Disc brakes using Aspen spindles
martin59
Posted 2015-08-26 12:03 PM (#488035)
Subject: Disc brakes using Aspen spindles
I know lots of guys on here used Aspen spindles just wondering what all do I need to do to get it going. I bolted the spindles on but the tires lean in on the top how do I fix this is it ball joint. Does anyone have build pictures or links.
Posted 2015-08-26 2:06 PM (#488049 - in reply to #488035)
Subject: RE: Disc brakes using Aspen spindles
20001000500100100252525
Is the weight of the car on the tires? Did you roll the car back and forth several times to allow the suspension to settle?
The Aspen spindles are known to be shorter than the originals but any out-of-spec camber should be able to be corrected with a front end alignment.
60 dart
Posted 2015-08-26 4:36 PM (#488060 - in reply to #488035)
Subject: Re: Disc brakes using Aspen spindles
50002000100050010010010010025
i have aspen front discs on my dart , it needs to be realigned after install ------------------------------------------------later
martin59
Posted 2015-08-27 9:36 AM (#488111 - in reply to #488035)
I'll move it back and forth to see if that helps then get it aligned. I guess this happens alot. Thanks guys
58coupe
Posted 2015-08-27 9:54 AM (#488112 - in reply to #488035)
100050010010025
Someone posted on this site a source for extra long ball joints that might help, I'll see if I can find them.
