compatible heads for 1960 RB 383
bad58mike
Posted 2016-05-02 1:32 AM (#510647)
Subject: compatible heads for 1960 RB 383
10001002525
Hi looking to find out which heads would be compatible for 1960 RB 383 out of a 60 Windsor. my heads are cracked and need t find some options.
thanks
60 dart
Posted 2016-05-02 4:06 AM (#510649 - in reply to #510647)
Subject: Re: compatible heads for 1960 RB 383
50002000100050010010010010025
http://www.moparts.org/Tech/Archive/motor/36.html
BigBlockMopar
Posted 2016-05-02 5:13 AM (#510650 - in reply to #510647)
20001000500252525
ANY bigblock head will fit, 'xcept for the MaxWedge heads. but it seems doubtful you will stumble onto a pair of these.
Newer heads will require 'matching'/more common 6-bolt valvecovers though.
58coupe
Posted 2016-05-02 9:52 AM (#510664 - in reply to #510647)
100050010010025
There is also a difference in the rocker shaft stands in about 64-66 (don't remember for sure) so need matching rocker stands.
NicksGarage
Posted 2016-05-02 12:28 PM (#510678 - in reply to #510647)
1000100100
What's the bore on an RB 383? There are heads with smaller valves. My '60 413 heads are casting number 2128521 and have 2.08" intake valves and 1.60" exhaust. You probably need something from a 361 or RB 383.
Here's another site with casting numbers and specs - http://www.hotrodreference.com/758/big-block-mopar-cylinder-head-ca...
My 300F has 1964 heads on it with the removable rocker stands and 6-bolt valve covers. Eventually I'll put the right heads back on it.
Posted 2016-05-02 9:55 PM (#510726 - in reply to #510678)
50002000100100
NicksGarage - 2016-05-02 9:28 AM
The bore on the RB383 is 4.03
