56' Belvedere interior Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Justinsane |
Location: Binghamton NY | I'm finally at the point of giving the interior a makeover. I've been neglecting it for twelve years now, driving around with rags over the crispy foam on the seats. Torn, stained, and fallen headliner, every bulb blown in the dash, water leaking in through the cracked door seals, side windows rattling from deteriorated window channel and whiskers. My girlfriend got me a headliner and windlace for Christmas from SMS fabrics to get me motivated. The past few months i've been working on it through the weekends, so i figure i'd post some things for you guys as i work on it, so you can get a glimpse of the project, or maybe pick up some ideas or references if you're planning on fixing yours up. What i've been building is a 1956 Plymouth Belvedere, two door sedan. It's several cars into one. A significant amount of it is from 1955 plymouth savoys and belvederes. I used what i could from the parts cars but limited too because as you know they changed from 6 volt to 12 and changed the rear end and grill between those years. Most the rest was the same. | ||
Justinsane |
Location: Binghamton NY | Here's the insulation that was behind the headliner when i tore it out. (20171226_191923.jpg) Attachments ---------------- 20171226_191923.jpg (325KB - 250 downloads) | ||
Justinsane |
Location: Binghamton NY | Here's a view into it with the door panels off. (20180421_144636.jpg) Attachments ---------------- 20180421_144636.jpg (322KB - 253 downloads) | ||
Justinsane |
Location: Binghamton NY | Sound deadener insulation.. (20180112_005731 (2).jpg) Attachments ---------------- 20180112_005731 (2).jpg (382KB - 258 downloads) | ||
Justinsane |
Location: Binghamton NY | I had to make the flange wider on the windlace using template board to be able to attach it to the interior. I wrapped it with black gorilla tape to hide the color of the cardboard. (20180331_162157-1 (2).jpg) Attachments ---------------- 20180331_162157-1 (2).jpg (80KB - 239 downloads) | ||
Justinsane |
Location: Binghamton NY | It went on smoothly and tight. Hopefully when the garnish trim and panels go on, it will cover up the flange. (20180422_145438 (2).jpg) Attachments ---------------- 20180422_145438 (2).jpg (322KB - 251 downloads) | ||
Justinsane |
Location: Binghamton NY | I couldn't find any decent push buttons so i had to sand mine with 1000 grit sandpaper to get the yellow out of the green plastic, then paint 3/4 of each of them black so the light from the new bulb will shine through. I put some color in the letters and sprayed a flash of clear on them. (20180428_153504-1 (2).jpg) Attachments ---------------- 20180428_153504-1 (2).jpg (229KB - 244 downloads) | ||
Justinsane |
Location: Binghamton NY | The dash was very tedious and time consuming but i an happy how it's turning out. I still have a few more things to put on it like the stainless trim around the glove box and ashtray, and find a spot to put a clock. (20180428_160144 (2).jpg) Attachments ---------------- 20180428_160144 (2).jpg (65KB - 231 downloads) | ||
Justinsane |
Location: Binghamton NY | It's still got some flaws but i like it. I'm going to keep the steering wheel wore down, i just have to find a full circle horn ring for it. (20180425_211419 (2).jpg) Attachments ---------------- 20180425_211419 (2).jpg (364KB - 247 downloads) | ||
60 Imp |
Location: North Australia | Looking good Man. Steve. | ||
Justinsane |
Location: Binghamton NY | I ordered the window channel and sweepers from Andy Bernbaum auto parts. I got the sweepers with the chrome edge. I was told the Belvederes didn't use the chrome strip type originally, but i got it anyways for something different. I wasn't sure how they were supposed to go on and didn't have any original ones for reference, but i didn't like it just going straight across to meet the window channel, so i took some extra time and figuring to put a bend in them to follow the window opening lines. (20180501_171209 (2).jpg) Attachments ---------------- 20180501_171209 (2).jpg (393KB - 258 downloads) | ||
Justinsane |
Location: Binghamton NY | So, here's how far i have it this evening. I ordered some tack strips from michaels i'm probably going to rivet on in the nook above the front window, and around the rear side windows to snug the headliner tighter. (20180430_221858 (2).jpg) Attachments ---------------- 20180430_221858 (2).jpg (461KB - 260 downloads) | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | Keep up the good work. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Nice. What carpet did you use? it looks molded like the newer ones. I much prefer that to the cut & sewn type that you have to futz with at the hump. | ||
