1959 DeSoto Fuel Pump
Posted 2016-07-27 11:54 AM (#517743)
Subject: 1959 DeSoto Fuel Pump
Two different fuel pumps are advertised that will fit a '59 DeSoto. The arm lengths are significantly different. How can both of them be the right one? From my experience many years past, I am familiar with the one that has the longer arm and also a push rod was needed that is about 3 inches long if memory serves me right.
Please advise.
Thanks,
Fred
Edited by Viper Guy 2016-07-27 12:00 PM
(s-l225.jpg)
(s-l225 (1).jpg)
Attachments s-l225.jpg (9KB - 122 downloads)
Attachments s-l225 (1).jpg (3KB - 123 downloads)
Posted 2016-07-27 7:06 PM (#517770 - in reply to #517743)
Subject: RE: 1959 DeSoto Fuel Pump
50002000100100100100
not the one with the longer arm. the upper seems right but i believe its a cheap non rebuildable carter. check ebay and search for mopar big block/hemi (2.gen) fuel pumps they all fit from 1958 till end of production.
Edited by 1960fury 2016-07-27 7:10 PM
Posted 2016-07-27 8:49 PM (#517776 - in reply to #517770)
1960fury - 2016-07-27 6:06 PM
Thanks! I have a new rebuilt one that came with the car when I bought and it has the shorter arm. It also has the row of bolts around the housing where it can be taken apart for repair. This I think is good and should be the right one. I probably will never need it because I have it as a spare but low and behold, if I sold it, that would be the first thing I'd have to replace - Murphy's Law you know.
Fred
Edited by Viper Guy 2016-07-27 9:06 PM
Matthew Keij
Posted 2016-07-29 6:27 PM (#517915 - in reply to #517743)
Subject: Re: 1959 DeSoto Fuel Pump
100100100100252525
The short arm pumps are for big blocks and the long arm pumps are for small blocks.
Make sure on the big blocks that the fuel pump push rod is not worn out
