NON A/C heater control switch Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ewoodard |
New User Posts: 2 | I am blessed with the last hurrah of the forward look, the fabulous 1964 Dodge Custom 880 2 dr HT. As usual, all of the vacuum tubes on the back of my push button heater control switch are broken off, and so the system does not work. I have found a zillion of the repro AC switches on the net, ebay etc., but I need the NON AC switch, part no 2290-089 or equivalent. Where, oh where, can I actually find one? | ||
ABloch |
Expert Posts: 1479 Location: Pacific Northwest | Give Tony a call at Old Car Parts NW (425) 572-0764. I know he has a bunch of these. Either that or Joe Suchy. He has all kinds of '64 Dodge parts. 1-770-964-4441 | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | they aint really too hard to fix , and you'd be lucky to find a nos one for @200$ . even a used one @ 100$ or so ----------------------------------------------later http://forwardlook.net/forums/forums/thread-view.asp?tid=39275&post... Edited by 60 dart 2016-12-22 11:57 PM | ||
Expert Posts: 3778 Location: NorCal | GASP !!!! http://www.2040-parts.com/nos-mopar-1960-5-full-size-heater-vacuum-... | ||
Rodger |
Expert Posts: 1506 Location: Colo Spgs | Hola Elmer MoPar used the same unit for several loooong years in various vehicles. Because of this take it into a local NAPA and ask if they can match the design. All you know is it came from "an ole MoPar" --- that did not have A/C. -------------------- If the unit is all broken ---- then you also need some better Vac Hose. Rodger & Gabby Colo Sphs | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | i use to deal with the guy from 57's link til he went nuts . he's also got a heater valve for 495+$ . the ac ones i can remember being offered on the pay in lots 10-20-50 for as low as 2-3 per. . now they're a 100$ ------------------------------------------------later | ||
hemidenis |
Expert Posts: 3889 Location: Northen Virginia | It is a guy somewhere in here who repair theses. I was lucky enough to buy 2 of theses when the cost only $100 each. Some parts of theses cars are seriously despairing form the shelf... | ||
Expert Posts: 3778 Location: NorCal | An old source I have listed for vacuum switch repair is: Anthony Powell 1305 North Grant Dr. Sherman,TX. 75092 aepowell3@juno.com Don't know if he's still around. Also: https://originalair.com/restoration-mopar-controls Edited by 57chizler 2016-12-26 12:55 PM | ||
Ray |
Expert Posts: 1497 Location: Fairfax, Minnesota | 57chizler - 2016-12-26 11:51 AM An old source I have listed for vacuum switch repair is: Anthony Powell 1305 North Grant Dr. Sherman,TX. 75092 aepowell3@juno.com Don't know if he's still around. Also: https://originalair.com/restoration-mopar-controls I contacted him a few months ago. He quoted something close to $75 to repair the vacumn switch unit for my 61 Chrysler non-AC. | ||
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | if it's not too far gone you could repair the switch yourself. It's not that difficult. page 1 page 2 Edited by Polara61_383 2017-01-03 4:31 AM | ||
Expert Posts: 3778 Location: NorCal | That doesn't help if the hose nipples are broken off like the OP's. | ||
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | You are of course right, I should have read OP's post more careful. However, you can repair those nipples as well. I repaired them by drilling the broken nipples to the same size and then glued brass tube of the correct OD into the holes using JB weld or something similar. I think I have more detailed instructions on that as well somewhere | ||
Polara61_383 |
Veteran Posts: 158 Location: Ottawa, ON | I've fixed a couple of heater control switches by finding just the right size brass tubing to fit inside the nipples and cutting it just long enough to match the length from flush inside the switch housing to the tip of the nipple. The brass tubing is available at some hardware stores and most good hobby shops. Cut the piece to length, coat outside of brass tube with JB Weld, insert in porthole on switch body and slide broken plastic nipple back in place over the tubing and wipe off any excess on nipple or smooth surface of inside switch housing and make sure the tube is clear. Let set overnight, put it back together. These switch assemblies are held together by 1/8 inch plastic rivets. I cut the heads off with an Exacto knife then drill them out and tap holes and replace with miniature allen head screws from a hobby shop. Then you have a serviceable switch that can be easily disassembled Quoted from http://www.1962to1965mopar.ornocar.com/techstuff.html | ||
