Location: Melbourne, Australia | I've always had an issue with a build up of pressure in the tank on my 57 Plymouth so finally got around to replacing the cap with a vented unit. Went to check it the next day and the tank had filled up with vapour yet again, enough pressure to slightly expand the tank itself ! Should I just drill a hole in the cap and leave it at that ? |
I've always had an issue with a build up of pressure in the tank on my 57 Plymouth so finally got around to replacing the cap with a vented unit. Went to check it the next day and the tank had filled up with vapor yet again, enough pressure to slightly expand the tank itself ! Should I just drill a hole in the cap and leave it at that ?
I've seen this done before although I didn't do it myself. Seemed to work OK from what I recall and no one got "blown up". So in my opinion, a vent is a vent. |
Location: So. Cal | I have the same problem. Did the definition of "vented" change over time? My cap doesn't seem to vent much, if at all. |
Location: Melbourne, Australia | Well I decided to just drill a hole and be done with it. There is no more pressure build up and only a very slight smell of petrol around the cap so I think that it's problem solved. |
Location: Melbourne, Australia | I have that same issue; even with the cap OFF, I can hear the fuel climbing the filler pipe and dripping down the quarter panel... 57 Plymouth just like yours, Poly..... "only" happens in warm weather but a real hazard in a confined space or parked on a public street with smokers walking past.... Colin |
