Location: Muskego, WI | I have a new, pre bent stainless fuel line kit and I was surprised to find this non-flared, compression type fitting at my gas tank connection when I went to make the swap. What type of fitting is this and where can I get a new one or have one made? I screwed up the copper insert trying to pull it out to see what it was, big mistake on my part as now it's not useable. Any help is appreciated.
Edited by jboymechanic 2015-04-24 12:32 AM
(Fuel line 1 sized.jpg)
(Fuel line 2 sized.jpg)
Attachments ---------------- Fuel line 1 sized.jpg (206KB - 94 downloads) Fuel line 2 sized.jpg (231KB - 87 downloads)
I took that nut off the end of my old line and then put it on my new one. I never quite found a replacement for it as the 55 was longer than a normal fitting. I did have luck eventually from Inline Tube. They had a fitting like the original but I had to go into the store to actually get it matched. Their books don't go back to 55 / 56. They physically matched it at the store.
A standard flair did work for me. The unique thing was the nut...
http://inlinetube.com/
Edited by Beltran 2015-04-24 7:11 PM
Location: Muskego, WI | I do have the nut, but need the insert. I appreciate your response, I'll try to get a hold of them this week. |
Location: Michigan | I am not sure you really do. I don't recall having that insert in mine. I only had trouble with the nut. My take is original and I just have a flared standard line going in. |
