Location: DFW, TX | Those hydraulic pressure switches are notorious for giving up. I don't know if there is a brake light switch and bracket that would bolt onto the pedal assembly from a C-body.
BUT
I do know it took about 20 minutes contorted under the dash with a piece of steel scrap and a '70s GM brake light switch to get one working in my Plymouth. It worked well enough that I did the same in my Chrysler before I put the dashboard back together :D
Good luck!
Location: Victoria, BC, on Vancouver Island, Canada | I mounted a 1962 Chrysler brake pedal switch in my 60 Chrysler. 62 is the first year for the pedal switch on full sized Mopars. I had to make a small bracket and mounted it so that the switch bottoms out against the knuckle where the pedal assembly pivots at the brake push rod to the master cyl.
Here`s an old thread showing how I made up mine. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=60202&...
Edited by imopar380 2019-03-11 3:25 PM
Location: Southern Sweden - Sturkö island | This is my brake light switch (originally made for the AutoPilot, now another switch is mounted as a twin, one for AutoPilot and the other one for the brake light and ABL
(Mekanisk bromsljuskontakt-rez.jpg)
Attachments ---------------- Mekanisk bromsljuskontakt-rez.jpg (113KB - 182 downloads)
Location: northern germany | FIN_NV - 2019-12-11 2:56 PM
Tired of changing hydraulic switches. Has anyone changed there's? Other than making my own mounting bracket, is there something I could adapt from a C Body?
Thanks in advance,
Steve
Yes, a braket is easy to fabricate but these were popular already back in the day, so there are always some on ebay:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=li... |
Location: The Mile High City | there are a bunch of threads on this topic. One, for example: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=42562&posts=12&start=1 |
Location: Pittsburgh, PA | [2019-03-14 Automated Thread Reset] |
Location: Northern New Jersey | Tired of changing hydraulic switches. Has anyone changed there's? Other than making my own mounting bracket, is there something I could adapt from a C Body?
Thanks in advance,
Steve |
