56 Chrysler with a 354 Hemi Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | I'd like to replace the complete spark plug wire kit for this car and wonder if any of you can recommend a good supplier. (New yorker 2.jpg) Attachments ---------------- New yorker 2.jpg (151KB - 165 downloads) | ||
51coronet |
Extreme Veteran Posts: 360 | the old wires are different from todays wires. I see the old style OE wires on ebay. If you have any modern electronics in the car the old wires may cause some noise. | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | No, it's all stock. | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Atlas Obsolete makes, or made, OEM style wires. I use generic 8MM Accel wires on my 331. | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | Mopar1 - 2016-11-01 5:29 PM Atlas Obsolete makes, or made, OEM style wires. I use generic 8MM Accel wires on my 331. DO YOU MEAN LIKE THESE ? http://www.ebay.com/itm/Mopar-426-331-354-392-Hemi-Spark-Plug-Wires... | ||
Expert 5K+ Posts: 9922 Location: Lower Mainland BC | Reg Evans - 2016-11-01 7:26 PM I'd like to replace the complete spark plug wire kit for this car and wonder if any of you can recommend a good supplier. I have just ordered these (should have done this awhile ago): http://www.moparmall.com/Hemi-Spark-Plug-Wires-w-Insulators-for-195... | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | 56D500boy - 2016-11-01 10:19 PM Reg Evans - 2016-11-01 7:26 PM I'd like to replace the complete spark plug wire kit for this car and wonder if any of you can recommend a good supplier. I have just ordered these (should have done this awhile ago): http://www.moparmall.com/Hemi-Spark-Plug-Wires-w-Insulators-for-195... Hey Thanks 56D500Boy. Those look like what are on the engine now. I just ordered a set ! Reg | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | ...not so sure that the 'metallic' core is the best wire these days....... | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | Why do you say that ? | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Can interfere with electronics & possible buzz on radios. Reportedly not compatable with Pertronix II ignition (OK with regular Pertronics). | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Reg Evans - 2016-11-01 8:37 PM Mopar1 - 2016-11-01 5:29 PM Atlas Obsolete makes, or made, OEM style wires. I use generic 8MM Accel wires on my 331. DO YOU MEAN LIKE THESE ? http://www.ebay.com/itm/Mopar-426-331-354-392-Hemi-Spark-Plug-Wires... Those will work, but generic strait boot 8MM Accel wires are a bunch cheaper & work well. | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | Is the spark plug tunnel suppose to have a rubber cap on it after the wire is installed ? | ||
Expert Posts: 3780 Location: NorCal | The early Hemis had no rubber seal at the top of the tube like the later 426 Hemi does. | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | Thanks 57chizler ! | ||
Expert 5K+ Posts: 9699 Location: So. Cal | Mopar1 - 2016-11-02 8:58 AM Can interfere with electronics & possible buzz on radios. Reportedly not compatable with Pertronix II ignition (OK with regular Pertronics). I just experienced that problem with my tried and true HEI modules too. With over 12 different vehicles that I have used them on, I have never had one fail. I had a no-spark issue on my '70 Satellite, but it turned out to be a low voltage condition because of a bad bulkhead connector. But I recently installed a copper core coil wire on my '58 Dodge that ended up sparking across to the metal distributor advance tube, through the insulation of the wire. It was about 1/2" away from the tube, but that didn't stop it from arcing there. What's worse is that in doing so, it fried my ignition module. Bogus. Needless to say, I yanked that coil wire out of there and replaced it with a standard version. So I don't recommend them for any electronic ignition systems. | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | Success !!!! I benched the distributor today so I could accurately set the dual points to 17. They were set at about 28 :-( .. My new wire set came from Atlas so I had time to install them on the passenger side only but BAM....the engine came alive and started running on all 8 for once. Plug #4, 6, and 8 were very oily and not firing. I guess the old plug wire set was not delivering the juice to the plugs. A big cloud of smoke blew out of the pass side and then the engine smoothed out and the smoking stopped. WooHoo ! | ||
Expert 5K+ Posts: 9922 Location: Lower Mainland BC | 57chizler - 2016-11-02 1:51 PM The early Hemis had no rubber seal at the top of the tube like the later 426 Hemi does. Like this? (before the wire cover was attached): | ||
Beltran |
Expert Posts: 1730 Location: Michigan | That is a darn pretty engine compartment... could we trouble you for some more pictures of this beauty? | ||
Reg Evans |
Regular Posts: 51 Location: Grass Valley,CA. | Okay, here's some. (56 chry 1.jpg) (56 chry 2.jpg) (56 chry 4.jpg) (56 chry 5.jpg) (New Yorker 3.jpg) Attachments ---------------- 56 chry 1.jpg (157KB - 161 downloads) 56 chry 2.jpg (136KB - 161 downloads) 56 chry 4.jpg (135KB - 163 downloads) 56 chry 5.jpg (114KB - 154 downloads) New Yorker 3.jpg (149KB - 156 downloads) | ||
Beltran |
Expert Posts: 1730 Location: Michigan | Just as pretty outside as on the inside! | ||