Justinsane |
Location: Binghamton NY | Powerflite, the carpet i used is one i got from a carpet/upholstery place that was going out of business. I put it in there when i first started building this car back in 2006. It's held up really good all these years, but i never put insulation of anything under it so it wore down in areas that have depresses in the steel on the floor pans. I plan on replacing it this summer and insulating under it. My girlfriend found a company called SMS Auto Fabrics. I've been getting the materials from them. I'm 100% certain they have matching materials for your Savoy if you ever need any. They even have the Aztec pattern that was on the seats. It's expensive though. I ordered three yards of it, but will have to change the layout and use more vinyl. Here's a sample sheet if you're interested.. | ||
Justinsane |
Location: Binghamton NY | Here's the sample sheet.. (20180502_233705.jpg) Attachments ---------------- 20180502_233705.jpg (395KB - 239 downloads) | ||
Justinsane |
Location: Binghamton NY | The interior upholstery panels i got were in bad condition but in good enough condition to be restored. The backing board was warped and most of the fasteners were ripped out so i had to make new panels using the old ones as templates. I had to soak the old ones and flatten them back out so i could trace the outline and holes. I used 1/8" masonite or hardboard.They sell it in 4' X 8' sheets at home depot. (20180528_140736 2.jpg) Attachments ---------------- 20180528_140736 2.jpg (351KB - 262 downloads) | ||
Justinsane |
Location: Binghamton NY | I put in the panel fasteners and pre fit them in the interior before i glued the padding and vinyl on. I like the look of the original aztec pattern and i'm going to use that pattern on the seats close to the original arrangement so i kept these close to how they were originally. (20180605_215147-1 2.jpg) Attachments ---------------- 20180605_215147-1 2.jpg (218KB - 244 downloads) | ||
Justinsane |
Location: Binghamton NY | After installing the headliner i put a dome light in from one of the 1955 plymouths i use for parts. About 40% of this car is from 1955 savoys and belvederes. The headliner took some time and was tricky in areas, if any of you need information or advise, feel free to message me and i'll let you know what i went through in the process. (20180607_184120.jpg 2.jpg) Attachments ---------------- 20180607_184120.jpg 2.jpg (215KB - 246 downloads) | ||
Justinsane |
Location: Binghamton NY | The back area is almost complete besides the seat. Those are going to go in last. Next week i'm going to start on the front door window channels, whiskers, seals, then redo the panels. It's starting to look like something again. (20180528_211306 2.jpg) Attachments ---------------- 20180528_211306 2.jpg (315KB - 251 downloads) | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Nice job, that looks really good. Did you end up taking the windshield rubber out to do the headliner? | ||
Justinsane |
Location: Binghamton NY | Thanks! I pulled it pretty tight, i like the fitted bowed look. I did not remove the windshield. I don't know why anyone would. I've heard several people saying you got to remove the windshield and back window, but it doesn't make sense to me. Maybe on other cars you've got to, but not a 1956 plymouth belvedere. I did have to remove the side windows to replace the window channel and wiskers though. Here's a pic of the liner before i put the garnish molding on, above the front window. There are tack strips in that nook that hold the liner as you stretch it onto them. I sprayed it with upholstery glue too so it'll never go anywhere especially with the garnish molding pressing on it. (20180519_134718 (2).jpg) Attachments ---------------- 20180519_134718 (2).jpg (302KB - 233 downloads) | ||
Justinsane |
Location: Binghamton NY | Here's one with the molding on, before i put the sun visors on. | ||
Justinsane |
Location: Binghamton NY | and before i put on the window frame moldings. I had to cut stress reliefs in that corner and wrap it around with glue too. (20180520_143721 (2).jpg) Attachments ---------------- 20180520_143721 (2).jpg (458KB - 239 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Justinsane - 2018-06-07 10:18 PM The interior upholstery panels i got were in bad condition but in good enough condition to be restored. The backing board was warped and most of the fasteners were ripped out so i had to make new panels using the old ones as templates. I had to soak the old ones and flatten them back out so i could trace the outline and holes. I used 1/8" masonite or hardboard.They sell it in 4' X 8' sheets at home depot. I like your thread. Congrats on the good work. I too had to remake door panels. I also used 1/8" Masonite. Cutting the rectangular holes for the spring clips was a lot of fun (NOT). After I finished the first panel, I bought a pre-made set (cardboard) off eBay. My door panel thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64288&... Mine during the construction process, a test fit before I put the "skin" back on. Edited by 56D500boy 2018-06-08 6:03 PM | ||
