Camcraft Cams
littlecarl
Posted 2015-03-12 7:01 AM (#472292)
Subject: Camcraft Cams
10010010025
I've been looking at a possible cam upgrade for my 318 poly an found this website for Camcraft Cams.
These are made from brand new blanks rather than re grinds. Just thought I'd share.
http://www.camcraftcams.com/index.php?page=318-chrysler
Carl
Rodger
Posted 2015-03-12 11:51 AM (#472305 - in reply to #472292)
Subject: Re: Camcraft Cams
1000500
Hola Carl
I looked at their A-318 information ( http://www.camcraftcams.com/index.php?page=318-chrysler ) and see only words ( aka hype ).
In England - what is the vehicle speed that you normally drive at. To Me - I would target this vs any other thoughts.
Rodger & Gabby
Colo Spgs
littlecarl
Posted 2015-03-12 3:09 PM (#472321 - in reply to #472292)
Subject: RE: Camcraft Cams
10010010025
Hi Rodger, Well it's anything from stop/start sitting in traffic to 30 to 40 in town and up to cruising at 70mph (maximum speed limit on motorways). I don't like the sitting in traffic part but it happens.....
I sent an enquiry to them telling them I have a poly and seeing what my options were as I have the Wieand single plane intake that the car came with.
I got back
" Our most popular cam is a 24-1212-10A4  (m). It has 212 duration @.050 with .435 lift and 110 lobe separation. We try to keep these in stock. Cost is $235.00 + shipping. The lifters are about $140.00 + shipping. If we do not have any in stock allow about a week for production. These cams are intended for basically stock engines and have great throttle response. They have a pretty smooth idle."
I do need to change my cam as the one that's in the car has pits on the back of the lobes from water damage (I had a major water in the oil problem). I only ran this temporarily whilst seeing if the rest of the engine was OK.. That temporarily has run into 3+ years so I thought I'd better get round to it
littlecarl
Posted 2015-03-14 11:39 AM (#472469 - in reply to #472292)
10010010025
Just had a look on Rock Auto for camshafts there. They have EngineTech camshafts but whats puzzling is the span of years it covers '57 to '89!! part no ES1089R
Posted 2015-03-14 11:57 AM (#472472 - in reply to #472292)
50001000500
Can't be 318a and la don't interchange:
273/318/340/360 LA Parts
Interchange With The Polyspherical "A" Motor
Distributor (electronic or standard points style)
Distributor/oil pump drive gear
Oil pump
Oil pan (except 360)
Fuel pump
Timing chain and sprocket
LA 318 ring set
Hi-torque or standard starter
Flywheel
Connecting rods
Crankshafts (including reground 360)
Rod bearings
Main bearings (except 360)
Valvesprings/retainers/keepers
Harmonic balancers from internally balanced 273/318/340 engines (may use timing tape where timing marks do not align)
Timing case cover and matching water pump
Thermostat housing and thermostat
Read more: http://www.hotrod.com/how-to/engine/mopp-0109-chryslers-poly-head-e...
Follow us: @HotRodMagazine on Twitter | HotRodMag on Facebook
littlecarl
Posted 2015-03-14 12:23 PM (#472473 - in reply to #472292)
10010010025
Precisely my thoughts Marc. Thanks for the reasurance.
