WTB Hemi Spark Plug Tube Seal Retainer Ring Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Leadfoot1000 |
Veteran Posts: 241 Location: Southern CA | It looks like a big washer. I have only seven of them, need one more. Thanks | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | The Retainer, Spark plug tube seal are items 15 and 87 in the diagram below. That leads to Section 8-36-138 in the parts list and that reveals the PN as 1324 941. You should have eight seals too, items 16 and 86, which go to 8-36-137 and PN 1324 940. PN is 1324 941 which crosses to an Atlas 825-465 Retainer, spark plug tube seal if that helps. Collectors Auto says they have one (or more) NOS 1324 940s and 941s http://www.collectorsautosupply.com/query.asp?make=Mopar+Fullsize&y... (Ctrl F on 1324940 and 1324941). Len Dawson doesn't list the 1324941 but he does list the 1324940 seals at $4 each: http://www.dpmotorparts.com/inventory_4_b.cfm S-99 23 1324940 SPARK PLUG TUBE SEAL 52-58 8 CYL 4 Edited by 56D500boy 2018-01-14 10:54 AM (HemiEnginePartsMap.jpg) (HemiEnginePartsMapIndex.jpg) (HemiEngineParts8-36-138_RetainerSparkPlugTubeSeal_PN1324941.jpg) Attachments ---------------- HemiEnginePartsMap.jpg (170KB - 96 downloads) HemiEnginePartsMapIndex.jpg (164KB - 92 downloads) HemiEngineParts8-36-138_RetainerSparkPlugTubeSeal_PN1324941.jpg (236KB - 82 downloads) | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | Go to your local farm/fleet or whatever store and look for "machine bushings" or shims. They are usually in the row that had all the nuts and bolts in bins as well as smaller trays w/hardware of all sorts. Also check www.McMasterCarr.com website. They also carry a complete line of that sort of stuff What's the I.D. of those washers? Edited by finsruskw 2018-01-14 10:24 AM | ||
Expert 5K+ Posts: 5006 | they are on ebay and hot heads. collectors auto supply is a flipper for DP(they simply mark up DP parts 30% and contact DP)... | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | mikes2nd - 2018-01-14 10:55 AM Collectors auto supply is a flipper for DP(they simply mark up DP parts 30% and contact DP)... DP = Len Dawson's Deception Pass Mopar parts I presume. I know how Collector's works. They only have some parts, the rest are in a dealer network that they have database links to. Collector's website is accessible and will come up on a Google part number search whereas DP never does. My strategy is to find the PN (as I did above) and then check with Collectors via an online search of their database. If they say they have it, then I check DP and my local NOS guy (100,000 NOS Mopar parts) (because might be one of the ones that Collectors say "they" have it). I prefer my local guy but sometimes he doesn't have what I need. I have bought from DP but never from Collectors because I know their prices are too high. | ||
NM Desoto |
Veteran Posts: 145 | The retainers on the Desoto I am working on average around 1.400" Id and 2.00" OD. Any competent hardware store should be able to get machine bushings that size if they don't stock them. | ||
Leadfoot1000 |
Veteran Posts: 241 Location: Southern CA | Thanks for the replies guys, those exploded engine diagram’s and data are very useful. The retainer measures at 1.93” OD 1.4” ID and 0.1” thick. I looked at some bushings but haven’t found the right fit. I’ve been looking on epay but haven’t seen any, other than with a set of tubes. Send a link if you have one. The actual seals are available from Napa made by Felpro. Collectors has them listed as “call for price and availability.” I’ll give them a call tomorrow after I check with DP. | ||
Leadfoot1000 |
Veteran Posts: 241 Location: Southern CA | Collectors Auto has them in stock for $15 + $4 shipping, so I bought one. Thanks. | ||
