Location: Suwanee, GA | My 62 NYer is at my parents, otherwise I wouldn't be asking. I need to pull the parking brake drum this weekend and thinking I'll need to make a tool to hold the drum by the studs while I loosen the center nut. Can anyone provide the either the bolt circle diameter, or the distance between two adjacent studs, and the inner diameter of the drum (the small center hole, not the diameter where the shoes contact)?
Thanks,
Robert |
Bolt circle is 3 1/4" |
| I have the emergency brake shoes -- the ol' # 95 -- 2 -- 7" x 2" Brake Shoes -- ++ New ++ Asbestos ++ with ++ NO ++ Core Charge!!!!!!!!!!!!!!!!
Call me, if you need, Craig -- 516 - 485 - 1935 .... New York..... |
Location: Suwanee, GA | Thanks John. Craig, I just left you a voicemail. Maybe we'll talk tomorrow.
Robert |
| Do you have the spring and other parts for the emergency brake I have a 1960 Chrysler Windsor pulled the drum from back of trans and everything just fell out |
