demon carbs
60 dart
Posted 2018-02-10 1:24 AM (#557816)
Subject: demon carbs
500020001000500
anyone using one ? if so what are the good and the bads ? ---------------------------------------------------------later
dlyle
Posted 2018-02-10 1:39 AM (#557819 - in reply to #557816)
Subject: RE: demon carbs
10010025
60 dart - 2018-02-09 10:24 PM
I have one on a 392 and it works well. Very easy to tune. Choke is a little finicky though.
hemidenis
Posted 2018-02-10 8:58 PM (#557881 - in reply to #557816)
Subject: Re: demon carbs
20001000500100252525
they are the best is what I heard, but they are priced accordingly..
60 dart
Posted 2018-02-11 7:25 AM (#557890 - in reply to #557816)
500020001000500
220$ factory refurbished , 313$ new . i'm thinkin more on the refurbished . everything i've read , heard , seen is top shelf except a little hesitation on a moving
kick down , which can be fixed mostly by timing and knowing the carb itself ----------------------------------------------------------------------------------later
625 cfm
Edited by 60 dart 2018-02-11 4:24 PM
60 dart
Posted 2018-05-28 12:15 AM (#564114 - in reply to #557816)
500020001000500
bought one of these . haven't heard or seen anything bad about em . after installing and start up it ran the same awful as the old eddy carb . so i dug in deeper with timing chain and other thoughts . while getting true top dead center i
just happened to feel tension on #1 pushrods and found i could remove the intake rod with super ease , pretty much just layin , waitin to be plucked out . so onward to a new 464 comp cam , rods , lifters and springs -----------------------------later
https://www.ebay.com/itm/Demon-Carburetion-1901-625-cfm-Street-Demon...
Edited by 60 dart 2018-05-28 12:16 AM
Stroller
Posted 2018-11-18 12:16 PM (#573707 - in reply to #557816)
100252525
Didn't Holley take over Demon? A rebuild kit for a 4150 is half of what Holley gets and works just fine. Holley-Demon, Carter-Edlebrock- remaking the wheel.
CrAzYMoPaRGuY
Posted 2018-11-18 4:34 PM (#573748 - in reply to #557816)
1002525
Demon carbs can be hard to identify, no part numbers on many of them, and they are HEAVY!!!!!! At least mine is. Incredibly heavy
Handygun
Posted 2018-11-27 6:47 PM (#574232 - in reply to #557816)
I ran a 750 speed demon on my 392 for awhile then switched to a QF SS830, I thought the Hemi made more power with the Demon than the QF but the Demon had some demons when the engine would get above 190. Off idle stumble, trouble restarting, slight surging. I had it jetted at 78/84. I still have it, It's going on the Poly stroker.
