Where IS the Data Plate ?
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
Chumley
Posted 2015-03-28 1:21 PM (#473676)
Subject: Where IS the Data Plate ?
Hi,
I just got a '58 Plymouth Plaza sedan. I looked around a little for the data plate I've seen pictured in other threads here, but can't find it. For some reason I thought it'd be on the firewall, but no dice.
Paul
finsruskw
Posted 2015-03-28 2:22 PM (#473684 - in reply to #473676)
Subject: RE: Where IS the Data Plate ?
2000100100252525
Look on the rad support, the earlier Chryslers were there, and your car is related Ya know!
May be down low above the splash pan
ronbo97
Posted 2015-03-28 6:11 PM (#473701 - in reply to #473676)
2000200025
Chumley - 2015-03-28 1:21 PM Hi, I just got a '58 Plymouth Plaza sedan. I looked around a little for the data plate I've seen pictured in other threads here, but can't find it. For some reason I thought it'd be on the firewall, but no dice. Paul
Only Newark-built and LA-built 58 Plymouths had data plates. Send to Chrysler Historical if you're curious about your car.
Ron
