heater / defrost motor wire gauge
hondaman1974
Posted 2018-11-19 3:30 PM (#573790)
Subject: heater / defrost motor wire gauge
100252525
hello, im in the process of rewiring my dash on my 55 custom royal. was wondering what gauge wire is used on the heater and defrost motor circuits. my fsm does not specify this. any input would be greatly appreciated.
Posted 2018-11-19 3:55 PM (#573791 - in reply to #573790)
Subject: RE: heater / defrost motor wire gauge
500020002000500100100100100
hondaman1974 - 2018-11-19 3:30 PM
hello, I'm in the process of rewiring my dash on my 55 custom royal. was wondering what gauge wire is used on the heater and defrost motor circuits. my fsm does not specify this. any input would be greatly appreciated.
I would bet that the wiring diagram is in the service manual but hiding in plain sight. I had to open up my 56 Dodge FSM and page it a bit until I found what you would need in a 55 FSM. For the 56 Dodges, the heater and defroster motor wiring was 14 Gauge and "black" (black threads in a beige covering??).
(56DodgeHeaterWiring_small.jpg)
Attachments 56DodgeHeaterWiring_small.jpg (233KB - 231 downloads)
hondaman1974
Posted 2018-11-19 8:22 PM (#573803 - in reply to #573790)
100252525
thanks 56d500, I found part of the diagram in the accessory chapter but doesn't show the gauge. my electrical section shows diagrams for lighting, starting, ignition, wiper and power seat. I may thumb through each page and see if its there. thanks!!!
Posted 2018-11-19 9:05 PM (#573804 - in reply to #573803)
hondaman1974 - 2018-11-19 8:22 PM
The 56 Dodge FSM showing the 14 gauge could be used as your guide. 14 Gauge is pretty stout. However, if you are concerned you could go to 12 gauge. I think 10 gauge would be over kill.
IF you find the correct diagram in your 55 FSM, please scan it and post it up here. For that matter, you might want to scan the other 55 FSM electrical diagrams and post them up here. I am going to start a 55 and 56 Electrical diagram thread very soon and your info would help.
There aren't too many 55 and 56 Dodge (or Plymouth, etc) guys on this forum so anything we post up could help us and the few others that are here.
Just a thought.
Posted 2018-11-20 1:54 AM (#573829 - in reply to #573790)
Subject: Re: heater / defrost motor wire gauge
50005000200010002525
You can use the AWG 14 gauge as original, but you could also install relays for the heater fan.
The schematic below id for '60 Chrysler, but it's the same principle - this way you'll have no voltage drop to the heater fan and the relays can be easily hidden.
(Heater Fan Relays-rez.png)
Attachments Heater Fan Relays-rez.png (43KB - 228 downloads)
hondaman1974
Posted 2018-11-20 11:57 AM (#573847 - in reply to #573790)
100252525
thanks for your input!!! 14 gauge it will be. 56d500, let me know what you need I would be glad to help, if I get a chance ill post some pics of the diagrams this weekend.
Posted 2018-11-20 1:51 PM (#573858 - in reply to #573847)
hondaman1974 - 2018-11-20 11:57 AM
I remembered that I had a 55-56 Plymouth FSM pdf in my archives so I took some of the wiring diagrams from it and started a new 55-56 Dodge and Plymouth Wiring Diagram thread. If I missed anything, please add it too the thread.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=70141&...
I found the 55-56 Plymouth heater wiring diagram and was surprised that, as you said, there are no wiring gauge notations on it. 14 should work fine.