57DODGECONV |
Elite Veteran Posts: 854 | Wow nice job on all your Interior ,Everything looks Great. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Justinsane - 2018-06-07 8:28 PM before i glued the padding and vinyl on. Justin, looks good, what did you use for padding and how thick was it? I got some fake tan Naugahyde with a pattern in it at a local fabric store and I am looking forward very much to doing the panels. Thanks, Ray, | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Justin, I tired to delete or edit my message, I couldn't. I found some padding, thanks anyways. | ||
Justinsane |
Location: Binghamton NY | Awesome man, i checked out your thread. We went through the same thing. Did you end up stapling your vinyl on after you glued it and wraped it around the masonite? Because i used 1/8 board, i couldn't find any staples anyplace! The shortest at hardware stores are 1/4". I bought a stapler from the fabric store that takes staples like the ones for paper but a little more heavy duty, but most of them poked through so i pulled them out. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I don't think 1/8" staples exist | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | No problem, I've made my own 1/8" staples out of longer ones by cutting them with a sharp nippers. Just work on a lenght of approximately 1/2" of staple stick. Very nice work on the interior! | ||
Justinsane |
Location: Binghamton NY | I've seen 5/32 staples from upholstery supply stores but it doesn't look like they go into the typical staplers sold at hardware stores. I tried nipping and grinding but had no luck. I got enough in to hold the corners where it overlaps and is thicker. I might just buy one of those staplers. I'll let you guys know what i find and how it works.. | ||
Justinsane |
Location: Binghamton NY | I decided to insulate the floor under the carpet with the sound deadener/insulation from tasharina corp. it's the 394mil/10mm thickness so it should make a difference. | ||
Justinsane |
Location: Binghamton NY | Here's the bare floor before i put in the sound deadener. (20180621_201221.jpg) Attachments ---------------- 20180621_201221.jpg (399KB - 228 downloads) | ||
Justinsane |
Location: Binghamton NY | I took my time and cut to seal the edges and flow around the curves. (20180623_195120.jpg) Attachments ---------------- 20180623_195120.jpg (482KB - 248 downloads) | ||
Justinsane |
Location: Binghamton NY | I put the old carpet back in for now, i replaced it back in 2005/2006 so it's still okay, but i'll probably replace it next year. I just want to get the seats reupholstered and put back in so i can drive it before winter. (20180624_174220.jpg) Attachments ---------------- 20180624_174220.jpg (323KB - 237 downloads) | ||
Justinsane |
Location: Binghamton NY | I repainted the highway hifi record player box black, to match the rest of the interior. (20180623_195355 (2).jpg) Attachments ---------------- 20180623_195355 (2).jpg (466KB - 240 downloads) | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | Are those the factory Hi-Fi mounts or did you custom make your own? I would really like to see some more pictures of the mounts if you have any. And did you ever get in touch with my buddy Gary P about the radio? -Dave | ||
Justinsane |
Location: Binghamton NY | We did get in touch, he doesn't have one that has the five pin socket for accessories. I'm still going to keep my eye out for one. The radio i have in there now doesn't have it either. I'm trying to find wiring schematics to put a socket in using amphenol plugs. I have a couple highway hifi players, the one that was in rough shape i disassembled to get parts for spares for the good player. The one in the picture is the one i gutted. For now i'm going to put an mp3 player and an amp in it so i can still have the tunes i want. I fabricated the gap plate out of 16 gauge stainless. It's close to the original plate except I added a 1/2 inch so it hangs slightly lower and put 1/2" pleats to fit that era, match the dash and door panels. I'll see if i have pictures of the parts for you. I think i have them on an old flash drive with other random pictures. | ||
