choke thermostatic coil to match my mark. Ensure that the link attaching the choke plate to the piston at the back of the air horn is in place...that is your "vacuum break" if that's not working it will add to the problem. For your reference I have included the original Carter specification sheet for your particular carburetor. 1960 Desoto 1958 Plymouth Fury 1958 Dodge Custom Suburban 1958 Plymouth Savoy 1959 Dodge Custom Sierra and a few non FL's Edited by grunau 2015-02-22 2:14 PM (3133s.jpg) (3133spg2.jpg) Attachments ---------------- 3133s.jpg (167KB - 134 downloads) 3133spg2.jpg (142KB - 131 downloads) | ||
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | Hi grunau, that sounds good, i'll give it a try! and thanks a lot for those scans, that's the most detailed information on my carb i've ever seen. | ||
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | Hi, readjusting the thermostatic coil really did the trick! Thanks! | ||
grunau |
Extreme Veteran Posts: 444 Location: North of the 49th | Happy to help! | ||
