| So I had talked with aaj but I wasn't told until today that I have to cut parts of my tie rod ends and sleeves up and grind parts of the spindle off. Are there any kits in the same price range that don't have that? I'm extremely wary of cutting up suspension components. |
Location: N.W. Fla. | I used '77 NYer disc spindles on my '60 Plym. Had to trim the tie rod collars a bit |
| for reference it's a 56 savoy |
Location: So. Cal | Yeah, '55-'56 is completely different from '57-up, so any information there would be useless. The '56 doesn't even have ball joints on it.
The other options are to use a Scarebird kit or a kit from Rusty Hope. AAJ also sells a kit that uses bigger 12" rotors that I *believe* doesn't require mods to your parts, *BUT* it requires using Dodge spindles so you have to swap yours out. Not fun. I haven't used any of these kits except the smaller AAJ so I can't give any other advice, but as far as I know, these are your only options apart from making up something custom for yourself. |
| I am thinking of doing the 56 dodge spindles, how bad is putting them on? any reason it's not fun? |
| if i remember right it's the 56 dodge hubs not the spindle |
Location: So. Cal | I think you are right. Just the hubs. My memory isn't the greatest. That wouldn't be too bad. |
| yeah I called aaj earlier, but now I have to find some for a good price, Big M has some but sells the entire drum and hub and I don't need the drum too, will buy both if need be |
| not sure if this will work, but thought i'd post it...
http://www.ecihotrodbrakes.com/dodge_plymouth_discbrake_conversions... |
| I will look into it right now thank you
| eci has the same setup as aaj |
