Brake & gas lines
Moderators: big m
   Forward Look Local Regions -> Pacific Northwest RegionMessage format
59 in Calif
Posted 2015-11-12 9:10 PM (#495014)
Subject: Brake & gas lines
Hey guys, I just finished routing new brake and gas lines. Check the pics posted in the 'Brake,,,,,' section main menu. Jerry
big m
Posted 2015-11-13 6:54 PM (#495094 - in reply to #495014)
Subject: Re: Brake & gas lines
50002000500100100100
Looks like you're making good progress. Do you have heat in your garage?
Posted 2015-11-13 9:36 PM (#495106 - in reply to #495094)
5000500050005000200050025
Heat in the garage ? He lives in Hayward ! How cold can it possibly get
in Hayward ???
59 in Calif
Posted 2015-11-14 1:02 AM (#495113 - in reply to #495014)
John, thanks for asking, No heat in the shop. I have one of those torpedo style diesel heaters for when it occasionally is nice to get the chill out. I have seen it snow here twice many years ago. It stuck to the grass and was gone in couple hours. But high 30's, low 40's is usually about as cold as it gets. I picked up the driveshaft today. It was cheaper to use the drive shaft out of the camper, shorten it a bit, and put a bigger yoke on the diff. I thought the tube was a bit big in diameter but he didn't see where that would be a problem. Although a 1" inward travel distance I though was a bit light. Jerry
