Location: Connecticut | Leaking master cylinder was replaced. Then brakes were bled. Bleeding order: RR, LR, RFL, RFU, LFL, LFU. Here's the problem: I bled the right front lower until I got a steady stream with no bubbles. But when I bled the right front upper, nothing came out when I opened the bleeder. Three attempts and still nothing, even when opening 180 degrees. So just to experiment, I moved on to the left side. The left front lower was bled until a steady stream. But when bleeding the left front upper, same story-- nothing came out. My helper says that pedal goes about half way down to the floor when bleeder is opened. Power brake car, BTW. Master was bench bled before installing. Any thoughts ? Ron |
Location: Connecticut | These wheel cylinders were installed in 2008. I removed the bleeder screws and they were not gunked up at all. Then I used a small wooden shish kabab skewer to poke around in the bleed hole to clear any blockage. I haven't had a chance to retest yet. If the problem persists, my friend suggested that I need to back off the shoes all the way, then retest. I also read something like that in the shop manual. Ron |
