Sharp looking 57 Firesweep 2D HT Hemi, pwr steering/brakes, front discs; $25,000 Moderators: ronbo97 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - EBAY, CRAIGSLIST & OTHER FINDS | Message format |
drosera88 |
Expert Posts: 1267 Location: San Antonio TX | Gorgeous!!! Guy upgraded it to disc brakes and that master cylinder looks aftermarket. Comes with the stock wheels and caps if you want to return it to a stock look. Under the hood looks good as well, steel braided lines and hoses with electronic ignition. Has after market 4bbl. The only thing I'd do to this is get rid of the two extra gauges on the dash and find a less conspicous air cleaner to give it a slightly more stock look under the hood. Also, about the hemi. Could you order Firesweeps with hemis or is this a swap? If it's a factory hemi, how rare is this? https://lasvegas.craigslist.org/cto/d/pahrump-1957-desoto-firesweep/6778710693.html | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I know nothing but I *think* that, because the Firesweeps were the lowest level Desoto model, they normally came with a 325 2 bbl poly in 1957. Edited by 56D500boy 2018-12-24 11:48 PM (1957 DeSoto Prestige-16.jpg) Attachments ---------------- 1957 DeSoto Prestige-16.jpg (167KB - 69 downloads) | ||
Doctor DeSoto |
Location: Parts Unknown | We've been over this before .... Firesweeps are Dodges with some DeSoto sheetmetal and the low end DeSoto interior. They were built on the Dodge assembly lines and every bit of the chassis, brakes, and drivetrain is pure Dodge. Thusly, no Firesweep ever left the factory with a DeSoto engine, namely a Hemi. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Doctor DeSoto - 2018-12-25 12:25 AM They were built on the Dodge assembly lines and every bit of the chassis, brakes, and drivetrain is pure Dodge. Thusly, no Firesweep ever left the factory with a DeSoto engine, namely a Hemi. Which is what I thought, i.e. the 325 was the poly 57 Dodge engine. The 4 bbl 341 was obviously a hemi. However what about the 2 bbl 341? Was that a poly or hemi? Edited by 56D500boy 2018-12-25 1:56 AM | ||
firedome |
Expert Posts: 3155 Location: NY & VT | 341 hemi in 'dome + 'flite, different carbs, like Doc say, DeSoto engine for the longer wheelbase DeSoto car. Edited by firedome 2018-12-25 7:45 AM | ||
Doctor DeSoto |
Location: Parts Unknown | I have never cared for cars after about 1930 and before fins, so I cannot say when this began, but Mopar offered a package referred to as something like "the Power Pack" that upgraded the carb from a base 2bbl and the exhaust from single to duals on the low end model cars. This was certainly the case with a Firedome in 57, but I will have to plead ignorance on the 'Sweep. Being that Dodge offered 4bbl's on the 325, I will assume the 'Sweep could be ordered that way too. This car looks like a well put together "bitsa" car, where the builder took bits of this and bits of that to make what they wanted, or simply put the car together with parts available to them. It happened/happens a LOT ! | ||
bbrasse1 |
Extreme Veteran Posts: 537 Location: Upstate NY | It looks to me like a Firesweep that someone decided to increase the value by dropping a Firedome hemi in it. just quessing | ||
57desoto |
Expert Posts: 1488 Location: New Castle PA | Car sold on Ebay in 2011 for $17k. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I believe the 4bbl power pak option began its roots in 1954 but was very limited. It became more common in 1955. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Powerflite - 2018-12-26 10:41 AM I believe the 4bbl power pak option began its roots in 1954 but was very limited. It became more common in 1955. I would believe that. The 54 Dodge Indy Pace Car had a 4 bbl (and maybe duals) but the brochures make no mention of Power Pack. By 1955, the engines were "Power came from either a 230 cu in (4 L) flathead straight six or one of two 270 cu in (4 L) V8s. The regular Red Ram V8 was standard on the Royal and optional on the Coronet. A hemi V8 (the Super Red Ram) was standard on the Custom Royal. A rare Power Pack was optional, consisting of a four-barrel Carter carburetor and dual exhausts good for 193 hp (144 kW; 196 PS) with the Hemi engine." *In fact* the 193 hp Power Pack option was mentioned in a special "box" on the brochure (lower left corner below): Finally, by 1956 the Power Pack was totally "out" as the 230 hp (instead of the 2 bbl 218 hp) "Super-Powered Super Red Ram" (315 poly). REFERENCE: https://en.wikipedia.org/wiki/1955_Dodge 1954 Brochure 1955 Brochure : 1956 Brochure ("Super-Powered Super Red Ram"): Edited by 56D500boy 2018-12-26 8:29 PM | ||
Doctor DeSoto |
Location: Parts Unknown | When I was in the parts business, these differences and understanding interchangeability were critical knowledge when hunting and buying parts. Helped with the selling too. I found that as one walked up the ladder from Plymouth to Imperial, the level of goodies and options increased relatively, so things like Power Pack equipment was a lot harder to find on a Plymouth than it was on say, a Firedome. One time a guy came to me looking for a 4bbl set up for his 56 Plymouth. He offered me stupid money, if I could find one. The kicker for him was the air cleaner. Knowing what other cars those parts might be found on, I was able to come up with his parts. He was thrilled. | ||
