What should the distributor gasket look like (56 Custom Royal V8)
Posted 2017-02-12 2:32 AM (#533811)
Subject: What should the distributor gasket look like (56 Custom Royal V8)
500020002000500100100100100
What I found when I removed the distributor was a thin metal ring. Doesn't seem like a gasket. How does it retain oil? I expected a rubber O-ring or rubber gasket, not metal.
I think the PN is 1326 836 (or 1326836 for Google).
This what turns up:
http://www.marineengineparts.com/chrysler-1326836-distributor-seal-...
http://www.ebay.com/itm/1951-1971-NOS-MoPar-DISTRIBUTOR-METAL-GASKE...
Edited by 56D500boy 2017-02-12 2:33 AM
60 dart
Posted 2017-02-12 4:43 AM (#533813 - in reply to #533811)
Subject: Re: What should the distributor gasket look like (56 Custom Royal V8)
50002000100050010010010010025
i've never used em ---------------------------------------------later
finsruskw
Posted 2017-02-12 9:15 AM (#533822 - in reply to #533811)
Subject: RE: What should the distributor gasket look like (56 Custom Royal V8)
2000100100252525
That's it!
wayfarer
Posted 2017-02-12 11:36 AM (#533832 - in reply to #533811)
500100100100252525
There isn't much oil in the vicinity of the gasket so the embossed tin works very well.
As a cost reduction measure, later gasket sets include a paper gasket.
Posted 2017-02-12 4:32 PM (#533848 - in reply to #533811)
20001000500100100252525
In cases of pretty severe blow-by (crankcase pressure) you might get oil leakage without a gasket but usually not.
