Water Pump Idler Pulley 1956 Imperial Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
petew |
Member Posts: 33 | The bearing in my water pump belt idler pulley is shot. It looks like the bearing comes out from the back but I am not certain . Is there any service that can rebuild (replace the bearing) this pulley or can anyone provide me with a part number and source for the bearing ? If I knew the process I would re-bearing it myself but at this point I don't want to damage the pulley by guessing. The application is a 354 hemi in a 1956 Imperial. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I will try dig mine up and have a look at it tonight. I converted my 354 hemi to use the water pump, cross over and accessories of a 392 hemi so I no longer use the idler. | ||
petew |
Member Posts: 33 | Any help greatly appreciated , I thank you sir. Pete | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I didn't get to it last night, I will shoot for tonight. | ||
petew |
Member Posts: 33 | thank you | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I am curious about this so I've tried to find the PN for the bearing. I might have been successful (or not): Engine bay photos followed by Parts Diagrams and a Part number list for Section 7-04-1 in the diagram. The bearing *might* be in Section 7-04-14. No guarantee. (Sorry). Edited by 56D500boy 2018-01-16 2:56 PM (56ImperialWithWaterPumpIdler.jpg) (56ImperialWaterPumpIdlerDetail.jpg) (56ImperialCoolingSystemPNDiagram.jpg) (56CoolingSystemSection7-04-0PartNumbers.jpg) Attachments ---------------- 56ImperialWithWaterPumpIdler.jpg (158KB - 125 downloads) 56ImperialWaterPumpIdlerDetail.jpg (230KB - 140 downloads) 56ImperialCoolingSystemPNDiagram.jpg (175KB - 159 downloads) 56CoolingSystemSection7-04-0PartNumbers.jpg (187KB - 133 downloads) | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I spent an hour tonight digging through parts and found all my pulleys, idler was not there. Sorry, I tried. | ||
petew |
Member Posts: 33 | Thanks for taking the time check . 56D500 boy good info and that's a nice looking engine compartment . My hope is that someone will see this thread here and has encountered this before and will have the info I need. I presently have the pulley assembly face down on my bench with a mix of STP and oil covering the top . It seem to be slowly seeping in and quieting down the bearing, we'll see what happens. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | petew - 2018-01-17 11:14 AM My hope is that someone will see this thread here and has encountered this before and will have the info I need. I presently have the pulley assembly face down on my bench with a mix of STP and oil covering the top . It seem to be slowly seeping in and quieting down the bearing, we'll see what happens. Not saying that this is what you need but it is a common bearing used in many engine accessories. It's only about $6 so buying one to try isn't going to be the end of the world: Here is one application (circa 1992-97 Audi belt tensioners but it is also used in many generators and alternators): Edited by 56D500boy 2018-01-17 11:47 AM | ||
Expert Posts: 3777 Location: NorCal | If you're not concerned with originality, there are generic idler pulleys, any A/C shop will have them. | ||
petew |
Member Posts: 33 | 57chizler - 2018-01-17 12:55 PM If you're not concerned with originality, there are generic idler pulleys, any A/C shop will have them. True idler pulleys are common but I have never seen a double pulley before . | ||
Expert Posts: 3777 Location: NorCal | https://www.ebay.com/itm/Dayco-Idler-Pulley-No-Slack-Double-V-Belt-1... (Dual Pulley.jpg) Attachments ---------------- Dual Pulley.jpg (8KB - 123 downloads) | ||
petew |
Member Posts: 33 | Thank you 57chitzler , I just ordered it . | ||