gradford |
Regular Posts: 87 | Nice project! I'm currently working on a 56 Belvedere 2 door HT, and I have three others at various stages of repair: a 56 Belvedere 2dr HT (different one from the current project), a 56 Belvedere Sport Sedan 4 door HT (same interior patterns as yours), and a 56 Savoy 2 door sedan. I need to install headliners in all four, eventually. Can you send me the details of how you installed your headliner? Looks like you did a very nice job, and I'd like to try one myself instead of taking it to the upholstery shop. Thanks Glenn | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | gradford - 2018-07-25 2:17 AM I need to install headliners in all four, eventually. Can you send me the details of how you installed your headliner? Looks like you did a very nice job, and I'd like to try one myself instead of taking it to the upholstery shop. In the interim, you might want to follow this info that I posted previously: 56D500boy - 2018-05-31 9:48 AM Go here: http://www.mymopar.com/index.php?pid=109 Download the 55-56 Plymouth Service Manual. Open the pdf. Go to page 375 Section 12 Headlining. The words and photos are the same as in my 56 Dodge Service Manual. Good luck. I successfully (in my opinion) replaced my windlace without removing the headlining so, yes, "If there is a will, there is a way" :) I think you will find what you need there but I don't want to close the conversation, i.e. real time hints. ViperMan might also want to comment. | ||
Justinsane |
Location: Binghamton NY | Sorry i haven't been on here in awhile. Did you end up replacing your headliner? I've gone through the process many times trying to help people do it. It's not very difficult, just takes patience. Are you putting in a vinyl or fabric headliner, premade? Mine is fabric from SMS auto fabrics. I can send you any information you need to get one from them. They sent me a variety of complete interior samples before i ordered. If you replace the headliner, it might be a good time to do the windlace too. If you read back in this thread i explained some issues i ran into and what i did to solve it. I didn't need to remove the rear window to do it, even though many say it has to be done. Just check your seals inside and out for cracks, and when you have the old liner out, check around the rear window seal for signs of water leakage. It'll stain your liner if the seal is bad. Remove the bands and label them, and take note what hole they come out of. If you are replacing the insulaton you can adjust the bands up or down with those holes the end of the bands go into depending on the thickness of insulation you use. You'll have to remove all your garnish trims to take out the headliner and the side panels in the back if you are doing the windlace too. Check your side window channels for your rear windows, because you might want to replace them too, same with the whiskers on the outside and on the garnish pieces. Get all the old liner out and clean everything really good. It's best to remove the seats too. If you have to remove the headliner retainers above the doors, you'll need to replace the fasteners that hold them on. I just used pop rivits, Ive seen on other plymouths ive gutted, they used screws. The original clips are crimp type that when you put it in the hole, when the outer end is squeezed, it expands inside holding the galvanized headliner retainer on. Put your bows in the liner, start from the rear find center, press it onto the rear retainer above the back window pull it tight on the sides keeping it centered, work your way up front clipping in the bows and pulling it towards the front. When the bows are all in and you got the spacing in between them how you want it, spray your glue on the liner thats going to get tuck into the window channel in the rear side windows if you have a two door. Pull and tuck it in evenly on both sides. Then tape the rear window seal underneath where the slit is that you tuck the liner into, spray the liner always letting the glue set a minute. tuck it into the rear window seal starting in the center towards the sides. Then tuck it into the headliner retainers above the doors, with the windlace already installed. You've got to do the windlace first, it's very important. Make sure you keep good tension on it at all times while you are tucking it in, you want the liner tight. Then spray glue along the front window nook and pull the liner onto the tack strips. If you are on facebook, i got a group i just started to discuss things like this and it's easier to post pictures on there. My group is called 55 56 Plymouth https://www.facebook.com/groups/1133463890135342/ | ||
