1959 Dodge 383: how do I install/align new motor mounts?
fivespeedv8
Posted 2018-05-13 4:44 PM (#563307)
Subject: 1959 Dodge 383: how do I install/align new motor mounts?
Hi all,
Background: I am reinstalling my engine after a rebuild. The transmission is in the car resting loosely. The whole front clip is off the car.
Since the rubber motor mount isolators are an eccentric circle I understand this allows adjusting the engine position on the frame.  But the shop manual and the posts in the forum have not been helpful in figuring out exactly what the alignment should be.
I have attached a description of the procedure from the manual which I cannot decipher.
1) What rotational position inside the motor mount cups should the rubber pieces start out in? Should they push the motor up, down, left, or right? level or tilted? Or do you just play with the adjustment to ensure the engine and transmission alignment is true? In the image, it APPEARS that the meat of the rubber goes UP and the hollow part goes DOWN.
2) The manual also says to use some sort of cement. What would you use? There doesn’t appear to have been any type of glue in there before although I’m not positive they were original.
thanks!
Edited by fivespeedv8 2018-05-13 6:51 PM
(D63D1C1A-3794-45BB-8182-F3974545D96B.jpg)
Attachments D63D1C1A-3794-45BB-8182-F3974545D96B.jpg (99KB - 113 downloads)
fivespeedv8
Posted 2018-05-13 4:54 PM (#563309 - in reply to #563307)
Subject: Re: 1959 Dodge 383: how do I install/align new motor mounts?
Forgot to mention that the motor mount isolators I bought already have the threaded stud and serrated “washer” installed. I presume that’s the “inner cup?”
Posted 2018-05-13 7:34 PM (#563314 - in reply to #563307)
50001000500
Hmmm....They usually find center when the engine is installed. You could do a test fit, mark the cylinders and apply 3M 1300L or similar adhesive. Once installed I don't think they can pop out . Install the engine and tranny and fit to the trans. cross member. You can do some measuring, but a string from the front crank shaft to the rear axle might help with the center line. These engines are 1-1/2'' off center or so for the steering box. I have some pics of a 383B in a 1957 frame.
(58plyrattleboxengine1.jpg)
(58plyrattleboxengine2.jpg)
(58plyrattleboxengine3.jpg)
Attachments 58plyrattleboxengine1.jpg (224KB - 130 downloads)
Attachments 58plyrattleboxengine2.jpg (231KB - 127 downloads)
Attachments 58plyrattleboxengine3.jpg (216KB - 116 downloads)
fivespeedv8
Posted 2018-05-14 11:33 AM (#563347 - in reply to #563307)
thanks for the tip
fivespeedv8
Posted 2018-05-17 2:42 PM (#563578 - in reply to #563307)
Subject: RE: 1959 Dodge 383: how do I install/align new motor mounts?
The engine went in with the rubber insulator aligned as shown in the illustation: The inner cup, or hollow part, at the bottom.
Posted 2018-05-18 9:04 PM (#563621 - in reply to #563307)
50001000500
two more pics i just found.
(myenginemounts350-383-400-1.jpg)
(myenginemounts350-383-400-2.jpg)
Attachments myenginemounts350-383-400-1.jpg (237KB - 116 downloads)
Attachments myenginemounts350-383-400-2.jpg (221KB - 122 downloads)
