New recommended Hayden fan clutch. The 2947 to replace the 2765
b5rt
Posted 2018-04-01 5:18 PM (#560899)
Subject: New recommended Hayden fan clutch. The 2947 to replace the 2765
200010010010010025
The topic of fan clutches has come up repeatedly and the current recommendation seems to be the Hayden 2765. In fact I'm running one on my 69 Coronet R/T. It has a shallow offset to allow clearance between the fan and radiator. I do however have a problem with the 440 running hot (but not boiling) after driving for over 20 minutes.
I was reading the Dec. 2017 issue of Mopar Action (yes it's back in publication!) and the engineer Richard Ehrenberg addresses the Hayden 2765 as a "sleazy Jaguar clutch which was the thinnest available". He states it is " designed for a much smaller and lighter blade, causing the clutch's fluid to overheat and slip (thereby freewheeling the fan). Now Hayden has released a specific HD thermal-control fan clutch for this problem, we got one at a super price from Rock Auto. The P/N is 2947". He also states that Ma Mopar called the clutch fan setups "Silent Flite".
He then has a picture showing "it has an offset of a scant 1 1/8".
I post this to open the possibility that the 2947 is a better alternative to the 2765.
Edited by b5rt 2018-04-01 5:24 PM
StillOutThere
Posted 2018-04-01 6:49 PM (#560906 - in reply to #560899)
Subject: Re: New recommended Hayden fan clutch. The 2947 to replace the 2765
200050010010010010025
Good post, thanks. I also have a '69 Coronet R/T 440 car. With the standard 26" radiator though, this has always been the coolest running car I own and now starting its 15 year in my barn and I'm in south Texas on top of that.
