56 Plymouth V-8
billb
Posted 2016-06-28 1:05 PM (#515381)
Subject: 56 Plymouth V-8
The engine acts like the carb. is boiling away the gas when it is hot. The engine has just been rebuilt, it runs fine until it reaches 190 degrees at the top hose at the rad. At first I thought it was the heat riser valve but it is the same when I wired it open. I have done a compression test and all are 160 lbs. I have sprayed around the intake manifold and the carb. gasket with no change in RPM. Any other suggestions would be appreciated.
Mopar1
Posted 2016-06-28 1:51 PM (#515387 - in reply to #515381)
Subject: Re: 56 Plymouth V-8
2000100025
Possibly the crappy gas we have today. Might have to add a phenolic spacer to keep the carb cooler.
ttotired
Posted 2016-06-28 5:05 PM (#515397 - in reply to #515381)
50002000100010010010010025
Fuel boiling in the carb is usually a only a problem when you stop an engine, then restart, unless your getting a vapour lock?
What is the engine doing, whats the set up (2 barrel, 4 barrel, 2x4, 3x2, injected)?
And have you rebuilt the carb and is it new fuel and did the car sit for a while ect
billb
Posted 2016-06-28 8:25 PM (#515415 - in reply to #515381)
Subject: RE: 56 Plymouth V-8
It is a 2 barrel, it is new gas and it runs fine until it gets hot, then it boils the gas.
Stevie Exit
Posted 2016-08-01 5:23 PM (#518148 - in reply to #515381)
What do you mean by the gas is boiling away? Do you see it boil over?
