Location: Minnesota | Does anyone have a picture from inside the trunk that shows where the rear fin mount antenna strap should be attached and the orientation of where it connects to the main antenna tube. It's been seven years since I took it apart and apparently I welded up the holes when I was fixing the trunk floor. Measurements might help too. Thanks for any assistance I can get! It is always appreciated, Mark |
Location: Hay Lakes, Alberta, Canada | Here are a few, from a '58 Chrysler...
('58 fin antenna small.jpg)
(58 fin antenna 3 small.jpg)
(58 fin antenna 4 small.jpg)
Attachments ---------------- '58 fin antenna small.jpg (243KB - 177 downloads) 58 fin antenna 3 small.jpg (227KB - 188 downloads) 58 fin antenna 4 small.jpg (209KB - 165 downloads)
Location: New Castle PA | Here are some from a '57 DeSoto.
(antenna_inside_fin_1.JPG)
(antenna_inside_fin_2.JPG)
(antenna_inside_fin_3.JPG)
(antenna_inside_fin_4.JPG)
Attachments ---------------- antenna_inside_fin_1.JPG (199KB - 158 downloads) antenna_inside_fin_2.JPG (195KB - 168 downloads) antenna_inside_fin_3.JPG (105KB - 167 downloads) antenna_inside_fin_4.JPG (166KB - 162 downloads)
Location: Minnesota | Thanks! That helps a lot!!! Greatly appreciated! |
