Two oval shaped holes in core support on driver’s side, below terminal block. What are they for?
Leadfoot1000
Posted 2018-10-23 2:59 PM (#572231)
Subject: Two oval shaped holes in core support on driver’s side, below terminal block. What are they for?
10010025
I am considering blocking them off to force a little more air through the radiator.
Posted 2018-10-23 3:37 PM (#572232 - in reply to #572231)
Subject: RE: Two oval shaped holes in core support on driver’s side, below terminal block. What are they for?
500020002000500100100100100
Leadfoot1000 - 2018-10-23 2:59 PM
Not knowing for sure, but trusting the engineers who designed that rad support, etc. I would say that they are there to provide some cooling to the battery which is just there on the other side of those holes.
Edited by 56D500boy 2018-10-23 3:38 PM
Leadfoot1000
Posted 2018-10-23 3:54 PM (#572234 - in reply to #572231)
Subject: Re: Two oval shaped holes in core support on driver’s side, below terminal block. What are they for?
10010025
I was thinking that too, I’ll just leave them open. I imagine the radiator cooling advantage of plugging them would be minimal at best anyway.
Posted 2018-10-23 4:08 PM (#572236 - in reply to #572231)
5000
yeah probably wanted some free air moving under hood.
maybe to help the down draft tube, take some fumes out of the engine bay?
maybe make sure the battery was getting air movement since these batteries would blow up
